Need help translating English to Swedish naturally
I’m working on some text that needs to be translated from English to Swedish, and I want it to sound natural to native speakers, not like a literal or machine translation. I’m not confident in my Swedish skills, and online tools give mixed results. Can anyone help me understand the best way to translate my English phrases into correct, conversational Swedish and point out any common mistakes I should avoid
You will get more natural Swedish if you stop thinking word‑for‑word and start thinking in chunks.
A few practical tips that help a lot:
  1. Shorter sentences
    English tolerates long chains. Swedish starts to feel stiff if you stack too many clauses.
    EN: “I’m working on some text that needs to be translated from English to Swedish, and I want it to sound natural to native speakers, not like a literal or machine translation.”
    SW (more natural):
    “Jag jobbar med en text som ska översättas från engelska till svenska. Jag vill att den ska låta naturlig för modersmålstalare, inte som en ordagrann eller maskinell översättning.”
  2. Change structure, not only words
    Do not copy the English structure. Swedes often prefer:
    • “Jag håller på att…”
    • “Det är viktigt att…”
    • “Det blir konstigt om…”
    Example:
    EN: “I’m not confident in my Swedish skills.”
    SW: “Jag känner mig inte så trygg i min svenska.”
    or
    “Jag är inte så säker på min svenska.”
  3. Watch false friends and stiff words
    “Confident” → trygg, säker på mig själv, inte “konfident” (that sounds wrong).
    “Skills” → kunskaper, nivå, “min svenska”.
    “Need help” → “behöver hjälp”, not “behöver support” in this context.
  4. Use common filler words
    Native sounding Swedish often uses småord:
    • ju
    • väl
    • nog
    • bara
    Example:
    “Jag är ju inte så säker på min svenska, så jag tar gärna emot hjälp.”
  5. Let natives “fix” your text
    Your best move is to post your attempt and let people correct it.
    You learn patterns like word order, pronoun choice, and where Swedes drop words.
Here is a full natural version of your description in Swedish:
“Jag jobbar med en text som ska översättas från engelska till svenska. Jag vill att den ska låta naturlig för svensktalare, inte som en ordagrann eller maskinell översättning. Jag är inte så säker på min svenska, och jag skriver ofta direkt från engelskan, så jag tar gärna emot hjälp med att göra formuleringarna mer naturliga.”
If you use AI to draft the Swedish, run the result through something that smooths out the “AI tone” before you show it to natives or clients. Tools like
Clever AI Humanizer for natural-sounding text
help remove robotic phrasing, adjust formality, and make the translation read more like a human wrote it. It works well for English and then you adapt the same ideas in Swedish.
You’re already on the right track by caring that it sounds natural. That alone puts you ahead of most word‑for‑word stuff.
I mostly agree with @sognonotturno, especially about shorter sentences and not copying English structure. I’ll push in a slightly different direction though: instead of thinking “how do I say this sentence in Swedish,” think “how would a Swede actually phrase this idea from scratch?”
Take your original description in English. A very natural Swedish version could be a bit more casual and less “translated” than the one already given, for example:
Jag håller på med en text som ska översättas från engelska till svenska och vill att den ska låta så naturlig som möjligt. Min svenska är inte jättestark, och jag märker att jag ofta skriver lite för direkt från engelskan, så jag skulle gärna få hjälp att göra formuleringarna mer idiomatiska.
Differences from what’s already been suggested:
  • “Jag håller på med…” feels very everyday and less stiff than “Jag jobbar med…” in some contexts.
  • “inte jättestark” is a very Swedish way of understatment, slightly softer than “inte så säker.”
  • “idiomatiska” is more textbooky, but it fits if the rest of the text is semi‑formal.
A few extra tricks that help you sound less like a machine:
  1. Actively change words when Swedish would “downgrade” them
    English loves big words. Swedish often goes smaller or more neutral.
    • “confident in my Swedish skills” → “ganska osäker på min svenska” / “min svenska är rätt rostig”
    • “needs to be translated” → “ska översättas” (shorter, more natural)
  2. Use “lagom” hedging
    Swedes often soften things with “lite”, “ganska”, “rätt”, “typ”, “inte riktigt”.
    • “I’m not confident in my Swedish skills”
      → “Jag är inte riktigt bekväm med min svenska.”
      That tiny “riktigt” does a ton of natural‑sounding work.
  3. Let word order carry the emphasis
    Don’t just keep English order:
    • “Jag vill att texten ska låta naturlig för svenskar” is fine.
      But if you want to stress “not like a machine translation”:
    • “Framför allt vill jag att den inte ska låta som en maskinöversättning.”
  4. Don’t be afraid to drop stuff
    English repetition sounds natural; Swedish often cuts:
    • EN: “I want it to sound natural to native speakers, not like a literal or machine translation.”
    • SW can drop “translation” the second time:
      “Jag vill att den ska låta naturlig för svensktalare, inte som en ordagrann eller maskinell.”
  5. Check if a Swede has actually said that before
    What helped me most: search the phrase in quotes with “site:.se”. If nobody on Swedish sites has ever written that string, it’s probably a bit off.
    For example, test:
    • “känner mig inte så trygg i min svenska”
    • “min svenska är lite rostig”
      You’ll see what people really use.
On the AI side: if you already use AI to draft your Swedish, you can run the English or Swedish through a “de‑robotizer” before polishing. Something like Clever AI Humanizer for more natural-sounding text is aimed exactly at taking stiff AI output and making it read more like a human wrote it. In practice that means:
  • Smoothing weird phrasing
  • Adjusting formality so it matches your context (blog, marketing, academic, etc.)
  • Reducing repetition and the typical “AI rhythm” in sentences
You still need to tweak the Swedish yourself or with native help, but if the English source is more natural and less robotic, the Swedish you produce from it will be easier to make idiomatic too.
If you want, paste one or two of your English → Swedish attempts and folks can “Swedefy” them. That’s honestly the fastest way to get a feel for what looks fine vs what screams “direct translation”.
Forum expert angle here, building on what @sognonotturno already covered but from a slightly different side.
I partly disagree with the idea that you should always relax and go super colloquial like “inte jättestark”, “typ”, etc. That is great for everyday text, but if your target is e.g. a company page, grant application or a portfolio, Swedish readers often expect a cleaner, slightly more neutral style. So step one is: decide register before you translate.
1. Pick a register first
Ask yourself:
  • Is this text closer to a LinkedIn post, an email to a friend, a landing page, or a term paper?
    Then choose the level of Swedish:
  • Neutral / semi formal:
    • “Jag är inte helt säker på min svenska.”
    • “Jag skulle uppskatta hjälp med att göra språket mer naturligt.”
  • Informal:
    • “Min svenska är lite rostig.”
    • “Skulle gärna få hjälp att få det att låta mer naturligt.”
Do that choice consciously before you touch any sentence.
2. Think in “information blocks”, not sentences
Instead of trying to mirror the English sentence, break it into blocks:
Your original:
  1. I’m working on some text that needs to be translated from English to Swedish
  2. I want it to sound natural to native speakers
  3. not like a literal or machine translation
  4. I’m not confident in my Swedish skills
  5. and only …
In Swedish, you could merge or reshuffle:
Jag håller på med en text som ska från engelska till svenska, och jag vill att den ska låta naturlig för svensktalare, inte som en rak översättning. Min svenska är inte helt på topp, så jag skulle gärna få hjälp med formuleringarna.
Notice a few things:
  • I dropped repetition like “translation” after it was clear from context.
  • I merged 2 + 3 into one smoother contrast.
  • I avoided overusing “att” and “som” right next to each other, which quickly feels clunky.
3. Replace “translation flavor” connectors
English loves “that”, “which”, “so that”, “in order to”. Literal Swedish versions often sound heavy. Try these swaps:
  • “so that it sounds natural”
    → “så att det låter naturligt” is fine, but often shorter is better:
    → “så det låter naturligt” or just “…och låta naturligt”.
  • “I want it to …”
    → Often replaceable with “den ska …” or “målet är att …”:
    “Målet är att texten ska låta naturlig, inte översatt.”
4. Use verb-driven phrasing
Swedish often prefers verbs where English uses nouns:
  • EN: “I want the translation to have a natural flow”
  • Literal: “Jag vill att översättningen ska ha ett naturligt flyt.”
  • More Swedish: “Jag vill att texten ska flyta naturligt.”
Look out for “have / make / do + noun” constructions in English, and see if Swedish would just use one verb.
5. Small things that quickly betray a non native
Some quick “red flags” that make text feel translated:
  • Overuse of “på svenska språket” instead of just “på svenska”.
  • Direct “native speakers” → “infödda talare”. Better: “svenktalare” or “de som har svenska som modersmål” depending on context.
  • Too many commas where English would put them. Swedish often uses fewer.
  • Overusing “väldigt” for everything. We use “ganska”, “rätt”, “riktigt”, “jätte” strategically.
6. Using tools without sounding like a robot
If you run your English through AI first, you can improve the source text before translating. Cleaner English in, better Swedish out.
Here is where something like Clever AI Humanizer can actually help:
  • It smooths out stiff or overly formal AI English, which makes Swedish phrasing easier and more natural.
  • It reduces typical AI repetition patterns that are very hard to carry over into Swedish without sounding off.
  • You can push the tone closer to how people really write, which Swedes then expect too.
  • It can over casualize or add “fluff”, so you still need to trim and adapt for Swedish conciseness.
  • If you rely on it blindly, you might end up with idioms that work in English but are awkward to mirror in Swedish.
  • It does not replace a native review, especially for nuance heavy stuff like marketing or creative writing.
So: use it upstream to make your English more natural and less robotic, then do a human conscious pass into Swedish, exactly like you are trying to do now.
7. How to get better fast
Since you are already thinking about idiomatic Swedish:
  • Take one of your translations.
  • Put each Swedish sentence into quotes and search it on Swedish sites.
  • If you get basically no hits, try to adjust word order or swap 1–2 key words (“naturlig” → “vardaglig”, “säker” → “trygg”) and test again.
Combined with the structural tips from @sognonotturno about shorter sentences and not copying English syntax, this builds a feel for “how Swedes actually say stuff”.
If you want, post one English paragraph plus your Swedish attempt in the thread. Instead of just correcting it, people can also explain why certain tweaks feel more natural, which is where the real learning happens.
