How To Recover Files From Hard Drive After Deleting Them?
I accidentally deleted important files from my hard drive and realized too late that I still need them. I’m looking for the best way to recover deleted hard drive files before anything gets overwritten, including safe recovery software or steps that actually work.
I wouldn’t freak out yet. I’ve had drives look cooked, then cough files back up once I stopped messing with them. The big thing is this, quit writing anything new to the drive right now.
No installs. No big downloads. Don’t shuffle folders around. When a file gets deleted, the file entry is often gone first, while the raw data still sits there until something else lands on top of it. If you keep using the drive, you make your own recovery job worse.
When software recovery usually works
From what I’ve seen, tools do fine with stuff like:
  1. files deleted by accident
  2. Recycle Bin already emptied
  3. a quick format
  4. a partition going missing
  5. files vanishing after a crash or bad shutdown
Different story if the drive starts clicking, grinding, beeping, or dropping off the system at random. I stop there. Those noises usually mean the issue is physical, and repeated spin-ups tend to make it worse.
A simple first try
If I were starting from scratch, I’d try Disk Drill first. I used it once on an external drive after a sloppy format, and it was easy enough to get through without reading a pile of docs. It handles common cases like deleted files, formatted volumes, damaged file systems, and external HDDs or SSDs. The preview tool helps a lot, since you get to check whether a file still opens before saving it out. On Windows, the free recovery limit is 100 MB.
How I’d do it
  1. Install Disk Drill onto a different drive, not the one where the files went missing.
  2. Plug in the affected drive.
  3. Launch Disk Drill and pick the correct disk.
  4. Hit “Search for lost data.”
  5. Let the scan finish, even if it feels slow.
  6. Use the filters or search bar to narrow things down.
  7. Preview a few files before restoring them.
  8. Select what you want back.
  9. Save recovered files to another drive.
That last step matters more than people think. If you restore onto the same drive, you risk overwriting data you haven’t recovered yet. I’ve seen people do this once, then wonder why half the folder came back broken. Bad day.
Check the easy stuff first
Before you run a long scan, look in the obvious places:
Recycle Bin. OneDrive. File History on Windows. Time Machine on Mac.
I’ve watched people spend an entire evening scanning sectors, then find the missing files sitting in a cloud sync folder. Annoying, but better than gone.
Other tools worth a look
  1. PhotoRec, free and strong, though filenames tend to come back messy and the workflow feels rough
  2. UFS Explorer, solid with external drives, though it leans more technical
When I’d stop doing it myself
If the drive shows physical trouble, or your computer doesn’t detect it at all, I’d skip home recovery tools. At that point, a recovery lab makes more sense. Software won’t repair damaged hardware, and extra attempts sometimes make the lab’s job harder. Learned that one the hard way.
Stop using the drive first. I agree with @mikeappsreviewer on that part 100 percent. Where I differ is this, I would check for backup copies before running any scan at all. People waste hours scanning when the file is sitting in OneDrive version history, File History, Time Machine, or even an app temp folder.
My order would be:
  1. Check Recycle Bin or Trash.
  2. Check cloud sync trash and file history.
  3. Check app autosave folders, Office, Adobe, etc.
  4. If nothing shows up, run recovery software.
For software, Disk Drill is a solid pick because preview matters. If the preview opens, your odds are better. Recuva is fine for simple deletes on healthy drives, but it misses stuff on damaged file systems in my expereince. PhotoRec digs up more raw files, but filenames often come back as a mess. That gets ugly fast.
One more thing people skip. If this is an SSD, TRIM lowers recovery odds a lot after deletion. HDDs usually give you a better shot if you stop write activity fast.
If SMART stats show rising bad sectors or the drive disconnects, stop DIY. Clone it first with something like ddrescue, then scan the clone. Working on the original is how data goes from recoverable to gone.
If you want a clean guide, this thread title says it better: best ways to recover deleted files from a hard drive
Big rule, restore recovered files to a different drive. Same drive recovery is how people wreck thier second chance.
I mostly agree with @mikeappsreviewer and @jeff, but I’d add one thing people skip: check whether the delete was logical or just hidden by the file system before doing a full recovery run.
If the drive is an HDD and still mounts normally, open Command Prompt as admin and run chkdsk X: /f only if you suspect file system errors, not just a normal delete. Sometimes files “disappear” because the index got weird, not because the data is gone. I know some folks hate recommending chkdsk, and fair enough, because on a failing drive it can make things worse. So I would not use it if the disk is making noise, freezing, or dropping offline.
Also, search by file signature and extension, not just folder path. Deleted files often lose original names first. That’s why Disk Drill is useful here, especially for previewing documents, photos, and videos before restoring. Their preview alone saves a lot of time compared to blindly recovering 20GB of junk.
One point where I slightly disagree with @jeff: cloning first is ideal, but for a totally healthy drive with a simple accidental delete, that can be overkill for regular users. If the drive shows even a hint of instability though, yeah, clone first.
I’d also avoid “repair tools” and registry cleaners. Those are how people turn a recoverable mess into a bigger mess. Recover to another disk, then sort later.
If you want a readable Disk Drill review and deleted file recovery walkthrough, that’s worth a look before you click random buttons. It covers how Disk Drill handles deleted files, formatted drives, corrupted partitions, and previews recoverable data, which is the part that actualy matters.
Short version: stop using the drive, verify backups and hidden copies, scan smart not hard, and don’t “fix” the drive before you recover from it. That’s where ppl mess it up.
One angle I think @jeff, @espritlibre, and @mikeappsreviewer only partly touched: if the deleted files were on the system drive, shut the computer down and recover from another OS if possible. Booting Windows normally keeps writing logs, temp files, updates, browser cache, all the annoying little writes that can stomp deleted data. For an internal HDD, I’d rather pull the drive, connect it as a secondary disk or via USB dock, then scan it from another machine.
I also would not jump to chkdsk for plain deletion. That’s fine for directory corruption cases, but for accidental delete, repair tools are solving the wrong problem.
About Disk Drill, it’s a good middle-ground option.
  • easy preview of files before recovery
  • decent filtering by type and size
  • handles simple deletes and a lot of messy logical cases
  • less intimidating than some forensic tools
  • free recovery on Windows is limited
  • deeper scans can return lots of clutter
  • not my first pick for physically failing drives
  • large scans can take a while
My own rule:
  • Healthy HDD, recent delete: Disk Drill first
  • Need free and simple: Recuva
  • Need raw carving and don’t care about filenames: PhotoRec
  • Drive unstable: image/clone first, then recover from the copy
One more overlooked place: antivirus quarantine. I’ve seen “deleted” docs sitting there the whole time. Also check whether the file was moved by sync conflict handling, not deleted. OneDrive, Dropbox, and some NAS apps love making duplicate conflict copies in weird folders.
Big mistake people make is sorting the recovered files on the source drive. Recover first, organize later.
