How to recover deleted items in Outlook?
Accidentally deleted important emails in Outlook and need to recover them. Tried checking the Deleted Items folder but it’s empty. Is there any way to retrieve them? It’s urgent as they are work-related.
Been there, done that! If you’ve already checked the Deleted Items folder in Outlook and it’s empty, don’t panic just yet. You still have a few more options to try before waving goodbye to those important work emails.
Firstly, you should check the Recoverable Items folder. This is like a safety net that keeps deleted items for a bit longer, even if they’ve been cleared from the Deleted Items folder. Here’s how you can access it:
  1. In your Outlook desktop application, go to the Folder tab.
  2. Click on Recover Deleted Items.
  3. You should see a list of deleted items that are recoverable. Select the emails you want to retrieve and click Recover Selected Items.
If you’re using a web version of Outlook (like Outlook.com or Office 365), the process is a bit different:
  1. Go to your Deleted Items folder.
  2. At the top, there’s an option called Recover items deleted from this folder. Click on it.
  3. Browse through the list and select the emails you need to recover, then click Recover.
Okay, if that’s a no-go too, then you might need to roll up your sleeves and use some recovery software. One reliable tool is Disk Drill
. Here’s why you might wanna consider it:
  • User-Friendly Interface: Even if you aren’t super tech-savvy, you’ll find it pretty straightforward to use.
  • Deep Scan Feature: It can dig deep and find those elusive, permanently deleted files.
  • Supports Multiple File Systems: Whether you’re on Windows or Mac, Disk Drill has got you covered.
  • Cost: The free version has some limitations, although it’s definitely worth the investment if you need to recover important emails.
  • Time-Consuming: Deep scans can take a while to complete, especially if you have a lot of data.
To use Disk Drill for Outlook (or any other similar recovery software like Recuva or Stellar Data Recovery), follow these basic steps:
  1. Download and install Disk Drill.
  2. Open the program and select the drive or location where your Outlook data file is stored.
  3. Run a scan. Disk Drill will start searching for deleted items.
  4. Once the scan is complete, browse through the results and look for your Outlook data file (usually it’s a .pst or .ost file).
  5. Select the file and choose to recover it.
  6. After recovery, open this file using Outlook.
Keep in mind that once you recover your .pst or .ost file, some of the emails might not be in the exact order they were before. But hey, at least you’ll have access to them again!
Lastly, be sure to set up some preventive measures to avoid this in the future:
  • Always back up your Outlook data regularly.
  • Use cloud storage solutions that offer version history and recovery options.
  • Set up rules in Outlook to categorize and save important emails in specific folders so they aren’t accidentally deleted.
Hope this helps and you manage to get those critical work emails back!
Recovering deleted items in Outlook can be a real pain, especially when you’ve got urgent work emails to get back. From my experience, there are different strategies you might still try before diving into recovery software.
It sounds like you’ve already checked the Deleted Items folder and found nothing. Well, besides the Recoverable Items folder as @techchizkid mentioned, there’s another trick you could use if you’re working in a corporate environment with an Exchange server. Exchange servers typically have policies for retaining deleted items beyond what you see in Outlook:
  1. Mail Admin Assistance: Ask your system administrator to check the retention policy settings. They might help you retrieve deleted items directly from the server – this can often include emails purged from the Deleted Items folder. IT folks usually have access to tools and settings we regular users don’t see.
  2. Outlook Search:
    Sometimes items get misplaced rather than permanently deleted. Use the advanced search function in Outlook:
    • Click on the Search tab at the top.
    • Use the options under “Search Tools” to expand your search scope to “All Mailboxes” or “All Outlook Items.”
    • Try searching specific keywords, senders, or date ranges to see if the emails show up somewhere unexpected.
  3. Auto-Archive Folders:
    There’s also the possibility that your emails might have been auto-archived based on specific settings:
    • Check the Archive folder in Outlook, usually found in the folder list on the left side.
    • If you have a separate .pst file for Archive, you may need to open it in Outlook using “File → Open & Export → Open Outlook Data File.”
As for recovery software recommendations, if you find yourself needing to go down that path, Disk Drill is definitely a reliable option. But when dealing with company-related content, you might need to follow specific IT protocols or get approval for using third-party software.
Pros & Cons:
  • Disk Drill really is user-friendly, making it less daunting for non-techies.
  • Its deep scan feature can be a lifesaver for finding those hard-to-retrieve files.
  • Be prepared that it can be time-intensive, especially with larger hard drives.
  • As stated, the premium features aren’t free, so weigh the cost against your urgency and the email’s importance.
If you decide to use Disk Drill, here’s a straightforward guide to help you out:
  1. Download Disk Drill from Disk Drill Data Recovery Software.
  2. Install and open the application.
  3. Select the drive or location where the Outlook file (.pst or .ost) is stored.
  4. Run a scan and let it do a deep search.
  5. Review the results and locate your Outlook data file.
  6. Recover the file and then open it in Outlook to access your emails.
Just a quick heads-up: sometimes, after recovery, your emails may be a bit scrambled, but having them slightly disordered is better than losing them entirely.
For long-term preventive measures:
  • Set calendar reminders to back up your files frequently.
  • Utilize cloud storage options that offer automated backups and recovery.
  • Separate crucial emails into dedicated folders to minimize accidental deletions.
It’s always a good idea to discuss with your IT team about setting some of these measures or understanding existing protocols—this way, you’ll have a smoother retrieval process for future incidents.
Hopefully, you find what you need without too much of a hassle!
If @byteguru and @techchizkid’s methods didn’t quite pan out, don’t throw in the towel yet. You’ve still got a shot at snagging those emails back before considering recovery software. Especially if you’re in a work environment with an Exchange server, you’d be surprised by the hidden safety nets in place. Here’s a different angle:
Check the Exchange Server Retention:
Sometimes, big brother (aka your company’s IT department) has retention policies that can help. Deleted items might still be chillin’ on the server even after disappearing from your “Deleted Items” and “Recoverable Items” folders.
  1. Contact IT Support: Tell them you’ve got an emergency. They can access the Exchange Management Shell and might be able to use the “Get-RecoverableItems” cmdlet to retrieve your lost emails.
  2. Exchange Online Protection: If your company uses Office 365, there’s often additional compliance settings and retention policies in place. Your admin can look into their compliance settings and see if the emails are still lurking somewhere.
Microsoft Purview Compliance:
If your organization uses Microsoft 365, there’s a treasure trove of compliance tools. For instance, Microsoft Purview Compliance, a comprehensive data governance solution, facilitates eDiscovery searches:
  • Ask your corporate compliance officer or IT department about running an eDiscovery search. They can search through all the mailboxes for specific deleted items.
Outlook Archiving Settings:
It’s worth poking around to see if Outlook auto-archived your emails. Found that Archive folder sitting there quietly?
  1. Check Archive Settings: Go to “File” → “Options” → “Advanced,” and then check the AutoArchive settings to see where it placed your emails.
  2. Open Archive: You might have to manually open an archive .pst file in Outlook, which can be done by heading to “File” → “Open & Export” → “Open Outlook Data File,” and then selecting the archive .pst file.
Rebuilding OST File:
If you’re dealing with an .ost file (Outlook offline data file), rebuilding it can sometimes pull lost emails out of the ether.
  1. Close Outlook.
  2. Rename the current .ost file: Locate your .ost file (usually in C:\Users<YourName>\AppData\Local\Microsoft\Outlook), rename it by adding .old to the filename.
  3. Reopen Outlook: This forces Outlook to rebuild the .ost file by downloading all items from the server again.
Third-Party Recovery Tools:
Now if these methods are a dead-end, Disk Drill is a solid choice. True, it’s not cheap, but it’s got the chops to get your data back. The steps from @byteguru and @techchizkid cover that in detail already, so I won’t go repeating it.
Disk Drill: Ready to dig deeper? Disk Drill (find it at Disk Drill Data Recovery Software) might be your last resort. It’s one of the more user-friendly recovery tools out there and offers a robust deep scan feature, perfect if your Outlook data files have taken a walk.
Additionally, let’s talk about preventive measures because no one likes this game of hide and seek:
  • Scheduled Backups: Set up periodic backups for your Outlook data. Use tools like Acronis or native Windows Backup & Restore.
  • Third-Party Backup Solutions: Services like Carbonite or Backblaze can back up your entire system, making it easier to restore specific files.
  • Email Rules: Create rules to move important emails to specific folders, reducing the risk of accidental deletions.
  • Cloud Solutions: Use OneDrive or Google Drive’s backup features to keep a synced copy of important files. Outlook also integrates well with these services.
So before you hit total panic mode or contemplate a career in fishing lost emails, there’s still hope down these roads. And if you do need to recover your entire data file using Disk Drill, don’t sweat it; it’s straightforward yet powerful, making the whole ordeal somewhat bearable.
