Need help with my Dell Pro 16 Plus PB16250
My Dell Pro 16 Plus PB16250 has started acting up, and I’m trying to figure out what went wrong. It was working fine, then suddenly began having issues, and I need help troubleshooting so I can get it back to normal. Looking for advice from anyone familiar with Dell Pro 16 Plus PB16250 problems and fixes.
Start with the basics, because random laptop issues usually fall into 4 buckets. Power, heat, storage, or driver/BIOS trouble.
Check this stuff first.
  1. Run Dell ePSA diagnostics.
    Shut it down.
    Power it on and tap F12.
    Pick Diagnostics.
    If it throws an error code, post it. Dell codes are useful and save time.
  2. Watch temps and fan behavior.
    If it gets hot, slows down, or shuts off, check vents and fans.
    Use Dell SupportAssist or HWInfo.
    CPU temps over 95C under light use are bad. That points to cooling.
  3. Check SSD health.
    If it freezes, hangs on boot, or apps take forever, look at the drive.
    Use CrystalDiskInfo.
    If health shows Caution or bad SMART values, back up your stuff fast.
  4. Rule out Windows corruption.
    Open Command Prompt as admin.
    Run:
    sfc /scannow
    then
    DISM /Online /Cleanup-Image /RestoreHealth
  5. Update BIOS and chipset from Dell’s support page for the PB16250.
    Do not grab random driver packs.
    BIOS bugs cause weird sleep, battery, and USB issues alot more than people think.
  6. Test RAM.
    Windows Memory Diagnostic works, MemTest86 is better.
    Bad RAM causes random blue screens and app crashes.
If you post the exact symptoms, like no boot, black screen, fan noise, BSOD, battery drain, WiFi drops, people here cn narrow it down fast.
If it was ‘fine and then suddenly weird,’ I’d also look at what changed right before it started. That can matter more than shotgun-testing everything. @voyageurdubois covered the hardware basics pretty well, but I wouldn’t jump straight to assuming heat or SSD unless you’re seeing classic signs.
A few things I’d check that are diff:
  • Event Viewer and Reliability Monitor
    Search for Reliability History in Windows. It gives a way cleaner timeline of crashes, driver failures, update installs, app hangs, etc. If this started after a Windows update or Dell utility update, it’ll usually show up there.
  • Safe Mode test
    If the laptop behaves normally in Safe Mode, that points more toward drivers, startup apps, or background junk, not failing hardware.
  • Clean boot
    Disable non-Microsoft startup items/services and reboot. A lot of “random acting up” cases end up being some dumb background process.
  • Power adapter / battery behavior
    Dell laptops get super annoying if the charger isn’t recognized properly. Then they throttle hard and act broken even when they sorta work. Check BIOS on boot and see if AC adapter wattage is detected corectly.
  • External stuff
    Unplug docks, USB devices, SD cards, monitors, all of it. Bad peripherals cause bizarre boot/sleep/USB issues way more often than ppl think.
  • Windows update rollback
    If the timing lines up, uninstall the most recent quality update and test.
Post the exact symptoms. Slow? freezing? black screen? not charging? random restarts? That changes the whole answer tbh.
I’d add one angle @voyageurdubois did not really hit: Dell-specific firmware weirdness.
For a Dell Pro 16 Plus PB16250, sudden “acting up” can come from:
  • BIOS update gone half-wrong
  • Intel graphics/chipset driver mismatch
  • Dell Optimizer / MyDell utility conflicts
  • Modern Standby sleep bugs
What I’d do:
  1. Run Dell preboot diagnostics
    Tap F12 at startup, choose Diagnostics. If that throws memory, SSD, fan, or battery errors, stop chasing Windows.
  2. Check BIOS defaults
    Enter BIOS, load defaults, save, reboot. Sometimes one bad power or thermal setting causes chaos.
  3. Test without Dell extras
    I actually would uninstall Dell Optimizer first if symptoms are lag, fan spikes, wake issues, or weird power behavior. It helps some systems, but it can also cause nonsense.
  4. Device Manager check
    Look for hidden warning icons under Display adapters, System devices, Storage controllers.
  5. Create a new Windows user account
    If the problem only happens on your normal profile, that points to profile corruption, not hardware.
Pros of the ‘’: likely solid screen/build and good business features.
Cons of the ‘’: Dell software stack can get bloated, and firmware/driver interactions can be annoyingly sensitive.
If you post the exact symptom pattern, people can narrow it down fast.
