How to retrieve deleted messages on Instagram?
I accidentally deleted some important messages on Instagram. Can anyone help me understand if it’s possible to recover them? Would really appreciate any guidance on this.
The process of trying to retrieve deleted messages on Instagram can be a frustrating journey. But worry not, there may be some hope. Here’s a breakdown of options you could explore:
  1. Request Data Backup from Instagram: Instagram has this cool feature where you can request complete data from them, including photos, comments, profile information, and messages. Here’s how you do it:
    • Go to your Instagram profile.
    • Tap the three lines (menu) in the top right corner and head to settings.
    • Click on ‘Security’ and then ‘Download Data’.
    • Enter your email address and tap ‘Request Download’.
    • Instagram will send a link to your email where you can download this data.
    Note that the process might take up to 48 hours, and sometimes messages might not be fully restored if they were deleted way back.
  2. Check Connected Facebook Account: If your Instagram DMs were connected to Messenger (through Facebook’s cross-platform integration), you might be able to find those deleted messages there.
  3. Third-Party Recovery Tools: Occasionally, third-party apps like Disk Drill
    can help if you have a backup. Disk Drill (https://www.disk-drill.com/) is popular for data recovery, though it’s more commonly used for recovering files from your computer or phone storage rather than directly from an app like Instagram. It’s something you could have in your toolkit, but remember to use such services cautiously to ensure you’re not violating any privacy policies.
  4. Check Archived Chats: Sometimes chats are mistakenly moved to archive rather than deleted. To check, go to your direct messages and swipe down to reveal the search bar. Type the name of the chatter; if the chat is archived, it will appear here.
  5. Backup Services: Moving forward, consider setting up regular backups for your data, be it via a cloud service or through dedicated apps that can keep a log of your messages.
Remember, while recovery isn’t always a guarantee, these steps maximize your chances of getting those important DMs back. Also, it’s good practice to routinely back up critical data to avoid future frustrations.
codecrafter’s approach covers a lot of ground for retrieving deleted Instagram messages, but there are a few additional methods and alternatives to consider— and let me be clear, nothing is foolproof—but you might find greater success with these strategies.
  1. Instagram Support: If you have tried codecrafter’s breakdown and hit a wall, the last resort is to approach Instagram Support directly. Yes, it can be a cumbersome process filled with form-filling and waiting, but there has been some success in term of recovering deleted data through them. Be incredibly detailed in your communication to avoid any back and forth.
  2. Cloud Backups: A lot of people aren’t aware of this, but if you have set up backups of your phone, sometimes these contain your app data as well. For instance, if you’re using an Apple device and regularly backup to iCloud, you might try restoring your phone to an earlier backup point—one prior to when the messages were deleted. It’s a blanket approach where you’ll restore all your phone’s data, but it might be worth it if those messages are crucial. Similarly, Android users could use Google Drive’s backup function. Here’s the crucial bit: back up your current data before restoring any old backups to not lose what you currently have.
  3. Undeletion Feature Requests: This might sound odd, but sometimes advocating for a feature can get results. Currently, Instagram doesn’t offer an easy “recycle bin” for deleted messages. Many users have been asking for this on forums and directly via app feedback. Pester them! Sometimes the pressure actually leads to platform updates—if nothing else, it shows you’re looking for proactive solutions, helping others with similar issues in the process.
  4. Browser Caches and Internet History: This is a wildcard, but if you remember accessing those DMs via a web browser at any point, check your browser cache and history. There might be fragmentary recoverable data. This is more likely if, for instance, you’ve used your desktop to view Instagram rather than solely the app. A deep dive into your browser storage tools or even employing cache recovery methods can sometimes yield results.
  5. Previous Device Meta Recovery: If you have previously accessed or downloaded Insta Data on another device, sometimes those messages could stubbornly linger in some deep corner of a previous device’s storage. Tools designed for deep phone storage recovery might help. This is a last long shot, but tools like ‘Disk Drill Data Recovery Software’ (https://cleverfiles.com/lp/data-recovery-software.html) come in handy. It’s a multi-purpose software that allows the recovery of various kinds of data and can be a lifesaver, though its primary function isn’t fixing deleted app data. But given how intertwined app data can be with device storage, anything’s worth a try. Be cautious with privacy and data access permissions when using such software.
  6. Vendor-Specific Services: Check if the phone manufacturer offers data recovery services. For example, some Samsung devices have a built-in data recovery option through Samsung Cloud, which holds more data than the user might realize. The same can go for other brand-specific cloud services which sometimes back up more than you are consciously aware of.
  7. Messaging Recovery From Linked Apps: If you have cross-platform app integration (like some productivity tools linked with Instagram), sometimes configuring those apps means some message data might get stored there. Slack, Trello, etc., can sometimes hold key fragments of communication due to app bots or integrations, though this is rare and specific.
So, recoverable or not, the next time you find a golden moment in your DMs, screen capture and save locally. A tad manual, but it could save you hours of heartache. Always keep a proactive data backup regimen handy!
Actually, I’ve had a similar issue before and found a few alternative methods that can help fill in some gaps missed by @byteguru and @codecrafter’s excellent breakdowns.
  1. Direct Message Backup Tools: There’s specialized software like ‘FoneLab’, which claims to help with recovering specific app data such as Instagram DMs. While these tools can be more versatile, they often require root access or a jailbroken device, which can void warranties or make your device vulnerable. Proceed with caution.
  2. Old Notifications: Sometimes, if you had Instagram notifications turned on and one of those messages was displayed in your phone’s notification history, you might get lucky. Android users can use the Notification Log, and iPhone users can check the Notification Center for a snapshot of missed notifications.
  3. Find old messages with Data Management Features: Some smartphones come with in-built data management features that sometimes store older versions of app data. For example, OnePlus devices offer this feature in their Settings under Storage>Explore and iPhones have the “Offload Unused Apps” feature. These might just have what you’re looking for.
  4. Email Notifications from Instagram: If you had email notifications enabled for Instagram messages, check your email archive or delete folder for message previews.
Disk Drill, already covered well above, is notable for its broad file recovery prowess across multiple types of data. However, its scope is generally limited to local storage rather than direct app data recovery, which some of its competitors like EaseUS or Dr.Fone emphasize.
Good luck trying these out!
Try Instagram’s Download Your Information. It is simple and official.
Open Instagram, Settings, Accounts Center, Your information, Download your information.
Select Messages, format HTML, date range All time, submit.
Watch your email. You recieve a link within a few hours, up to 48 hours.
Download the zip. Open messages.html. Use search to find the thread.
If you deleted only on your side, messages still appear. If both sides removed, nothing shows. In that case, ask the other person to export or send screenshots.
This avoids third party tools and risky rooting.
