Issues with Whatsmyname App?
I’ve been using the Whatsmyname app, and around a week ago, it stopped working properly. Whenever I try to open it, it crashes immediately. I’ve tried restarting my phone and reinstalling the app, but nothing seems to help. Has anyone else faced this issue or know a solution? Your advice would be greatly appreciated.
Same here! Been experiencing constant crashes with the Whatsmyname app. I tried the usual stuff like restarting my phone, reinstalling the app, and even clearing the cache. Nothing worked so far. I wonder if it’s an issue with a recent update or something.
I also checked on Reddit and it seems like a few more people are having the same problem. I guess contacting their customer support might be the next step—hopefully, they can provide a fix soon. If anyone finds a workaround, please share! Trying to keep my patience here while waiting for an update… :triumph:
By the way, what type of device are you using? Curious if it’s an OS-specific issue. I’m on an iPhone, but heard someone on Android having a similar issue too.
Anyway, good luck!
I’ve seen similar issues pop up, especially after an app update. It’s possible Whatsmyname’s latest version has some bugs that need fixing. One thing I noticed is that some apps tend to behave better when they’re allowed all permissions they request; have you double-checked your app permissions? Maybe it’s just a simple setting causing the crash.
Also, try toggling Airplane mode on and off or switch from WiFi to mobile data. Sometimes connectivity issues can lead to unexpected crashes. Granted, it’s a long shot, but I’ve seen stranger things fix app issues!
As for contacting customer support, totally agree. But don’t just stop there. Drop a review in the App Store or Google Play Store—developers tend to take public complaints more seriously.
OS-wise, it doesn’t seem restricted to iPhone or Android. It might very well be a server-side issue. Are other apps working fine on both iOS and Android, cazadordeestrellas?
Anyone checked if there’s a beta version available? Sometimes joining the beta program of an app gets you fixes earlier than the general user base.
Add in one more thing: if any of you are comfortable with it, try to find the APK of an older version (obviously stay safe and ensure it’s from a trusted source). Not the most elegant solution, but it might get you back in action until the devs release a fix.
Hope this helps, and fingers crossed for a quick update from the devs!
Hey all,
Experiencing the same annoyances with the Whatsmyname app lately. I’ve gone through the ritual of phone restarts, app reinstalls, and clearing out caches, to no avail. The crashing persists.
Someone recommended rechecking app permissions and toggling connectivity options. I tried both—still nada.
So, here’s my wild card: if you have an older device lying around, try installing Whatsmyname on it to see if it crashes there too. Sometimes device-specific issues emerge with new app versions.
As for customer support, it’s undeniably a good step but feels like throwing a bottle into the ocean. I’d also suggest tweeting to their Twitter handle. Social media complaints can expedite responses.
One con with Whatsmyname is its frequent updates that seem to introduce bugs rather than fix them. On the flip side, when it works, it’s quite seamless and user-friendly. But reliability has been a major downside lately.
Competitors like Truecaller and Hiya might be more stable at the moment, but they lack some of the niche functionalities Whatsmyname offers, like customizable alerts.
Also, one workaround I haven’t seen mentioned: try running the app in compatibility mode if your OS allows it. Works sometimes, especially for crash-prone apps.
Hope this helps someone ease the headache a bit!
Try this simpler path.
Create a new user profile on your phone. On Android, go to Settings, then System, then Multiple users. Add a user, switch to it, install Whatsmyname fresh there.
If it works under the new profile, the issue sits in your main profile data.
Then clear app data again on your main profile or keep using it from the new one.
