Need help choosing performance review software for my team
I’m looking for practical recommendations on performance review software that actually improves feedback and goal tracking, not just adds admin work. My current process is a mix of spreadsheets and emails, and it’s become messy, hard to track progress, and frustrating for both managers and employees. What tools have you used that support clear performance metrics, regular check-ins, and easy reporting, and what should I watch out for before committing?
We went through the same spreadsheet and email chaos last year. Sharing what worked and what sucked for us.
Context
Team size: 28 people
Mix: engineers, ops, sales
Needs: continuous feedback, goals, light admin
Short list we tested:
  1. Lattice
  2. 15Five
  3. Culture Amp
  4. Small tool: PerformYard (for comparison)
What you likely want based on your ask:
• Easy goal tracking (OKRs or simple goals)
• Regular feedback without extra forms
• Simple review cycles
• Clear visibility for managers
Here is how they stacked up.
Lattice
• Goals: Strong OKR support. Good dashboards. You see team and individual alignment.
• Feedback: 1:1 templates, feedback requests, praise. Integrated with Slack.
• Reviews: Flexible templates. You set up self, manager, peer reviews pretty fast.
• Analytics: Performance trends per team and per manager. Helps spot weak feedback habits.
• Admin setup takes time. You need 1 owner who cares.
• People complained about notification noise until we tuned settings.
• Price felt high for under 20 people, ok for 20+.
Best fit if you want structure and plan to grow the team.
15Five
• Feedback: Weekly check-ins, simple questions, quick pulse on morale and progress.
• Goals: Objectives + key results. Less complex than Lattice.
• Reviews: Focuses on strengths and development. Good manager prompts.
• Coaching: Their templates nudged managers to write better feedback.
• Some folks ignored weekly check-ins after 2 months. We had to enforce a bit.
• Goal views less deep than Lattice for multiple teams.
• UI felt slightly dated to some people, still fine though.
Best fit if your main pain is ongoing feedback, not complex reviews.
Culture Amp
• Strong on engagement surveys plus performance. Good if HR wants both.
• Flexible review templates. Strong library of questions.
• Good science behind their suggested questions and scales.
• Felt heavier for a small team.
• More HR focused. Our managers found Lattice easier daily.
• Price higher for small orgs.
Best fit if HR and leadership want data and engagement surveys with performance in one tool.
PerformYard or similar lean tools
• Simple cycles. Self and manager reviews with fewer clicks.
• Cheap compared to the bigger ones.
• Good if you only need structured reviews twice a year.
• Weak continuous feedback.
• Goal tracking basic, more like checkboxes than real OKRs.
Best fit if you only want to replace spreadsheets for formal reviews.
What I would do in your shoes:
  1. Decide your priority
    • If goal tracking is top: look at Lattice first.
    • If feedback rhythm is top: look at 15Five first.
    • If HR data is top: look at Culture Amp.
  2. Run a 90 day pilot, not a big bang rollout
    • Pick 1 or 2 teams.
    • Set a simple rule: weekly 1:1s logged in the tool, quarterly goals in the tool, one small feedback request per person per month.
    • Track adoption: login rate, 1:1s done, goals updated.
  3. Non negotiables to ask every vendor in the demo
    • How to integrate with Slack or Teams for reminders.
    • How to sync people data with your HRIS or at least CSV.
    • How to export to CSV in case you switch later.
    • How many clicks for a manager to complete one review. Ask them to screen share and walk an end to end example.
  4. Stop the admin bloat
    • Limit review questions to 5 to 8 core questions.
    • Use rating scales plus one comment box.
    • Use the tool for 1:1 agendas, so you remove separate docs.
    • Autocreate review cycles by date, so admins do not build each one from scratch.
My quick recommendation
• Team under 15, simple needs: a lighter tool or even 15Five with check-ins only.
• Team 15 to 200, want goals and structured reviews: start with Lattice.
• Team with strong HR and survey needs: add Culture Amp to the conversation.
If you share team size, budget range, and if you use OKRs or not, people here can narrow this down even more.
We were in your exact “spreadsheets + emails + pain” phase last year. Short version: the tool matters, but how you use it matters more than which brand you pick.
I agree with a lot of what @cazadordeestrellas said, but I’d push on one thing: I wouldn’t start with a Lattice-scale system unless you’re very sure someone will own it. The “one admin who cares” they mention is not optional. Without that, any big tool becomes a fancy spreadsheet with nicer fonts.
A few practical angles you might not have considered:
1. Clarify your actual use cases before shopping
Write 3 user stories, literally:
  • “As a manager, I need to see my team’s goals in one place and who’s off track.”
  • “As an IC, I need a simple way to ask for feedback after a project.”
  • “As whoever owns HR stuff, I need to run a review cycle without chasing people manually.”
If a vendor can’t show those 3 flows in under 10 clicks each, move on. Most demos are fluffy. Force them into real workflows.
2. Don’t sleep on lighter tools or combos
Everyone jumps to big “performance platforms,” but there are other combos that can be less admin:
  • Google Docs / Notion + a feedback plug‑in
    Use a structured 1:1 doc template + something like Leapsome / Effy / Officevibe for ongoing feedback. Reviews live in docs, feedback in the tool. Cheap and surprisingly effective if your team is under ~20.
  • Small focused performance tools (similar to PerformYard)
    Some of them are decent at goals + reviews but not noisy like Lattice/15Five. The win here is less configuration, fewer options, less “what do I click” confusion.
I’d disagree slightly with the idea that “light tools are only good for twice‑a‑year reviews.” If your culture is already feedback‑friendly, even basic tools can work for continuous feedback. The tool doesn’t create that habit, it just records it.
3. Watch out for these hidden failure modes
Stuff I learned the hard way:
  • Too many “goal types” and fields = nobody updates goals. Start with: title, 3–5 key results, owner, due date. That’s it.
  • If weekly check‑ins are optional, half your team will drop them after novelty wears off. Either:
    • Cut them entirely, or
    • Make them 3 questions, max, and tie them to 1:1s.
  • Don’t let every manager design their own review template. That turns into chaos and you’re back to spreadsheet vibes.
4. Evaluation checklist that cuts through the sales fluff
When you trial tools, actually time these:
  • How long for a manager to:
    • create / edit a goal for a direct
    • give quick written feedback
    • complete a full review
  • Slack / Teams integration: can people respond to nudges inside Slack, or just get pinged to a browser? That small detail changes adoption a lot.
  • Permissions sanity: can an IC see their own history clearly, without accidentally seeing confidential ratings?
If any tool makes you click through 6 pages just to give feedback, it will die.
5. My concrete recs by situation
Assuming you want to reduce admin, not introduce a new part‑time job:
  • If you’re under ~20 people and mainly want:
    • “Stop chasing people for forms” and
    • “Keep goals and reviews in 1 place”
      I’d pick a lean performance tool or a simpler module like Leapsome Performance only, not the full suite.
  • If you’re 20–80 people, planning to grow, and you have at least one semi‑HR owner:
    • Lattice or 15Five can be great, but start with just 3 things: goals, 1:1s, and one review cycle. Turn off everything else at first.
  • If leadership obsesses over survey data and benchmarks:
    • Culture Amp or similar is worth it, but it is heavier than it looks in the demo.
6. How to avoid adding more admin
Regardless of tool:
  • One shared company review template
  • 5–7 questions max, mostly scaled + 1–2 free text
  • Goals updated quarterly in 15 minutes during 1:1s
  • Feedback after big milestones only, not random weekly spam
If you share rough team size, whether you already use OKRs, and how much time you can give someone to “own” the system, you’ll get much more targeted suggestions. Right now, your bigger risk isn’t picking the wrong software, it’s picking something too heavy for how ready your org actually is.
