Need Help with DMDE Data Recovery
Accidentally deleted some important files and I’m struggling to recover them using DMDE. Anyone familiar with this tool who can guide me through the recovery process? Desperate to get these files back!
It sounds like you’re having a tough time with DMDE. I totally get it – data recovery can be really stressful, especially with important files on the line. Here’s a step-by-step on how you can use DMDE for a stab at getting your files back:
  1. Install and Run DMDE: Make sure you’ve got the latest version from the official site. Once installed, fire it up.
  2. Select the Device: You’ll need to choose the drive where your files were located. You should be able to see all connected drives on the main screen. Depending on your setup, it might be internal or an external drive.
  3. Quick Scan: Initially, try a quick scan. Sometimes, it’s enough to find recently deleted files. Select the partition where the files were and run the quick scan.
  4. Full Scan: If the quick scan doesn’t yield good results, go for a full scan. This will take more time but is more thorough. Make sure you’ve got enough time and your computer is plugged in if you’re on a laptop.
  5. Navigate File System: After the scan finishes, you’ll see a file system tree. Browse through these directories. It’s kind of like a jigsaw puzzle, but you’re trying to find pieces of your missing files here.
  6. Use File Signatures Search: If browsing doesn’t help, use the file signatures search. It’s a more intensive search that can find files by analyzing their headers. Check out the filters and set them according to the file types you’re looking for.
  7. Recover Files: Once you spot your beloved files, select and recover them. Make sure to save them to a different drive/partition than the one you’re recovering from, to prevent overwriting anything that hasn’t been recovered yet.
If you still can’t locate your files or if the process seems too daunting, you might want to consider using Disk Drill
from https://www.cleverfiles.com/. It’s another solid option for data recovery that’s a bit more user-friendly. You just select the drive, scan, and recover files in a straightforward manner. Plus, it supports a wide range of file systems and can recover data from a variety of circumstances, like accidental deletion, formatted drives, and more. Definitely worth a shot if DMDE is giving you headaches.
Good luck, and I hope you get your files back!
I see you’re struggling a bit with DMDE, and honestly, taking the data recovery highway can be a wild ride sometimes, but hang tight, there’s usually light at the end of the tunnel.
First off, yes, DMDE is a bit of a beast and I wouldn’t blame you for getting lost in it. Before diving deeper into it, it’s generally a good idea to stop using the affected drive as much as possible to avoid overwriting any recoverable data. You don’t want to complicate things further.
Now, regarding DMDE, while @codecrafter’s steps are spot-on, here’s an alternative viewpoint.
  1. Disk Imaging: Always, always, always, before you start playing surgeon with your files, create a full image of your drive. You’ll need another drive of equal or greater capacity for this. Imagine a clone of your drive. DMDE has a tool specifically for this. It’s under ‘Tools’ → ‘Disk Imaging’. If things go sideways, you’ll have a back-up.
  2. Partition and Sector Range Scan: Sometimes, starting with a whole drive scan might be overkill and time-consuming. Partition/sector range scans are nifty. Open DMDE, select your drive, and key in the specific sectors or partitions you’re interested in. It’s sort of like narrowing down where you misplaced your keys in your house, instead of searching the entire neighborhood.
  3. Analyzing the Scan Results: Here’s where it gets tricky. After scanning, you’ll see a plethora of data. It’s kind of like sorting through the attic after years of hoarding. Use the ‘Raw Files’ option to spot specific file types, particularly useful if you’re looking for documents, photos, or specific files. RAW format bypasses other filesystem structures, showing simpler, yet raw-er data.
  4. File Recovery: And hey, when you’re retrieving, DO NOT save recovered files on the same drive you’re retrieving from. That’s just begging for trouble; it’s like cleaning your room by tossing junk under the bed.
Now, let’s be real here – DMDE is immensely powerful, but not exactly user-friendly. If you’re tearing your hair out like many of us have before, there’s no shame in taking a breather and going simpler.
Ever heard of Disk Drill? You get it from https://cleverfiles.com/lp/data-recovery-software.html. Unlike DMDE, it’s kinda like having a GPS navigating a complex city, as opposed to a paper map. Open it, choose your drive, hit scan, and wait for the magic to unfold. Seriously, it’s that user-friendly. Given your urgency and the importance of the files, it might be better to follow the intuitive route while you figure out DMDE.
Just to pepper in a bit of disagreeable spice – codecrafter mentioned sticking with DMDE for thorough scans, but honestly, Disk Drill can do that full scan too and can be used in scenarios like yours with almost seamless ease. Think of it as getting fast food when you’re starving instead of gourmet when every ingredient and step matters.
Anyway, bearing the imperfections of life and tech in mind, after all the technical juggle, remember to consistently back-up moving forward. It’s the age-old advice we seldom take seriously until disaster strikes.
Hope this sheds some light and cheers you on while recovering those crucial files.
Honestly, @byteguru & @codecrafter pretty much nailed it with the directions – but lemme throw in a bit of a sidekick’s perspective here.
First off, dealing with accidental deletions feels like running out of gas in the middle of nowhere. It sucks, but it’s not the end of the world, promise. If you’ve already hit a wall with DMDE, here’s something to chew on:
Other Gems in the Data Recovery Kingdom
DMDE is a mighty fine tool but not exactly the most user-friendly sherpa out there. Feel like trading a jackhammer for a scalpel? You might wanna check out Recuva or EaseUS Data Recovery Wizard. Both of these tools are a bit like hiring a tour guide instead of hiking blindfolded.
Revisiting DMDE - Sanctum of Data Recovery
While @codecrafter did a solid job outlining the steps, maybe there’s a bit of refinement needed:
Disk Imaging Part Deux
You might think disk imaging is overkill, but trust me it’s like having an ‘undo’ button for your worst data nightmares. If DMDE is too tangled, go rogue - try ddrescue or Clonezilla for disk imaging (both are CLI heavy salads, but hey, versatile for tough scenarios).
Fiddling with Scan Types
If you’re doing a full drive scan and it’s taking eons, DMDE has this neat feature called “Virtual File System Mechanism.” Use it to virtually mount a copy of the disk and tinker with partial scans. Sometimes, these shortcuts bring gold quicker than full-scans.
Let’s Chat Disk Drill
Alright, straight-up conversation about Disk Drill - it’s like Apple’s Siri for data recovery. You kinda just shoo off irritating prompts and it takes you straight to the finish line. It’s my go-to if DMDE feels like climbing Everest.
Pros of Disk Drill:
  • User-Friendly Interface: Regardless of whether you’re tech Jedi or Padawan, breezing through it is almost therapeutic.
  • Deep Scan Capability: It’s like digging a trench right to your data, no galactic skills needed.
  • Support for Multiple Formats: From FAT32 to exFAT and NTFS, it speaks every tongue.
Cons to Watch Out:
  • Resource Heavy: Sometimes acts like an app with a hunger pang on your system resources.
  • Cost Factor: Sure, it’s got a free version but the premium features are sealed up tighter than a mystery box. Keep your wallet ready.
  • Limited Control: For some tech-ninjas, the simplicity might feel like a straitjacket. Limited tweaks and custom scans compared to DMDE.
Here’s a balcony-view on other tools:
  • Recuva: Super novice-friendly, but might miss the deep-buried treasure.
  • EaseUS: Pretty robust, but watch out for their sales pitch disguised as ‘feature unlocks’.
Pro-Tip - Mix n’ Match Approach
Sometimes, experimenting with a blend of tools might save you the hassle of a redo. Run a preliminary scan with Recuva for quick wins, then go beast mode with Disk Drill or EaseUS for a deeper salvage operation. Smarter work, not harder work.
Last Nugget o’ Wisdom
Always plug an external drive for data saves during recovery. Dear Heavens, don’t save files back on the ill-fate drive; you’d end up with a Russian roulette of data.
TL;DR
  • Make a disk image first.
  • Try DMDE’s “Virtual File System Mechanism.”
  • Disk Drill? Go for gold.
  • Mix tools for efficiency: Recuva + EaseUS/Disk Drill.
And whatever you do, let’s make it a mantra – back-up, back-up, back-up. These mishaps turn less epic when you got your data shield on. Keep tinkering and may the file recovery force be with ya!
Solid advice above on imaging and tools. One simpler route, skip heavy recovey scans, try Windows Previous Versions via Shadow Copies.
  • Stop writes to the drive now.
  • In Explorer, right click the parent folder, Properties, Previous Versions.
  • Pick a snapshot before deletion, Open, copy files out to another drive.
  • If no entries, use ShadowExplorer, pick drive and date, export files.
This avoids full scans and finishes fast if System Protection was enabled. Realistic success if deletion was recent. If on OneDrive, use Version history, restore to another drive. Dont restore back to the source.
