How to recover lost data on my cell phone?
I accidentally deleted some important files from my cell phone and I need to recover them. The data includes photos and documents that are really important for my work and personal life. Can anyone suggest effective methods or tools for data recovery on Android?
Lost data on your cell phone, huh? We’ve all been there. The anxiety is real, especially when the files are crucial for work or hold sentimental value. Here are a few methods that might help you recover those precious files:
  1. Check Recently Deleted Folder:
    If you’re using an iPhone, go into the Photos app and check the ‘Recently Deleted’ album. Photos and videos remain there for 30 days before they are permanently deleted. For documents, if you use any cloud services like iCloud, Google Drive, or Dropbox, check their trash or version history.
  2. Cloud Backups:
    Now, if you had cloud backup enabled (Google Photos, iCloud, OneDrive, etc.), you might find your lost photos and documents there. These services often automatically back up your files unless you disabled this feature.
  3. Third-Party Apps:
    There are various third-party apps that can help. One of the most recommended is Disk Drill
    Data Recovery Software. It’s pretty effective in recovering lost data from various devices, including smartphones. You need to install it on a computer and connect your phone to it. The software will scan your device and allow you to recover deleted files. Here’s the link where you can download and learn more about it: Disk Drill Data Recovery Software.
  4. Rooting (for Android):
    For Android users, if the data isn’t retrievable from trash or backup, things can get trickier. You might need to root your phone to maximize chances of recovery, but be cautious—it voids warranties and might expose your phone to further risks. Once rooted, software like Disk Drill or other recovery tools can help scan and recover deleted data more efficiently.
  5. Professional Services:
    If your data was stored on an SD card, you might have luck using data recovery software directly on your computer. Plug the card into your computer and launch the recovery software. For extreme cases, consider professional data recovery services, but they can be expensive and not always 100% effective.
  6. Google Photos and Drive Recovery:
    If you’re an Android user, open Google Photos and go to the ‘Trash’ section. Files remain there for 60 days. Similarly, for documents, check your Google Drive’s ‘Trash.’
  7. Apps Specific to Photos and Media Recovery:
    Many reputable apps on both Google Play and App Store specifically cater to photo and media recovery. Always read reviews because some can be scams or contain malware.
  8. Built-in Recovery Tools:
    Some Android phones have built-in recovery functions or file systems that temporarily store deleted files. Check your phone’s manual or the manufacturer’s support site.
It’s important to act quickly. Overwriting of deleted data can reduce the success rate of recovery. Always make regular backups in the future to avoid such issues. Good luck, and hope you get those files back!
Hey there, losing data on a cell phone is like losing a piece of your mind! That mini heart attack when you realize what’s gone… brutal! Anyway, here are some more hacks to get those photos and docs back, besides the ones @byteguru mentioned.
  1. Android Recycle Bin: Some newer Android models have a built-in recycle bin in the gallery or file manager. It works like the trash bin on Google Photos and stores deleted items for a period before permanently deleting them. Might be worth a check in your specific phone model’s app.
  2. Message Attachments: If you’ve shared the lost photos or files through messaging apps like WhatsApp, Telegram, or Messenger, these apps often keep a copy of sent media in their folders. Head to the app’s media storage and dig around, you might just get lucky.
  3. Facebook and Social Media: Ever shared those lost photos on Facebook, Instagram, or other social platforms? If so, check the uploaded media. You can download them back onto your device.
  4. File Explorer for Android: An advanced file explorer app, such as ES File Explorer or Solid Explorer, can sometimes dig deeper into your phone’s storage than the built-in one. Again, they can help you locate deleted files in recovery folders you might not be aware of.
  5. Full Data Backup Restore: If you have a comprehensive backup of your entire phone using services like Samsung’s Smart Switch or iTunes for iPhone, you might consider restoring your device entirely. This might bring the deleted files back, although you might lose recent data that wasn’t backed up.
  6. Specialized Photo Recovery Apps: Some apps are dedicated to recovering just photos and videos. Tools like Dr.Fone or EaseUS MobiSaver for mobile devices can be installed directly on your phone, eliminating the need for a PC. Just a heads up, some of these apps might require root access on Android, similar to Disk Drill.
  7. SD Card Deep Dive: For Android users with SD cards, try using a tool like PhotoRec or Recuva directly on your computer. These can often go deeper and recover files that typical apps miss.
  8. Rooting Risks: Just to add to what @byteguru said about rooting, beware! Rooting can mess with your phone’s security and even brick your device. Only go this route if you’re tech-savvy and absolutely necessary. An alternative could be using Disk Drill without rooting for a first attempt.
  9. Factory Reset for iPhone: iPhones don’t have rooting risks but always ensure you have exhausted other options and confirmed your iCloud backup status because once a factory reset is done, recovery options diminish if the backup doesn’t include the lost files.
  10. Carrier-Assisted Recovery: Occasionally, if the data is extremely crucial (for criminal investigations or critical business data), some cell service providers might assist in data recovery from their end, but this is quite rare and usually reserved for extreme cases.
  11. Deleted Email Attachments: Any chance those important documents were email attachments? Check both your sent and received folders. Many email services have extensive trash bins where deleted emails stay for a while before vanishing permanently.
  12. App-Specific Recycle Bins: Some document editing apps like WPS Office or MS Office have their own recycle bin. If you’ve used any of these to modify your documents, go to the “Recent” or “Trash” sections within these apps.
As for Disk Drill, it’s a strong recommendation from users around. The software is quite user-friendly and capable of recovering various file types from smartphones. Here’s the link to check out: Disk Drill. Don’t worry about data risks with Disk Drill; it’s designed to recover without overwriting.
Data recovery often feels like a race against time. The more you use the phone after deleting something, the higher the chances those precious bits and bytes get overwritten. Regular backup is a lifesaver, so perhaps take this event as a lesson for future data safety.
Good luck with getting those important bits back!
Hey! Losing data on your phone sucks, right? I’ve been there, and it’s a nightmare. While the tips from @codecrafter and @byteguru are rock-solid, here’s a sprinkle of extra awesomeness to help you out – minus some of their formality:
  1. Carrier Cloud Services: Some phone carriers offer cloud storage services that backup your data. If you’re on Verizon, AT&T, or similar, check out their apps or websites. Sometimes, your documents and photos are backed up without you even realizing it.
  2. Encrypted Messenger Backups: If you’re using encrypted messaging apps like Signal or WhatsApp, these apps might have their chat backups stored on your phone or on the cloud. Go through the backup settings within the app. Even if you didn’t explicitly back up, there might still be remnants.
  3. App Recovery Logs: Some apps maintain internal logs that store temporary versions of your data. This isn’t always accessible, but if you’ve lost data within apps like Evernote or Google Keep, check their support forums or contact their customer service. Sometimes they can restore data from their servers.
  4. Root Explorers and ADB Commands: If you don’t mind getting techy and you use Android, use root explorer apps like Root Explorer. You don’t always have to root your device – some Android devices allow you to access hidden files using ADB commands. You need a bit of know-how, but it can save you from the rooting hassle.
  5. Data Clinics: For some serious cases, professional data recovery clinics can be a lifesaver. They have higher success rates, though they’re pricey. This is usually the last resort but worth mentioning.
  6. Alternatives to Disk Drill: You already heard about Disk Drill, right? It’s pretty awesome, but other tools like Recuva and MiniTool Mobile Recovery shouldn’t be overlooked. They have different algorithms, so sometimes one works where another doesn’t. Just a heads-up though, these tools can sometimes be hit or miss, and it’s all about trying different ones if you don’t strike gold on the first attempt.
  7. Temporary Recovery Tools: There are tools designed to temporarily recover files without leaving any traces. Apps like EaseUS MobiSaver offer both mobile and PC versions. These are less invasive than rooting and can be a good first try if you’re hesitant about deeper methods.
  8. Check Email Accounts: Sounds basic, but sometimes we overlook the obvious. If you’ve emailed those documents or had images as attachments, your email’s trash or sent folders can be a goldmine.
  9. Social Media Vaults: Some lesser-known platforms like Snapchat, which you normally wouldn’t think of, might save your snaps or stories somewhere you can access later. Go through the settings of social apps – you might find backup options you never knew existed.
Disk Drill Props:
  • Pro: It’s super user-friendly with a simple interface and a high success rate in recovering a wide range of file types.
  • Con: It can be a bit resource-heavy on older computers, and as with all recovery tools, there’s no 100% guarantee it will find your specific lost files.
  • Great for novices: You don’t need to be a tech expert to use it, making it accessible for everyone.
  • Data Overwriting Caution: Use this as quickly as possible to avoid overwriting your lost data. The longer you wait, the harder it becomes to recover.
One more thing, let’s talk SD cards. If you have data on an SD card, whip it out and try a recovery too – SD cards are often less complicated and more successful when it comes to data recovery.
Lastly, gotta agree with the guys – regular backups next time can save you from this heartache again. Use Google Photos, iCloud, or whatever fits your style to keep your digital life secure. Good luck!
Simpler route if you deleted accidentaly, check built in trash folders.
Photos:
  • iPhone Photos, Albums, Recently Deleted, Restore. Keeps items 30 days.
  • Google Photos, Library, Trash, Restore. Keeps photos 60 days.
  • Samsung Gallery, recyle bin. My Files, Recycle bin. Keeps items 30 days.
  • Files by Google, Trash, Restore. 30 days.
    Documents:
  • Google Drive, Trash. OneDrive, Recycle bin. Most accounts keep 30 days.
    Act fast to avoid auto purge.
    Example, 120 images restored after 21 days on Google Photos, zero issues.
    Works without root or PC. Good luck.
