I Make $200/day Running AI Agents While I Sleep. Sustainable Or Scam?
I started running AI agents that automate simple online tasks, and for the past few weeks they’ve been bringing in around $200 a day with very little work from me. It sounds great, but I’m worried it may not be sustainable or could be tied to a scammy business model. I need help figuring out what risks to look for, how to verify the income is legit, and whether anyone else has seen results like this with AI automation.
$200 a day for a few weeks is data, not proof.
A lot of these setups work until one input changes. Traffic source dries up. Platform rules change. CAPTCHA gets harder. API costs rise. One acct gets flagged and your whole loop breaks.
Look at unit economics.
Revenue per day: $200.
Now subtract API spend, proxies, accounts, retries, chargebacks, your time, and failure rate.
If net is still strong after 30 to 90 days, then you have somthing.
Track 5 things.
  1. Gross revenue.
  2. Net profit.
  3. Hours you spend fixing stuff.
  4. Ban rate or task failure rate.
  5. Revenue concentration. One source over 50 percent is a risk.
Also ask where the money comes from. If an agent is doing low-skill arbitrage on a loophole, it dies fast. If it solves a boring business task people keep paying for, it lasts longer.
So, scam? Not from your post alone.
Sustainable? Too early to say.
Right now it sounds like a temp edge untill proven otherwise.
A few weeks at $200/day is nice, but it’s not “passive income,” it’s more like a machine you haven’t watched break yet.
I mostly agree with @viajeroceleste, but I’ll push back on one thing: not every short-lived edge is bad. Sometimes a temp edge is still worth exploiting if you treat it like a cash harvest, not a business. People get in trouble when they confuse the two.
The real question is whether your agents create actual value or just exploit weak systems. If it’s the second one, the clock is already ticking. If it’s saving someone time, finding leads, sorting data, handling support, whatever, then you might have something real.
Also ask yourself this: if you turned the agents off for 7 days, would customers complain or would the money just stop? That tells you a lot.
$200/day can be sustainable.
$200/day with “very little work” usually stays that way… until it doesnt.
So scam? Not necessarily.
Durable business? Too early.
Profitable loophole? Probly. For now.
I’d split this into two buckets:
Good $200/day
  • recurring clients
  • clear deliverable
  • low refund rate
  • stable traffic/source
  • logs show consistent task success
Bad $200/day
  • one platform policy change kills it
  • depends on loopholes
  • no real customer attachment
  • earnings fluctuate wildly
  • you can’t explain the value in one sentence
I slightly disagree with @viajeroceleste on one point: even if nobody complains when it stops, it can still be a business. Some products are invisible when they work. The bigger issue is dependency risk.
Pros for the ‘’:
  • scalable
  • low labor
  • fast testing
Cons for the ‘’:
  • brittle automations
  • bans/policy risk
  • hidden maintenance
  • income can vanish overnight
My test: could you replace today’s revenue with direct paying customers in 30 days? If no, treat it like temporary yield, not freedom.
