How to recover lost data from my iPhone?
Lost important data after my iPhone crashed. Need help with possible recovery methods.
If you lost important data after your iPhone crashed, don’t freak out—there are several ways you can recover it. Here’s a rundown of methods you can try:
1. Check iCloud Backup
First thing to do is see if you have an iCloud backup:
  1. Go into Settings > [Your Name] > iCloud > Manage Storage > Backups.
  2. Look for a recent backup. If it’s there, restore your iPhone using this backup by going to Settings > General > Reset > Erase All Content and Settings and then set up your device again, choosing Restore from iCloud Backup.
2. Restore from iTunes Backup
If you’ve been syncing your iPhone with iTunes (or Finder on macOS Catalina and later), you can restore from an older backup:
  1. Connect your iPhone to your computer.
  2. Open iTunes or Finder and select your device.
  3. Select Restore Backup in the Summary section.
  4. Pick the most relevant backup based on date and size.
3. Use Third-Party Data Recovery Software
Sometimes neither iCloud nor iTunes backups can help. In such cases, specialized recovery software may be the solution. One tool I recommend is Disk Drill
. This software is effective in recovering lost data from iPhones and other devices.
Disk Drill offers a user-friendly interface and powerful recovery features to help you recover data like photos, messages, contacts, and more. You can learn more and download Disk Drill from this link. It’s particularly helpful if you’ve got no recent backups.
4. Check Recently Deleted Folder
For lost photos or videos:
  1. Open the Photos app.
  2. Go to Albums > Recently Deleted.
  3. Select the items you want to recover and tap Recover.
5. Contact Apple Support
When none of the DIY methods work, or if the data loss is severe, Apple Support might be able to assist you:
  • Visit Apple Support
  • Schedule an appointment at a Genius Bar for professional help.
6. Cloud-based Services
If you’re using cloud services (like Google Photos, Dropbox, etc.), check if the lost data might be stored there. These platforms often keep backups of your files synchronized with your device.
7. Messaging Apps Backup
For messages or other app-specific data:
  • WhatsApp: Go to Settings > Chats > Chat Backup and see if there’s a recent backup you can restore from.
  • Check other apps for similar backup options.
Tips for the Future:
  1. Enable Automatic Backups: Make sure iCloud backup is turned on to automatically back up your data.
  2. Regularly Sync with iTunes: If you prefer local backups, sync your iPhone with iTunes regularly.
  3. Use Multiple Backup Services: Don’t rely on one backup method. Using a combination like iCloud, iTunes, and other cloud services increases your data security.
Handling device crashes and data loss is frustrating, but with these steps, hopefully, you’ll be able to recover your important info. Good luck!
Gotcha. Data recovery after a crash can be a real hassle, but there are a few additional methods you can try beyond what @byteguru suggested:
8. Re-download Purchased Content
If part of the lost data includes music, apps, movies, or books you’ve purchased, don’t forget you can re-download these from the App Store, iTunes Store, or Apple Books. This won’t get back personal content like photos or messages, but it’s still something:
  1. Open the appropriate store app.
  2. Go to your Account > Purchased.
  3. Re-download the items you need.
9. Check App-Specific Data
Many apps store data locally and in the cloud. For instance:
  • Google Drive: If you were using Google Docs or Sheets, your documents might still be safe in the cloud.
  • Notes: If you sync your Notes app with an email account or iCloud, you can recover them manually.
Sometimes a simple app reinstall can bring back lost data if it’s stored in the app’s own cloud service.
10. Enterprise Solutions
For those with more advanced needs, enterprise data recovery solutions like Dr.Fone or Tenorshare UltData offer additional features. They’re not as user-friendly as Disk Drill, but they may provide deeper recovery options at a higher price point. The upside? They sometimes delve into more complex data retention systems. The downside? They can be a bit overwhelming for the average user.
11. Hardware-Based Recovery
In those extreme cases where software solutions fail, professional data recovery services might be necessary. Companies like Data Recovery Group can perform hardware-based recoveries, though these can be expensive and time-consuming. This is really a last-ditch effort for mission-critical data.
Pros & Cons of Disk Drill
  • Pros:
    • Intuitive interface that’s easy to navigate, even for non-techies.
    • Offers a comprehensive scan and recovery process for a wide range of file types.
    • Has a free trial to see if it can find your lost data before you commit financially.
  • Cons:
    • The free version has limitations on the amount of data you can recover.
    • It may not always find everything, especially if the data sectors have been overwritten.
    • Some users feel the pricing is high compared to other solutions.
Keeping Your Data Safe:
Going forward, to avoid these issues, think about employing a multi-layered backup strategy. A mix of cloud (iCloud, Google Drive, Dropbox), local (iTunes/Finder), and external drive backups is ideal. Also, think about enabling features like:
  • Optimize iPhone Storage for Photos: This will keep smaller versions on your phone and full resolutions in iCloud.
  • Message in iCloud: Keep your messages and attachments up-to-date automatically.
12. Regular Backups with Time Machine
For Mac users, integrating your iPhone backups into your macOS’s Time Machine setup will give you automatic, regular backups without much fuss.
In summary, data loss can be a real headache, but with the right tools and methods, most data is recoverable. Disk Drill aligns perfectly with user-friendly recovery needs, but weighing the pros and cons and considering competitors like Dr.Fone can also be wise depending on your specific situation. And, yes, consider mixing various backup services and methods to cushion against such surprises in the future.
I see some great tips here from @techchizkid and @byteguru, but there are a few additional angles you might want to explore.
First up, if you haven’t already done so, consider trying iMazing. It’s pretty similar to the methods mentioned, but sometimes offers a slightly different approach and extra features. iMazing can backup and restore, but also selectively recover specific data, like just your messages or photos without a full device overwrite. Download it here.
Additionally, while @techchizkid mentioned re-downloading purchased content, there’s a trick to this I found useful. If you’ve subscribed to Apple Music or iTunes Match, you can re-download many of your past purchases directly from the cloud, but don’t forget to enable “Show Apple Music” in your Music settings to see everything you have access to.
Next, consider re-calibrating your expectations with DIY data recovery. Not every method is foolproof, and sometimes, professional help might be unavoidable. Companies like DriveSavers offer high success rates for complex recovery situations—just be prepared to potentially pay a significant amount.
One potential caveat to using third-party recovery tools like Disk Drill: Although it’s often effective, there’s no 100% guarantee of recovery, especially if the data sectors were heavily rewritten. For non-professionals, Disk Drill offers an easy-to-navigate UI and a plethora of recovery options. You can dive deeper into it here.
An often overlooked method is to leverage social media backups. If you share a lot of photos or videos on platforms like Facebook, Instagram, or Twitter, you may be able to recover some of your personal media from those sites.
A techie secret: Considering you use a combination of backup methods mentioned by @byteguru (iCloud, local iTunes/Finder), I strongly suggest setting a regular backup schedule. It’s as simple as setting a monthly reminder on your calendar app. Consistency here can save a lot of headaches later.
Last but not least, if you had important documents and personal notes stored in apps like Evernote, Google Keep, or similar cloud-based note-taking platforms, do check there. These apps have robust recovery features and keep deleted files for a period before permanent deletion.
As a rule of thumb to avoid future panics, adopt what I call the “3-2-1 Backup Strategy”:
  1. Keep 3 copies of your data (1 primary and 2 backups).
  2. Store your backups in 2 different formats (such as cloud and external hard drive).
  3. Ensure 1 copy is off-site to safeguard against physical disasters.
Sometimes, encrypted backups can help too, adding an extra layer of safety to sensitive information. In iTunes, under your device’s Summary tab, you can opt for “Encrypt iPhone backup” to ensure your data is secure.
Also, double-check your settings for apps like WhatsApp and WeChat. Often overlooked, these have built-in backup and restore capabilities, which can save critical conversations and media.
Remember, the goal isn’t just recovery after losses but prevention of future losses. Investing a little effort now saves a lot of stress later.
