Where can I measure Flesch Reading Ease?
I have to include a Flesch Reading Ease score when I send the office my handout on reserving a meeting room. What do you use to check the score on a document like that? The handout is a PDF, but I still have the editable text.
If your editable text matches the PDF you’re sending, paste it into the clever humanizer reading level calculator. The live score is handy for a handout: if you split a long reservation step into two sentences, you can see the new score without pasting the whole thing again.
In your office document, please include the ‘Flesch Reading Ease’ score, rather than the Flesch-Kincaid grade level. In your email, write ‘Flesch Reading Ease: [score]’ so that we know which score corresponds to which document.
Check readability using the Clever Humanizer Readability Checker in the last version. It is ideal for using in an office setting as you can calculate the score directly within your browser.
If the editable version uses the same text as the final PDF, copy into the Clever Humanizer Readability Checker (making sure that line breaks do not cause a hyphen to be added at the end of a sentence). Check through this text quickly, and copy across the number for Flesch Reading Ease. Don’t copy across the value for Flesch-Kincaid Grade Level.
Avoid changing the button text here to improve your score. “Check Availability,” in the booking section should not be renamed to “Find a room” as this gives an easy phrase to read, but there is no such button.
To calculate the desired number for the office, please check the readability of your editable document before exporting into PDF. Include headings and button text in the analysis to find the reading ease score. If you only include paragraph text in the analysis, you may receive a slightly different result.
If you wish to improve this score, edit the text around the labels. In the example above, change “In order to determine whether the room is available, click Check Availability.” to “Click Check Availability”. Re-analyse the document. By reducing the length of the sentence, we have improved the score without making the user unsure of which button to click.
Do not include internal booking links in this document. If the leaflet is to be available to the public, simply use the browser tool. If there are staff only booking links/door codes in this leaflet, complete the readability test using the approved editing software within the office.
By replacing information with “[link]” in this leaflet, you will get a different score. Be careful with short instructions. To get the correct score, copy the editable version of the leaflet (with the exact text) and run the Flesch Readability test on this version.
If this is routinely checked within the office, find out which tool they use. In your email you can write “Flesch Reading Ease: [score], checked with [tool]”. This means that if it gets rewritten in the future, the person rewriting it can easily check the readability score using the same tool.
Be careful when using short bullet points with this metric. As the calculation depends upon average sentence length and average number of syllables in words, short bullets may cause a very high (due to short sentences) or an unusually low (due to words such as availability and confirmation having many syllables) result. If you find that this score seems unusual compared to a regular block of text, don’t be concerned, it is due to the style of the text!
@0xdrone9 is right that headings and button labels shift the result, and I’d take that further. A bulleted procedure counts every line as its own fragment, which inflates the ease score in a way that doesn’t really reflect readability. If your office cares about the number matching the actual document, keep the analysis consistent with whatever they’ll re-check later, bullets and all, rather than cleaning it up into tidy sentences first.
Once done, simply copy and paste the editable text into the Clever Humanizer Readability Checker. Be careful however with numbers/ codes. If you have a room number, or a date in there, this will be interpreted as a single long word, and may affect your results. Remove any numbers or codes to improve your score.
On such a short piece (single page), do not worry too much about getting a certain score. Just state the score and method that you used. If you want to increase it, then reducing the length of the 2 longest sentences in the text will help most.
Leave the room numbers in. The office wants a score for the handout people will read, not for a version with the room numbers missing.
If the editable copy is in Word for Microsoft 365, open it and look under Home > Editor > Document stats. Use the number labeled “Flesch Reading Ease” in the statistics window. You can leave the PDF alone.
If Document stats is missing in Word for Windows, go to File > Options > Proofing. Turn on “Check grammar with spelling” and “Show readability statistics,” then run the spelling and grammar check. The score appears at the end. You can ignore suggested edits rather than change a finished handout just to see the number.
