How to restore deleted notes on my iPhone?
Accidentally deleted some important notes on my iPhone and can’t find them in the Recently Deleted folder. Need them back urgently for work. Any advice or methods to recover them?
If you’ve already checked the Recently Deleted folder and your notes aren’t there, you might still have options. Here are some steps to consider:
  1. Check iCloud: Sometimes notes are stored in iCloud. Go to iCloud.com, login, and see if your notes are still there under the Notes section.
  2. Restore from Backup: If you’ve been regularly backing up your iPhone via iCloud or iTunes, you can restore from a backup where your notes were still present. Just be careful as this will revert your entire phone to that point in time, not just the notes.
  3. Third-party Software: Programs like Disk Drill
    can scan your iPhone for deleted files including notes. Disk Drill is pretty effective and user-friendly but on the downside, the free version has limitations, and the pro version isn’t cheap.
  4. Other softwares: You might also look into alternatives like Dr.Fone, iMobie PhoneRescue, or EaseUS MobiSaver. They all offer similar functions for data recovery, but they too often come with the downside of being costly if you need advanced features.
Hope one of these methods works for you. Losing important work stuff is always a nightmare! Good luck!
Diskchizkid already shared some solid steps to follow, but let me add a few more angles you might want to check out, specifically if Dr.Fone, iMobie PhoneRescue, or other third-party software feels like overkill (or too expensive).
First off, if you use multiple email accounts on your iPhone, make sure your missing notes aren’t saved under a different account. Go to your Notes app, tap “Folders,” and check each email account listed to see if your notes are stashed away there. Sometimes notes unintentionally get saved under a less frequently used account, creating a bit of panic for no reason.
Another possibility is to check the iCloud settings on your device. Head over to Settings > [Your Name] > iCloud. Make sure Notes are toggled on. If it’s off, turning it back on might sync back your notes from iCloud to your device.
For those relying on the iCloud.com method, here’s an extended idea: Use a different browser or Incognito mode. Sometimes syncing issues on your usual browser can hide files, including notes, from view.
If you’re feeling adventurous or haven’t backed your phone up recently, you might consider checking old email archives for any notes you might have emailed yourself or saved drafts. This sometimes catches users off guard because it’s less direct but surprisingly effective.
One tool that deserves another mention is Disk Drill (https://www.disk-drill.com/). However, here’s a caveat: it scans for all deleted files, not just notes, which can be both a blessing and a curse. You might end up sifting through a lot of junk files – but it could potentially yield what you’re looking for if you can tolerate the effort involved.
In the slight chance you might have shared or copied parts of the notes into another app, perhaps due to research or collaboration, it’s worth sniffing through apps like Google Docs, Microsoft OneNote, or even simple text-editing apps like Notepad or Evernote.
Bottom line, there are several avenues you can explore beyond straight-up third-party software. Sometimes the simplest methods yield the best results, don’t underestimate good old-fashioned searching through your own saved drafts or emails. Good luck!
Hey, great suggestions from @codecrafter and @techchizkid! But let’s go beyond the usual suspects and dive into some alternative routes you might find handy when those crucial notes go MIA.
  1. Leveraging iPad or Mac: If you own other Apple devices like an iPad or Mac, there’s a chance your notes are still synced and alive there. It may sound obvious, but sometimes stepping away from your phone and checking your other devices can lead to pleasant surprises. Sync your devices and see if your notes reappear.
  2. Email and Messaging Apps: If you tend to share your notes or snippets via email, iMessage, or other messaging apps, it’s worth rifling through your sent messages or conversations. Sometimes we share important stuff without even realizing it, and it’s easier to retrieve from there than you might think.
  3. Spotlight Search: I’m not sure why, but some folks overlook the power of Spotlight Search on iOS. Swipe down on your home screen and type in keywords related to your notes. If they were saved anywhere or even partially cached, Spotlight might just bring them back to light.
  4. Contacting Apple Support: When all else fails and you’re truly stuck, sometimes getting in touch with Apple Support is a forgotten lifeline. They have advanced tools and diagnostics which could recover data that’s eluding even the best third-party software.
  5. Investigate Recently Opened Apps: Check the recently opened apps (double-click home or swipe up from the bottom and pause) to see if the content might have been viewed from another app. Sometimes the data might still be cached there, especially if it auto-saves drafts and documents.
  6. Keychain Update: Here’s a unique scenario: if your notes contain sensitive info often stored in a password manager or keychain, check those apps. Applications like 1Password or even your iOS Keychain can sometimes hold snippets or drafts.
  7. App-Specific Trash Folders: Some apps that sync with Notes like Evernote, Google Keep, or even the Office suite have their own trash or recently deleted folders. If you recall integrating or moving notes to such apps, it’s worth exploring their recovery features.
While third-party software like Disk Drill (https://cleverfiles.com/lp/data-recovery-software.html) is exceptional for deep scans, keep in mind it’s a broad tool. You might end up fishing through a hefty amount of reclaimed files, most of which are irrelevant. If you’re prepared for a bit of a “digital archeology dig” tho, it’s pretty effective.
Another perspective: frequent backups are your best friend and your worst enemy. They safeguard the data but rolling back an entire device to fetch a note might feel like shooting a fly with a bazooka. Consider selectively restoring just the Notes app if using iMazing. It offers a middle ground where a user might recover the notes without a full device restore.
One avenue rarely discussed is checking whether you’ve used a virtual assistant app like Siri or voice memos that might’ve jotted down those notes. Siri has the uncanny ability to draft notes from voice commands. Checking the accuracy of its transcriptions sometimes works.
Lastly, a wild card approach: if any of your notes were converted into a format readable by the Files app, hunting through those directories could also unleash success. In a time when apps predominantly are interconnected, this might just be an overlooked treasure trove.
Good luck – navigating dataspace can be a rollercoaster. Stay persistent and inventive, chances are, your notes are hiding somewhere in the matrix waiting to be uncovered!
Try a quick iCloud Notes resync.
Settings > Your name > iCloud > Notes off. Choose Keep on My iPhone. Wait 2 to 3 mins. Restart iPhone. Turn Notes on. Open Notes, pull to refresh. Then go to Settings > Notes, enable On My iPhone Account, check its folders.
This forces a fresh index and often recvoers server copies. I’ve seen notes reappear with today’s timestamp, edited last week. If nothing returns, repeat once after an hour, then stop to avoid sync loops.
