Need help with AI image-to-video description generation
I’m trying to automatically generate accurate, detailed descriptions for videos created from AI-generated images, but my current setup either misses important visual details or produces very generic text. I need advice on tools, workflows, or models that can reliably analyze these image-based videos and output rich, SEO-friendly descriptions that still sound natural. What approaches or best practices should I try to get better results?
You are fighting two things at once: vision quality and language quality. Treat them as separate steps.
Here is a setup that works decently for AI-image-to-video descriptions:
  1. Generate dense visual tags first
    Use a vision model to output structured info, not prose.
Prompt example to a vision model for each frame or keyframe:
  • Objects: list main objects with attributes
  • People: age, gender-presenting, clothing, pose
  • Scene: location, time of day, lighting
  • Style: 3d render, anime, watercolor, etc
  • Emotions: facial expressions, mood words
  • Actions: verbs, even simple ones like “walking, looking left”
  • Text in image: OCR result if any
Store it as JSON like:
‘objects’: [‘red sports car’, ‘wet asphalt road’],
‘scene’: ‘night city street, rain, neon lights’,
‘style’: ‘cinematic, 16:9’,
‘emotion’: ‘tense, dramatic’,
‘action’: ‘camera slowly moves forward’
Do this for:
  • First frame
  • 1 or 2 middle frames
  • Last frame
For short AI videos, 3 to 5 keyframes is enough.
  1. Track changes across frames
    Your text gets generic because it ignores change over time.
Simple heuristic:
  • Compare object lists across frames
    • If new object appears, add “a [thing] enters the scene”
    • If object disappears, add “the [thing] fades out”
  • Compare scene descriptors
    • “day” to “night” → mention time shift
    • “wide shot” to “close up” → mention camera movement
  • Compare emotions
    • Neutral to happy → mention mood change
Build a timeline like:
t0: rainy neon city, empty street
t1: red car appears, headlights on
t2: camera moves closer, reflections stronger
t3: car stops, lights reflect on wet road
  1. Turn structure into a template, not freestyle text
    Do not ask the model “describe this nicely”. It drifts into generic fluff.
Use templates:
Short factual description:
“AI generated video. A [subject] in a [scene] with [style]. The camera [movement]. Over time, [key change 1] and [key change 2].”
Accessibility focused:
“From 0 to 3 seconds, [events]. From 3 to 6 seconds, [events]. Colors: [main colors]. Mood: [mood words].”
Example based on the JSON idea:
“At night in a neon lit city, a red sports car drives along a wet street. The camera moves forward toward the car. Reflections from signs spread across the road. The shot gets closer until the car fills the frame. The scene keeps a tense, cinematic mood.”
  1. Force “no detail left behind” in the prompt
    For the language step, pass in the JSON for all keyframes and be explicit:
“Write a single paragraph describing this AI generated video.
Rules:
  • Mention the main subject, background, lighting, camera movement, color palette, visual style.
  • Mention all important changes between frames.
  • Do not invent objects or events that are not listed.
  • Keep it under 80 words.
  • Use simple, direct language.”
The “do not invent” part matters a lot. It cuts hallucinated details.
  1. Add a tagging pass for search and reuse
    For each video, generate:
  • 10 to 20 tags: subject, style, mood, medium
  • 1 short title: “Neon Rain Street Drive”
    You can prompt:
    “From this JSON and description, output a comma separated list of 15 tags, from most specific to more general. No sentences.”
  1. If you want more accuracy, use two different models
  • One vision model for detection and attributes
  • One language model for description
    Vision models with object detection and segmentation pick more small details than a general model.
    Language models handle style and readability better.
  1. Evaluate your system instead of guessing
    Take 20 videos and score each description on:
  • Coverage: 0 to 5, how many visible elements are mentioned
  • Precision: 0 to 5, how many errors or hallucinations
  • Readability: 0 to 5, how easy it is to read
Tweak prompts until:
  • Coverage is at least 4
  • Precision is 4 or 5
  • Readability is 4 or 5
  1. If you use AI image generators, tap into their metadata
    If your images or videos come from prompts, save:
  • Original text prompt
  • Seed, style, model, aspect ratio
Use that as extra context:
“Use this generation prompt as context for subject and style. Do not copy the prompt. Only include details that are visible in the frames.”
  1. Minimal pipeline summary
  • Extract 3 to 5 keyframes
  • Vision model → structured JSON tags per frame
  • Compare frames to get timeline changes
  • Language model → short structured description based on strict rules
  • Optional second pass → tags and title
If you share what models you use now and how you prompt them, people here can help tighten that up.
Your core problem isn’t just “bad prompts,” it’s that you’re asking one model to:
  1. See everything,
  2. Reason over time,
  3. Write nicely,
    all in a single shot. That almost always turns into generic fluff.
@nachtdromer already nailed the “structured JSON + diff across keyframes” approach, so I’ll try not to rehash that. I’ll focus on how to squeeze better temporal + visual fidelity out of what you probably already have.
1. Stop treating every frame as equal
Most people either:
  • describe only the first frame, or
  • try to describe all frames and drown in noise.
Try this instead:
  • Auto-select “semantic keyframes” where something actually changes:
    • Big motion (optical flow spike)
    • Color shift (scene change)
    • Object set changes (new object appears / disappears)
  • Limit yourself to 4–7 key timestamps per clip.
Pipeline idea:
  1. Use ffmpeg to sample at 3–5 fps.
  2. Run a cheap feature extractor (even a CLIP embedding).
  3. Measure cosine distance between consecutive frames.
  4. Mark a keyframe where distance > threshold (tune per dataset).
Now you only describe what matters, but you’re not stuck with arbitrary first/middle/last.
2. Use two text passes, not one
I slightly disagree with stopping at one “nice” description. In practice, two passes works better:
Pass A: Hyper-literal timeline
Prompt something like:
Given these keyframes in order, write a bullet-point timeline.
Each bullet: “time ~Xs: [literal description, no style, no metaphors, no guesses].”
Only describe visible things: subjects, background, motion, camera movement, lighting changes, color changes.
Maximum 1 line per keyframe.
This keeps things ultra grounded and avoids hallucinations. You want something almost boring:
  • 0.0s: Red car on empty wet road, camera far, neon signs in distance
  • 1.2s: Camera closer, reflections brighter, car centered
  • 2.4s: Camera near front bumper, headlights fill frame
Pass B: Human-friendly paragraph
Then feed that timeline into a second LLM call:
Rewrite this bullet timeline as a single short paragraph.
You may combine related events, but do not add new elements that are not present.
Aim for a natural, cinematic-sounding description. Keep it under 80 words.
This split makes a huge difference. First pass = “truth.” Second pass = “style.”
3. Reduce “generic-ness” by adding constraints, not more adjectives
If your descriptions feel generic, chances are your prompts are too open like “describe this video in detail.”
Try constraints that force specificity:
  • Require at least 1 detail about:
    • Foreground subject
    • Background environment
    • Lighting
    • Dominant colors
    • Motion (subject or camera)
  • Hard limit on length to prevent rambling (50–80 words max).
  • Explicit anti-fluff rule:
Avoid vague words like “beautiful,” “stunning,” “amazing.” Prefer concrete visual nouns and verbs.
Example prompt snippet:
From the structured keyframe data and timeline, write 2 sentences.
Sentence 1: who/what is in the scene, where, and in what visual style.
Sentence 2: how the scene changes over time, including camera movement and any mood or lighting shifts.
No more than 50 words.
That reduces the probability that the model falls back to “a stunning cinematic shot of…”
4. Use “disagreement” prompts to catch missing details
One trick I almost never see mentioned:
  1. Generate your description.
  2. Ask the same LLM to critique it against the structured visual data.
Prompt:
Here is the video description and the frame-level data.
  1. List any important visual elements from the data that are missing in the description.
  2. List anything in the description that is not supported by the data.
  3. Rewrite the description to fix both issues.
This self-review pass often recovers stuff like:
  • “reflections on puddles”
  • “distant buildings in fog”
  • “subtle camera tilt”
It also kills off invented nonsense like birds that never existed.
5. Add one “style-aware” pass, but lock it down hard
Since these are AI-generated images, style consistency matters.
I partly disagree with ignoring style generation metadata if you already have it. That prompt is often more reliable about intent than a detector is about style.
However, do not let the model freely paraphrase the original prompt. Blend both:
You get:
  • Original generation prompt (context only, may mention invisible ideas).
  • Keyframe JSON (ground truth).
    Only include style/genre details that are clearly visible in the frames and are also consistent with the generation prompt. Do not include story or lore that is not visually present.
Example:
Prompt says “cyberpunk dystopian Tokyo alley with neon kanji signs, heavy rain, cinematic lighting, shallow depth of field.”
Frames clearly show:
  • Neon signs with unreadable text
  • Wet ground
  • Strong contrast lighting
  • Futuristic architecture
Valid to say: “cyberpunk-style neon alley under heavy rain”
Not valid to say: “Tokyo” or “kanji” unless actually legible.
6. If you care about accessibility, use a second “alt-text mode”
Your first description can be cinematic and compact.
Then run an “accessibility mode” derived from the same data:
Produce an accessibility-focused description for blind users.
  1. Use time segments (0–3s, 3–6s, etc.).
  2. Prioritize clear explanation of motion, positions, and relationships between objects.
  3. Avoid technical art jargon unless crucial.
  4. ~120 words maximum.
This gives you:
  • Short “marketing” description
  • Longer alt-text description
    from the same structured source.
7. Concrete minimal stack suggestion
If you want something you can actually build without going insane:
  1. Extract frames at 3–5 fps.
  2. Select semantic keyframes based on CLIP embedding distance.
  3. For each keyframe:
    • Vision model → structured JSON (objects, scene, style, people, etc.).
  4. Second pass:
    • LLM → bullet timeline (literal, no style).
  5. Third pass:
    • LLM → 1 short human-friendly description + 1 longer accessibility description.
  6. Optional fourth pass:
    • LLM → tags & title, but forced to stay within listed objects/styles.
Where I differ slightly from @nachtdromer is:
  • I like a strict literal “timeline text” layer between JSON and final prose.
  • I lean heavier on self-critique prompts to raise coverage & precision.
If you share:
  • Rough clip duration range
  • What models you’re using now (vision + text)
  • Whether you need these for UX, search, or accessibility
you can probably trim a few steps and avoid overengineering the whole thing.
You’re already thinking in the right “multi-pass” direction. I’ll add a different angle: treat this as a data & control problem, not just a prompt-engineering one.
1. Stop trusting the model’s eyeballs by default
Where I slightly disagree with @nachtdromer: relying heavily on frame → JSON → LLM inference can still drift. Vision models are noisy. Instead, build redundancy:
  • Run 2 lightweight vision passes per keyframe (for example, CLIP-style tags + a detector/segmenter).
  • Only keep objects / attributes that both passes broadly agree on.
  • Expose uncertainty: let attributes be “strong,” “medium,” “weak” instead of all-or-nothing. Your text model can be told: “only verbalize strong + medium facts.”
That alone cuts hallucinations a lot.
2. Force alignment between video dynamics and text
Most descriptions are static even when the clip isn’t. To fix that, structure your input like this before the LLM ever writes prose:
  'global_scene': {...},
  'entities': [
      'id': 'car_1',
      'type': 'vehicle',
      'attributes': { 'color': 'red' },
      'track': [
        {'t':0.0, 'x':0.1, 'y':0.5},
        {'t':1.0, 'x':0.3, 'y':0.5},
        {'t':2.0, 'x':0.6, 'y':0.5}
  'camera': {
    'motion': [
      {'t':0.0, 'zoom':'wide'},
      {'t':2.0, 'zoom':'close'}
Then prompt something like:
Describe each entity using how its position or size changes over time. Always mention at least one motion verb derived from the track (e.g. moves left, approaches, recedes, stays still).
This prevents the model from collapsing your clip into “a static shot of a red car.”
3. Use templates like a layout, not like generic boilerplate
To beat generic text, give the model a fixed layout where each sentence has a job. Example:
  1. Sentence 1: Who/what + setting + visual style.
  2. Sentence 2: Main subject’s motion or action across time.
  3. Sentence 3: Camera movement or framing changes.
  4. Optional sentence 4: Lighting/color/mood change.
Then explicitly block fluff:
If a slot has no information (e.g. no camera motion), skip that sentence instead of inventing details.
You end up with consistent, dense descriptions that still read naturally.
4. Separate “search text” from “human text”
People often try to make one perfect paragraph that serves:
  • UX reading
  • Search / retrieval
  • Accessibility
That is how you end up with vague soup.
Instead, build two outputs from the same structured data:
A. Retrieval-focused text
  • Single sentence or short paragraph.
  • Overweight nouns and adjectives.
  • Explicit labels like: “medium shot, low angle, cyberpunk city street, neon signage, wet asphalt, rainy night, blue and magenta highlights.”
B. Human-friendly narration
  • Short, polished, ~40–70 words.
  • Allowed to merge details and remove repetition.
You can even train your own search index only on the retrieval text and leave the pretty description for front-end display.
This is where a dedicated “AI image to video description generator” pipeline really behaves like a product, not a single LLM call.
Pros of this dual-output approach:
  • Better search quality
  • Cleaner UI copy
  • Easier to debug (you know which layer failed)
  • Two generations per clip
  • Slightly higher latency and cost
5. Borrow from captioning datasets, not from marketing copy
To avoid “stunning,” “beautiful,” “cinematic” spam, bias your prompts toward the style of MS-COCO / VideoCaption datasets:
  • Short, literal, compositional.
  • Strong on “who does what where,” weak on “this looks amazing.”
Use simple, factual language similar to image captioning datasets. Focus on objects, positions, and actions. Avoid opinions or value judgments like “beautiful,” “epic,” or “stunning.”
This nudges the model closer to grounded captions and away from trailer text.
6. Make the model choose what to omit
When everything is “describe in detail,” you get either walls of text or vague summaries.
Instead, give it a budget and an explicit decision rule:
You may mention at most 8 distinct visual elements.
First, rank all detected elements by:
  1. How central they are in the frame(s).
  2. How long they are visible.
  3. How much they move or change.
    Only describe the top-ranked ones.
By forcing prioritization, you encourage concrete, salient details over listing every background object.
7. Lightweight self-calibration without a full critique pass
I like @nachtdromer’s self-critique trick, but you can make it cheaper:
  1. Generate the description.
  2. Ask the model in a second, tiny prompt:
    From this description, list the top 5 visual elements that are claimed to be present.
  3. Automatically compare those 5 against your structured data:
    • If any are unsupported, flag and re-run generation with a stricter prompt:
      You previously mentioned unsupported elements: X, Y. Regenerate the description without them and only use entities that appear in the data.
No need for a long analysis step, just a small guardrail loop.
8. Explicit style channel for AI-generated content
Because your videos come from AI images, you often know style tags up front. Instead of letting the model guess:
  • Maintain a separate style field per clip: ['oil painting', 'isometric', 'pixel art', 'photorealistic', 'anime', 'cyberpunk', ...]
  • Feed it in separately and constrain usage:
    You may only use style words from this list and only if they clearly fit the visuals. Do not invent new style labels.
This keeps your descriptions consistent across a series created with similar prompts, and it is easier to filter or cluster by style later.
  • High style consistency across a dataset
  • Easy to filter/search by art style
  • Requires you to track style metadata or tag it reliably
  • Can feel slightly rigid if the visual result drifts from the original style intent
9. Where this differs from @nachtdromer
  • I lean heavier on:
    • Redundant vision passes and agreement checking.
    • Explicit motion tracks and role-based sentence templates.
    • Strict priority rules for what gets mentioned.
  • I lean lighter on:
    • Long self-critique chains.
    • Very detailed JSON diffing across keyframes.
      Instead I prefer a small set of ranked entities + motion tracks.
If you share the rough average clip length and whether latency / cost are your main constraints, you can trim this to a very lean 2–3 step pipeline that still gives you accurate, non-generic video descriptions from AI images.
