Recover data from flash drive on Mac?
I accidentally deleted important files from my flash drive while using my Mac. Is there any way to recover them? The data is crucial for an upcoming project, and I’m really worried. Please help!
Yo, been there! Losing important data can feel like the end of the world. But don’t freak out just yet. There’s hope. Here’s a quick lowdown on what you can try:
  1. Check Trash Bin: Sometimes, the deleted files might still be recoverable from the Trash Bin. Just have a look in there first.
  2. Disk Drill: This is a lifesaver! It’s a powerful data recovery tool specifically designed to help you recover lost files from flash drives and other devices. It works perfectly on Mac, and its interface is pretty user-friendly.
  3. Time Machine: If your flash drive was backed up using Time Machine, you could restore it easily. Just connect the drive and enter Time Machine to roll back to a time when the files were still there.
  4. Terminal Command: If you’re feeling adventurous and are comfortable with some command-line action, you could try using the testdisk command. It’s a bit technical but can be very effective.
  5. Professional Help: If those files are super crucial and nothing seems to work, consider reaching out to a data recovery specialist. It might cost you, but it’s worth it if the data is that important!
And remember, for the future, maybe consider keeping regular backups to avoid this heart-stopping moment again. :floppy_disk: Keep calm and restore on!
Alright, here’s my 2 cents. You got some solid advice from @yozora, but let’s throw in a couple more tools and tricks just in case.
  1. PhotoRec: If you’re into open-source software, have a look at PhotoRec. It’s free and can recover a variety of file types from your flash drive. It might not have the sexy interface, but it’s powerful under the hood.
  2. Disk Utility: Before diving into third-party apps, try using your Mac’s built-in Disk Utility to see if the drive itself has any errors. Sometimes repairing the drive can magically unearth missing files. Open Disk Utility, select your flash drive, and click ‘First Aid.’
  3. Recoverit: Another tool to consider is Recoverit. Similar to Disk Drill but sometimes has luck where others don’t. Again, it’s user-friendly and quite efficient.
  4. Shadow Copies: Macs don’t use the term “shadow copies,” but sometimes older versions of files can be found if you use software like Mac Data Recovery Guru.
  5. Carbon Copy Cloner: If you had cloned your flash drive to another drive using this tool, restoration is pretty straightforward. No clone? Make it a habit for the future.
Just a quick note on Disk Drill mentioned before: Not only is it very easy to use, but it also supports a myriad of file formats and devices, making it a go-to for many when recovering lost files. For more info, you can check out Disk Drill.
And yo, don’t beat yourself up too much about not having backups. Even the best of us screw up and forget. From here on, just keep multiple copies of crucial files. Hang in there; you got this! :muscle:t3:
Alright, let’s get into it. Here are some additional approaches you might want to consider:
Step-by-Step Recovery Tactics
1. PhotoRec:
  • Pros: Free, powerful, open-source.
  • Cons: Interface isn’t pretty, can be a bit technical.
2. Disk Utility:
  • Pros: Built-in tool, no need for downloads.
  • Cons: Might not be sufficient if data is deeply corrupted.
3. Recoverit:
  • Pros: User-friendly, efficient.
  • Cons: Can be pricey, not always 100% effective.
Command-Line Wizards
4. TestDisk via Terminal:
  • Pros: Very effective, free.
  • Cons: Requires technical know-how, not for the faint-hearted.
Going Deeper with Disk Drill
Disk Drill:
  • Pros: User-friendly, supports many file formats, small learning curve.
  • Cons: Not free for full functionality, can be overkill for minor recoveries.
I see @vrijheidsvogel and @yozora already touched on Disk Drill and Time Machine, which are fantastic tools. But let’s not forget that PhotoRec and Disk Utility might also save the day depending on your comfort level with technology.
For maximum effectiveness:
  • Start with the simple checks like the Trash Bin and Disk Utility’s ‘First Aid.’
  • Move on to more powerful tools like Disk Drill or Recoverit if the simple steps don’t work.
  • As a last resort, head to the terminal for some testdisk magic if you’re feeling brave.
Remember, sometimes recovering data is a balancing act between ease of use, cost, and effectiveness. Stay calm and rally through these options one by one.
Hey folks, just jumping in since I’ve seen a couple people mention TestDisk here. Just want to give a heads-up that TestDisk isn’t really the right tool if you’re trying to recover deleted files from a flash drive on a Mac.
Yes, technically it has an undelete function, but it’s super limited. Anyone who’s actually tried using TestDisk specifically to recover deleted files will tell you that it’s just not built for that.
To clarify: TestDisk is amazing when you’re dealing with partition table issues, like accidentally deleted partitions or raw ddrives. But for standard deleted file recovery? It’s just not the right match, especially on macOS. If you’re leaning toward open-source options, go with PhotoRec instead. It’s actually part of the same project as TestDisk (same download), but it’s designed to scan the raw data and recover files based on signatures. It doesn’t care about the file system, so even if the file system is totally gone PhotoRec can still pull usable files, though you’ll lose original file names and structure.
Hope that clears up the difference!
EDIT: Also a quick word on Disk Utility, since a few folks mentioned it – it’s decent for checking if the drive is okay using the First Aid. But in terms of actually recovering deleted files? I’ve never seen it help there. If anything, running repairs might make things worse if data’s still recoverable, so I’d recommend running a recovery app first.
I’ll back up what @Yozora said, Disk Drill is the best shot you’ve got if you’re trying to recover deleted files from a USB drive on a Mac. I had a similar situation a couple of months ago. I deleted a whole folder of contracts from a SanDisk flash drive without realizing it and I didnt notice until a few days later. Panic mode obviously.
I tried a couple of free tools first (PhotoRec included) but it was kind of a mess. Tons of random files with no names/structure. Then I gave Disk Drill a shot. The scan took a while, but it pulled up almost everything, and I could preview the files before restoring, which helped a ton. Definitely worth the license in my case.
I also remember reading somewhere that it’s a good idea to use the Byte-to-byte backup feature first to make a copy of the flash drive and scan that instead of the original, supposedly better way. I didn’t do that myself, and it still worked fine, but maybe that’s the “proper” way to do it, especially if the files are mission-critical. Just something to consider if you’re about to start scanning.
@Zack that Byte-to-Byte backup thing is not the “proper” way in the sense that it’s required every time. It’s more of a safer method, especially when you’re dealing with storage that’s acting weird or showing signs of failure.
What it does is create a full, sector-by-sector copy of your flash drive as a disk image. Then, instead of scanning the physical drive (which might get worse with each access), you scan the image file. That way, you’re preserving the current state of the drive and avoiding wear or further corruption.
That said, for cases like @silverfox described (accidental file deletion on a healthy USB drive) it’s usually fine to scan the drive directly, especially if you haven’t written new data to it. I’ve done it both ways with Disk Drill. If the drive seems solid and the deleted data’s recent, you’ll often get great results without the extra step.
here’s what really matters in this type of situation: did you keep using the USB drive after deleting the files That’s the real make-or-break. When files get deleted, the data usually isn’t actually wiped right away on flash drives -it just gets marked as ““free to use” and anything new you copy to the drive can overwrit it. So if you added new files or even let the system write some hidden metadata there’s a good chance those deleted files are now partially or fully gone.
@silverfox I had literally the same thing happen with my thumb drive last week. I accidentally deleted a bunch of photos &videos while cleaning up space….and didn’t even realize it until couple days later.
First thing I tried was EaseUS Recovery, I’d seen it mentioned in a few places. It ran fast, found some stuff but not the files I actually needed. A lot of random files showed up, but none of the specific videos or photos I was missing. Same deal with Recoverit. Gave that a try too hoping it would dig a little deeper, but nope same results. found some generic files but not what I was looking for. Not sure if it’s the tools or I was just too late.
Either way figured I’d mention these in case someone else wants to give them a go. Maybe you’ll have better luck.
omg @Alice same exact situation here, mac user btw so my options already feel more limited than windows people. i tried a couple tools too with mixed results.
one thing that actually worked decent for me was Disk Drill (someone mentioned it above) but i also stumbled on a comparison site that listed a bunch of options specifically for flash drives - helped me figure out which ones actually support mac before wasting time downloading stuff that doesnt even work on my system
the point about not writing new data is SO real tho. i made that mistake the first time this happened to me years ago, kept using the drive thinking i could just “undo” the delete somehow :sob: learned my lesson the hard way
@Xavier quick question - when you do that byte-to-byte image thing on mac, what do you use for it? like does Disk Drill handle that part too or do you need a separate tool for creating the image first? asking bc my drive has been a little glitchy lately and sounds like thats exactly my situation
