Why Is My IPhone So Slow All Of A Sudden When Nothing Has Changed?
My iPhone started running slow all of a sudden, even though I haven’t installed new apps, changed settings, or updated anything recently. Apps lag, typing feels delayed, and switching screens takes longer than usual. What could cause sudden iPhone performance issues, and how can I fix it?
A nearly full iPhone can absolutely make the whole thing feel slow. That’s not some random myth people repeat. iOS needs free space for temp files, caches, updates, and memory-related stuff in the background. When storage gets tight, the phone has less room to work, and that’s when you start seeing the annoying stuff: laggy scrolling, delayed typing, apps taking forever to open, and the whole UI feeling sticky.
A good target is to keep roughly 10% to 20% of your storage free. If you’re down to only a few GB, even if it looks like “some space” is left, the phone can still start acting weird.
That said, storage isn’t the only thing that can cause it. If this started right after an iOS update, give it a little time before assuming something is broken. For the first 48 to 72 hours, the phone may be doing a bunch of background work like reindexing photos, rebuilding app data, and cleaning up files. Leaving it plugged in on Wi-Fi overnight for a couple nights usually helps it settle.
If it’s been a week or more and it’s still bad, check Battery Health in Settings. Once maximum capacity drops under 80%, Apple’s performance management can slow the processor to reduce random shutdowns. Heat can do the same thing too, especially if the phone is in direct sun or trapped in a thick case.
But honestly, storage is the thing I’d check first. It’s really easy to end up with a ton of junk without noticing: duplicate-looking photos, old 4K videos, screen recordings, random screenshots, all of it. Trying to clean that manually gets old fast.
What fixed it for me was using Clever Cleaner. I’m usually suspicious of cleanup apps because a lot of them are just subscription traps, but this one was actually free, with no ads, hidden paywalls, or subscription nonsense.
The useful part is that it doesn’t just say “delete stuff.” The Heavies tab sorts photos and videos by size, so you can immediately find the giant 4K clips and old screen recordings eating storage. It also shows the file size right on the thumbnail, which makes decisions easier. The Similars tab groups near-duplicate photos, like when you took ten versions of the same picture, and it suggests the best one to keep.
Privacy-wise, it also processes everything on the phone instead of uploading your photo library somewhere else. After clearing around 20GB, the difference was obvious. The lag went away and the phone felt normal again.
One thing people miss after cleaning photos: go to Photos, open Albums, scroll to Recently Deleted, and hit Delete All. Otherwise those files can sit there taking up space for 30 days.
Before doing a factory reset, I’d try this first:
  1. If you just updated iOS, wait a few days and keep it plugged in on Wi-Fi overnight.
  2. Make sure Low Power Mode isn’t on. The yellow battery icon can make the phone feel slower.
  3. Clear Safari’s cache in Settings.
  4. Free up a real cushion of storage, ideally at least 10GB or more.
If your storage is packed with the same kind of photo and video clutter, Clever Cleaner is a much faster way to find the huge files and near-duplicates than doing it all by hand.
Don’t start with a factory reset just because the whole phone suddenly feels laggy. The storage point is fair, but sudden lag with no obvious change can be a stuck process, so fully power it off for a minute, turn it back on, and see if one specific app is still dragging everything down before deleting half your stuff.
Don’t assume “nothing changed” means the phone isn’t suddenly doing work in the background. iPhones can get weirdly slow from stuff you didn’t manually start, like iCloud Photos syncing, Messages re-indexing, a stuck app refresh, Mail trying to download a huge inbox, or a bad network/VPN connection making apps hang.
I agree with @techchizkid that a full power-off is the first move, not a factory reset. But after the restart, I’d check whether the lag is really the whole phone or if one background task is poisoning the experience.
Go to Settings > Battery and look at the last 24 hours. If you see one app with a lot of Background Activity, that’s your suspect. Photos, Messages, Mail, Safari, Facebook/Instagram/TikTok, cloud storage apps, and navigation apps are common offenders. You don’t need to delete everything immediately. Try turning off Background App Refresh for that app, force close it once, then reboot.
If typing is delayed everywhere, check whether you’re using a third-party keyboard. Those can lag badly when they glitch. Switch back to the default Apple keyboard for a while and see if the delay disappears. If it only happens in one app, then the phone may not be the problem.
A few fast checks before doing anything drastic:
  1. Turn off VPN temporarily if you use one.
  2. Disable Low Power Mode if it’s on.
  3. Check Settings > General > iPhone Storage, but don’t panic-delete random stuff unless storage is actually tight.
  4. Look at Battery Health. A worn battery can make the phone feel older overnight.
  5. Take the case off for a bit if the phone feels warm.
  6. Leave it plugged in on Wi-Fi for an hour or two, especially if Photos or Messages seems busy.
The storage advice above is valid, but I’d be careful with the idea that storage is always the cause. If you have, say, 40GB free, clearing photos probably won’t fix a runaway process, bad app update, or keyboard glitch. If you only have 2GB free, then yes, clean first.
Factory reset should be near the bottom of the list. Before that, try Reset Network Settings if apps are hanging on loading screens, or Reset Keyboard Dictionary if the main symptom is delayed typing and autocorrect acting strange. Those are annoying because you’ll lose saved Wi-Fi networks or keyboard learning, but they’re much less painful than wiping the whole phone.
The pattern matters. Slow after unlocking plus warm phone usually points to background activity or heat. Slow while opening web-heavy apps can be network, VPN, or DNS. Slow typing in every app can be keyboard or low performance mode. Slow only when storage is almost full is probably storage. Treat it like narrowing down a suspect instead of immediately doing the nuclear option.
Try putting the phone in Airplane Mode for five minutes, then open Notes, Settings, Photos, and a few apps that don’t need the internet. If typing and swiping suddenly feel normal, the phone may not be “slow” so much as waiting on a bad network, VPN, iCloud sync, Private Relay, or some app constantly trying to phone home.
That’s where I’d slightly push back on jumping straight to storage cleanup. Full storage can definitely make an iPhone crawl, but if the lag mostly shows up when opening feeds, Safari, Mail, App Store, maps, or anything cloud-based, deleting photos may not touch the real problem. Forget the Wi-Fi network and rejoin it, turn VPN off, switch between Wi-Fi and cellular, and see if the behavior changes. A flaky DNS or hotel/work/school Wi-Fi can make the whole phone feel broken because so many apps wait for network checks.
If it’s still laggy in Settings and Notes while totally offline, then yeah, look at storage, battery health, heat, and background activity like the others said. Clever Cleaner or the built-in iPhone Storage screen can help find huge videos, but I’d treat that as a cleanup tool, not a magic “make phone fast” button. The quick split is: slow offline means local phone issue; slow only online means connection or account syncing issue. That saves a lot of wasted deleting.
