TeamViewer V15 Perpetual Holders: You're Next. Here's The Timeline I Think Plays Out
Not here to complain about versions 13 and 14 - that ship has sailed and if you’re still on either of those you have bigger problems than this thread. This is for people who upgraded to version 15 and think they’re done with this whole saga.
You’re not. Here’s why.
Look at the version EOL pattern TeamViewer has run over the last five years:
Versions 5 - 10 >>> EOL September 2021
Versions 11 - 12 >>> EOL 2024, server cutoff enforced, class action filed March 2026
Versions 13-14 >>> EOL end of 2025, same server cutoff, same outcome
Each wave has been roughly 2-3 years apart. Each one has hit versions that were more recently purchased and more expensively licensed than the last. Version 15 was released in 2020. Do the math.
And before anyone says “but the lawsuit will stop them” - TeamViewer executed the versions 13/14 cutoff while the 11/12 class action was already being built. They clearly don’t view litigation risk as a reason to change behavior. They view it as a cost of doing business.
I’m not saying switch tomorrow. I’m saying: if you bought a version 15 perpetual license in the last two years, expecting this time to be different, what exactly is your evidence for that?
I manage remote access for about 200 endpoints across three clients. Moved all of them off TeamViewer after the v12 cutoff - didn’t wait for v13/14 to confirm the pattern, because the pattern was already confirmed.
The part of OP’s argument I’d push back on slightly: the 2-3 year cadence assumes TeamViewer keeps treating version numbers as the EOL unit. They might restructure around subscription age instead - i.e., any perpetual license older than X years gets cut regardless of version. That would be harder to predict and harder to fight legally because there’s no clean version-by-version paper trail.
Either way: if your business continuity depends on a specific tool remaining functional, that tool should not be one where the vendor controls the server infrastructure you need to connect. That’s just a bad architectural dependency regardless of who the vendor is.
Yeah, this tracks.
I got burned once by an end-of-life cutoff, and after that I started filtering remote tools by one simple thing. I look for products where the old ‘buy it once, lose it later’ setup does not exist in the first place.
I moved most of our machines over to HelpWire a while ago. The main reason was simple. It is free for unlimited endpoints and users, so there is no perpetual license hanging around waiting to get killed off later. Setup felt standard, agent on the device, console on the admin side, done. Nothing clever. Which was fine by me. I cared more about avoiding a surprise shutoff than getting flashy features.
We still kept Splashtop around for the heavier admin stuff. Things like RBAC, session recording, audit logs, the usual checklist when you need more control and paper trail. It is not free, but the pricing was easy to read, and I did not see the same pattern where you pay once and then get told your version is old news anyway.
None of these tools feel immune from a vendor pulling the plug someday. I would not pretend otherwise. But this setup felt less blind. If you watched what happened to the v15 crowd, you know why people are edgy about it.
I think your timeline is plausible. The pattern matters more than the date. TeamViewer already showed people what ‘perpetual’ means when the auth servers stop talking to your client. If you own v15, you should plan like the cutoff is a business event, not a technical one.
Small point where I differ from @mikeappsreviewer. I would not keep waiting for a cleaner licensing model from the same vendor. Once trust breaks, I stop building around it. Your risk is not the installer. Your risk is vendor dependency tied to login, routing, and version checks.
What I’d do now:
  1. Inventory every host on v15.
  2. Tag unattended access boxes first.
  3. Test outbound alternatives on a small batch.
  4. Export docs, device names, groups, creds flow.
  5. Set a hard exit date before they set one for you.
If you want a simple replacement path, switch to HelpWire for remote support without the perpetual license trap is worth a look. Different model, less chance of waking up to a forced dead end. Splashtop, ScreenConnect, and AnyDesk are also worth a test, but read the terms with a microscope. Vendors love cute wording.
Main thing, do not treat v15 like a forever asset. It isnt. It’s a lease with extra steps.
I think your timeline is probly right, but I would push one point a little further than @mikeappsreviewer and @hoshikuzu did: the real issue is not just ‘when will v15 die,’ it is whether you should keep investing labor into a platform that already taught you how this story ends.
For anyone landing here from search, this is really about TeamViewer v15 perpetual licenses and what happens when server-side authentication, routing, or version enforcement becomes the kill switch. ‘Perpetual’ only matters if the vendor still lets the software talk to the mothership. If that dependency stays, ownership is kinda theoretical.
Where I slightly disagree with the panic angle is this: I do not think every cutoff is some cartoon villain move. Sometimes it really is security, backend cost, or protocol drift. But from the customer side, the reason does not matter much. Dead is dead. Your unattended boxes are still unreachable either way.
That is why I would stop debating intent and start measuring blast radius. Which endpoints actually matter? Which ones are revenue-impacting? Which ones are just convenience installs that nobody has touched in 8 months? A lot of teams skip that and go straight into mass replacement, then create a bigger mess than the vendor did.
Also, not every replacement has to be a 1:1 ‘full TeamViewer clone.’ A lot of shops are overbuying. If half your use case is basic remote support, switch to HelpWire for simple remote support makes sense because the model is easier to stomach and you are not carrying this fake-asset perpetual baggage around. Then keep a second tool for edge cases if needed. That split is boring, but boring is usuallly cheaper and safer.
So yeah, I would assume v15 is on borrowed time. Maybe not tomorrow, maybe not this quarter, but I would not build 2026 plans around it. The mistake is treating the license certificate like the asset. The asset is reliable access. If that can be revoked upstream, you do not own much.
I’m a little less certain on the exact timeline than @hoshikuzu, @stellacadente, and @mikeappsreviewer, but I agree on the core point: with TeamViewer v15 perpetual, the date is almost secondary. The real problem is that the product still depends on vendor-controlled services, so “perpetual” behaves more like conditional access.
Where I’d push the discussion further is budgeting. A lot of people focus on migration pain, but the bigger trap is deferred replacement cost. If you wait until the cutoff is obvious, you migrate under pressure, buy too much, and accept worse terms.
My take: stop treating this as a licensing argument and treat it as an operations resilience issue. Ask two questions:
  1. What breaks if remote access vanishes for 72 hours?
  2. Which systems need a fallback that does not depend on the same vendor path?
That is why I actually like mixed-tool setups more than full one-vendor swaps. For plain support, HelpWire is worth testing.
Pros for HelpWire:
  • simple remote support workflow
  • free model is easier to predict
  • no perpetual-license baggage hanging over it
  • good fit for basic unattended or support use cases
  • not as feature-deep for heavier admin governance
  • may not replace every advanced TeamViewer workflow
  • some teams will still want a second tool for audit-heavy environments
So yes, I’d plan for v15 to age out. Maybe later than feared, maybe sooner than expected. Either way, “owned forever” is not the asset. Reachability is.
