Need help with iPhone 16 Pro Max screen replacement
I dropped my iPhone 16 Pro Max, and the screen is now badly cracked and hard to use. I need help figuring out the best screen replacement options, including repair cost, whether to use Apple or a local repair shop, and how to avoid damaging Face ID or other features.
If it’s an iPhone 16 Pro Max, I’d start with Apple first. Simple reason, you keep Face ID, True Tone, touch response, brightness, and water resistance in the best shape. Third party shops vary a lot. Some are fine. Some use cheap OLED panels with bad color, weak brightness, and higher battery drain.
Rough cost, expect Apple screen repair to land in the few hundred dollar range if you do not have AppleCare+. If you do have AppleCare+, it should be a lot less, usually the standard accidental damage fee. Check your coverage first. That changes the whole math.
Use a local shop only if:
  1. Apple is booked out too long.
  2. The price gap is big.
  3. The shop uses a quality OLED, not LCD.
  4. They give a written warranty.
Ask the local shop:
  1. Is it original pull, premium OLED, or LCD.
  2. Will True Tone still work.
  3. Will Face ID be affected.
  4. Do they reseal for water resistance.
  5. What is the warrnty length.
If the frame is bent from the drop, screen-only repair sometimes goes bad fast. Dead spots, lifting, light bleed. Have them inspect the frame first.
Back up your phone before repair. If the glass is hard to use, connect a mouse with an adapter or use voice control. Annoying, but it helps. Apple route costs more, but fewer headaches IMO.
If you want the least hassle, Apple is still the safer bet, but I’d push back a little on the idea that local = risky by default. A really solid independent shop can be worth it if they do microsoldering and actually calibrate parts instead of just slapping in a panel and sending you out the door.
Big thing people forget: check whether it’s only the front glass/display or if the housing took a hit too. On big phones like the Pro Max, a twisted frame can make a new screen fail early. Also test the rear cameras after a drop. Sometimes the impact that cracks the screen also messes with OIS/focus and then the “screen repair” bill turns into a much bigger one.
Price-wise, without AppleCare+ you’re probably looking at “annoying enough to make you mad” money. With AppleCare+, way less painful. If the phone is older than a return window and repair cost gets too close to trade-in replacement math, compare both before spending anything. That’s the part people skip.
I do agree with @techchizkid on backing it up first, but I’d add this: if the display is glitching, stop using it as much as possible. A damaged OLED can get worse fast and ghost touch can lock you out. If needed, use Quick Start with another iPhone or hook it to a computer ASAP.
My checklist would be:
  1. Check AppleCare+ coverage
  2. Inspect frame and cameras, not just screen
  3. Compare Apple repair vs local shop vs carrier insurance claim
  4. If local, ask if they can preserve brightness behavior and sensor function, not just “does it turn on”
  5. Get repair notes in writing
If it were mine and the phone is otherwise mint, I’d probly pay more and do Apple. If it already has dents/scuffs and you just need it usable again, a reputable local shop can be totally fine.
I’d split it by what you care about most:
Apple repair
  • Pros for the ': OEM parts, Face ID and True Tone are least likely to get weird, better resale confidence, easier if you later need warranty help.
  • Cons for the ': usually the highest price, and Apple may flag extra damage and raise the total.
Good independent shop
  • Pros for the ': cheaper, faster, sometimes same day, more flexible if only the display stack needs work.
  • Cons for the ': quality swings a lot, some shops use softer OLEDs or lower-brightness panels, water resistance usually becomes a maybe.
I slightly disagree with @techchizkid on one thing: local repair is not just for beat-up phones. A top-tier shop can absolutely be the smart choice even on a clean Pro Max, if they warranty the screen and can prove they keep brightness, proximity sensor behavior, and refresh rate performance normal.
One thing I’d add that often gets missed: watch battery health and heat after the drop. On a hard impact, a screen crack can distract from a battery that got stressed. If the phone starts heating near the display edge, swelling, or draining fast, stop there and treat it as more than a screen job.
My rule:
  • AppleCare+: go Apple
  • No AppleCare+, resale matters: probably Apple
  • No AppleCare+, keeping phone 2 to 3 years, trusted local quote is much lower: local can make sense
Also ask both places this exact question: “If the touchscreen, Face ID, or front sensor acts up after replacement, what is covered and for how long?”
That answer tells you a lot more than the price does.
A simpler option is to replace the whole phone instead of repairing the screen.
Back up your iPhone first. Get quotes from certified refurbished sellers, then compare the final cost against screen repair. Sell your cracked phone to a parts buyer or trade-in service. This often saves time if the frame, battery, or cameras also took damage.
Choose a replacement with a return window and warrenty. Keep the reciept. Transfer your data, test Face ID and cameras, then erase the damaged phone before selling it.
Nobody’s flagged that ‘go to Apple’ only works cleanly if you actually live near an Apple Store. If you don’t, Apple repair means mail-in, and you’re without a phone for several days while it ships both ways. For a lot of people that alone tips the decision toward a local shop, regardless of part quality.
On the numbers everyone’s been vague about: out of pocket, an iPhone 16 Pro Max screen through Apple runs somewhere in the high three hundreds from what I’ve seen. With AppleCare+ the accidental damage fee for screen only is tiny by comparison, around thirty bucks. That gap is the whole ballgame, so @techchizkid and @caminantenocturno are right to say check coverage first, but confirm the exact fee in your Settings under the device, not from memory.
Where I’d push back a little on the ‘just replace the whole phone’ idea from @fuzzy_mega_hacker. That math only works if the frame or cameras are genuinely damaged too. If it’s purely a cracked front glass on an otherwise clean phone, buying a refurb and selling a cracked one usually loses you money once you factor in the depreciation hit on a phone with a broken screen. Trade-in values on cracked flagships are brutal. Fix first, replace only if the inspection turns up more.
One practical thing before you hand it over anywhere: Apple pairs the display to the phone now, so a genuine screen keeps True Tone and auto-brightness working properly. A local shop using a third-party panel may throw a ‘unable to verify genuine part’ notice even when everything functions. Ask them directly whether you’ll get that warning, because it doesn’t break the phone but it annoys people and it can matter for resale.
If your touch still works even partially, back up over Wi-Fi to iCloud or plug into a computer tonight. Don’t wait for the repair appointment. Cracked OLEDs can go from usable to black or ghost-touching with no warning, and then your backup window is gone.
