Need help choosing the right Google Wifi 3 Pack setup?
I’m upgrading my home network and considering a Google Wifi 3 Pack for better coverage and faster speeds. My current router leaves a lot of dead spots and unstable connections, especially for streaming and work calls. Can anyone explain if the Google Wifi 3 Pack is worth it, how to set it up correctly in a medium-sized house, and what issues I should watch out for?
Short version for your situation.
Google Wifi 3‑pack works fine for small to mid homes, but the setup matters more than the brand if you want fewer dead spots and stable calls.
Key points:
  1. House size and layout
    • If you are under ~3,000 sq ft, 3 pucks usually handle it.
    • If you have two floors or thick walls, expect some drop in speed on the far nodes.
    • Avoid putting points in corners or behind TVs. Put them in open areas, about 30–40 feet apart.
  2. Backhaul and speed
    • If you do Ethernet backhaul, Google Wifi is solid. Each puck wired to your main router gives much better stability for streaming and work calls.
    • On pure wireless backhaul, your second and third points often get half or less of your main speed. For example, 600 Mbps at modem, 250–300 Mbps at second puck, 100–150 Mbps at third.
    • If you do a lot of video calls, try to wire at least the office node.
  3. Internet speed vs mesh
    • If your ISP speed is 200 Mbps or lower, Google Wifi is fine. Your bottleneck is your ISP.
    • If you pay for 600–1,000 Mbps and want that across the house, you might feel limited and you might want Wi‑Fi 6 gear instead, like Nest Wifi Pro or similar.
  4. Placement tips for the 3‑pack
    • Put main puck next to modem, not inside a cabinet.
    • Put second roughly in the center of the house, same floor as main if possible.
    • Put third near the worst trouble area, but still in good signal range from the second.
    • Avoid putting a point right next to a microwave, big metal shelf, or on the floor.
  5. Router mode vs bridge mode
    • If your ISP modem is also a router, set Google Wifi into bridge mode, or put modem in bridge and let Google handle routing.
    • Double NAT often causes weird issues with calls, VPN, and consoles.
  6. Use a Wi‑Fi survey, not guesswork
    Do a quick Wi‑Fi survey before and after placement instead of eyeballing. NetSpot is good for this. You walk around your place with a laptop or phone and it maps signal and speeds.
    Check this out: map and improve your home Wi‑Fi coverage.
    You will see exactly where your dead zones sit and where to move a node.
  7. When Google Wifi is not ideal
    • Large multi‑story house.
    • A lot of concrete or brick walls.
    • Many heavy users on video calls at once, plus gaming, plus streaming.
    In those cases, look at a Wi‑Fi 6 mesh with Ethernet backhaul.
If you share your square footage, floor count, ISP speed, and where your worst dead spots are, users here can help you pick ideal puck locations or suggest if you should skip Google Wifi for something a bit newer.
If your goal is fewer dead spots and more stable calls, a Google Wifi 3‑pack can work, but it’s kind of “Wi‑Fi 5 comfort food” at this point, not cutting edge. @techchizkid covered placement and backhaul really well, so I’ll hit different angles and push back on a couple of points.
1. When Google Wifi 3‑pack actually makes sense
Google Wifi 3‑pack is still a solid choice if:
  • Your house is roughly 1,200–2,500 sq ft
  • You’re mostly on Zoom/Teams, Netflix, YouTube, web, not hammering big downloads on multiple devices at once
  • Your ISP speed is 100–400 Mbps
In that setup, you’ll typically see:
  • 200–300 Mbps near the main puck
  • 100–200 Mbps on the satellites (wireless backhaul)
For work calls and streaming, that’s totally fine. Latency and stability matter more than a pretty speedtest.
Where I don’t fully agree with @techchizkid: if you’re paying for gigabit and don’t really care about seeing 900 Mbps on Wi‑Fi, you don’t have to jump to Nest Wifi Pro or another Wi‑Fi 6 mesh. Plenty of folks are happy as long as everything is smooth and responsive, not maxed out.
2. Where you’ll regret buying Google Wifi
You’re likely to feel boxed in by Google Wifi if:
  • You have a large or weirdly shaped house (L‑shape, long ranch, basement office, etc.)
  • You want Wi‑Fi 6/6E for newer phones/laptops
  • You care about full‑house gigabit speeds, not just “good enough”
In those cases, a Wi‑Fi 6 mesh (TP‑Link Deco XE75, Nest Wifi Pro, Eero 6/6E, etc.) with wired backhaul is a better long‑term play. Google Wifi works, but you’ll be milking an older standard.
3. Get out of guess‑mode: measure your signal
Biggest mistake I see: people move pucks around by “feel” and then complain about dead zones.
You’ll get much better results if you:
  • Install NetSpot on a laptop or use the mobile version
  • Walk around your home before you buy anything and see where the signal drops
  • After placing the pucks, do another pass and check signal strength and throughput
NetSpot is seriously underrated. Instead of just eyeballing, you can use something like
map and boost your home Wi‑Fi coverage
to visualize where your Wi‑Fi sucks and where a node actually helps. That way you’re not stuck in the “move it 3 feet and pray” cycle.
If you do go with Google Wifi, use NetSpot to tune:
  • Is the satellite node getting at least ‑60 dBm from the main? If not, move it closer.
  • Is your “problem room” getting better than ‑70 dBm after placement? If not, that room may need Ethernet or a different layout.
4. A quick word on your actual use case
Your description, SEO‑friendly and human readable:
You’re upgrading your home network and looking at a Google Wifi 3‑pack to improve coverage and speed. Your current single router creates Wi‑Fi dead zones and unstable connections that hurt streaming quality and disrupt important work calls. You want a more reliable mesh system that delivers consistent performance throughout your home, with fewer dropouts and stronger signals in problem areas.
Given that, I’d say:
  • If your place is under ~2,500 sq ft and you’re not obsessed with gigabit speeds everywhere, a Google Wifi 3‑pack is a reasonable, budget‑friendly option.
  • If you have a lot of thick walls / multiple floors / home office far from the modem, I’d lean toward a Wi‑Fi 6 mesh and plan on at least one Ethernet run.
If you post your rough square footage, number of floors, ISP speed, and where your worst dead zones are, people can tell you pretty bluntly whether Google Wifi 3‑pack will be enough or if you’re about to buy something you’ll outgrow in a year.
Short version: Google Wifi 3‑pack can absolutely fix dead spots, but only if you treat it as an actual network design problem instead of just “3 magic pucks.”
A few angles @vrijheidsvogel and @techchizkid did not lean on as much:
1. Decide first: coverage vs peak speed
You mentioned streaming and work calls. For that, consistency beats raw Mbps.
  • If your current router does 300–500 Mbps in one room and garbage elsewhere, a Google Wifi 3‑pack that gives you 80–200 Mbps everywhere is a win.
  • Stop chasing the “gigabit everywhere” dream unless you really do massive LAN copies or downloads on Wi‑Fi all over the house.
So: if you mostly care about Zoom and Netflix not stuttering, Google Wifi is still perfectly relevant.
2. Where I slightly disagree with them
They focus a lot on “wired backhaul or bust.” I agree it is ideal, but in a normal wood‑frame house:
  • A clean wireless backhaul with decent placement is fine for most people up to 300–400 Mbps ISP speed.
  • Running Ethernet everywhere is great in theory and often unrealistic in rentals or finished homes.
What matters more than the backhaul type is that the hops are clean: no point in the basement trying to talk to a main node two floors away through three walls.
3. Consider your client devices
Everyone talks about the mesh, almost nobody talks about what is connecting to it.
  • If most of your devices are older phones / laptops that only support Wi‑Fi 5 anyway, a fancy Wi‑Fi 6E mesh will not magically make them faster.
  • If you just bought a bunch of Wi‑Fi 6 laptops and phones, then I would tilt more toward Nest Wifi Pro or similar.
So if your gear is mostly a few years old and your ISP is under ~400 Mbps, Google Wifi still sits in the “sensible choice” zone.
4. Use NetSpot differently than just a heatmap toy
Both of them already suggested using a Wi‑Fi survey, but let me frame how to actually use NetSpot as a decision tool, not just eye candy:
Pros of NetSpot:
  • Gives a visual of weak areas instead of “it feels bad here.”
  • Lets you test before you buy new hardware, so you see if simply moving the modem/router helps.
  • After installing the mesh, you can confirm whether each Google Wifi unit is talking to the previous one with a strong link.
  • Helps you spot weird interference spots like one corner of the kitchen that always looks worse.
Cons of NetSpot:
  • It is another thing to install and learn, not a 30‑second tool.
  • People misread the graphs and obsess over hitting perfect numbers instead of “stable enough for calls.”
  • You can end up moving pucks endlessly chasing marginal gains of 5–10 Mbps that you will never notice.
Competitors like in‑app signal bars from mesh systems are lazier but simpler; they just say “good / okay / bad.” NetSpot lets you nerd out more, which can be a pro or a con depending on your patience.
5. Practical decision tree for you
Use this mental checklist:
  1. ISP speed
    • ≤ 300 Mbps: Google Wifi is fine, focus on placement.
    • 300–600 Mbps: Google Wifi still OK if you do not care about maxing every room.
    • Gigabit and you want to see >600 Mbps on Wi‑Fi: look at Wi‑Fi 6 gear instead.
  2. House layout
    • 1 floor, 1,200–2,500 sq ft: 3‑pack is usually enough.
    • 2 floors or more: plan 1 unit near modem, 1 somewhere central on the same floor, and 1 on the other floor aligned vertically if possible.
    • Weird L‑shape / long ranch: place the middle puck literally in the middle of the path between modem and far rooms, not where it is most “convenient.”
  3. Office location
    • If your office is far from the modem, bias your best link toward the office, even if that means a bedroom gets slightly worse Wi‑Fi. Work calls benefit more than a spare TV.
6. What I would actually do in your shoes
  • Run NetSpot once with your existing router to see if maybe a single better‑placed router fixes most of it. Sometimes moving the modem/router out of a corner or closet already wipes out half the problems.
  • If you still have clear dead or weak zones after that, then move to a Google Wifi 3‑pack.
  • Place main at modem, second roughly mid‑house, third biased toward your office or main streaming area.
  • Use NetSpot again after setup, but stop tweaking once your “problem rooms” show reasonably strong signal and your real‑world tests (speedtest, a few long calls) are stable.
If you share your square footage, floors, ISP speed, and roughly where modem and office are, people can sanity‑check whether a Google Wifi 3‑pack is the right call or if you should bite the bullet and go Wi‑Fi 6 from the start.
