How to clear cache on iPhone?
My iPhone is running slowly and someone suggested clearing the cache might help. I don’t know how to do this. Can anyone guide me through the steps?
Alright, clearing the cache on your iPhone can actually help it run more smoothly. Here are some steps to do this:
  1. Safari Cache:
    • Open the Settings app.
    • Scroll down and select Safari.
    • Tap Clear History and Website Data.
    • Confirm by tapping Clear History and Data.
  2. App Cache:
    • Unfortunately, iOS doesn’t allow you to clear app caches individually without deleting the app, but you can do the following:
    • Open Settings.
    • Go to General.
    • Select iPhone Storage.
    • Find the specific app that’s using a lot of space.
    • Tap the app and choose Offload App. This will free up space but keep documents and data. Alternatively, you can select Delete App and then reinstall it via the App Store.
  3. Restart Your iPhone:
    • Sometimes, simply restarting your phone can clear out temporary files and improve performance. Hold the power button and slide to power off. Turn it back on after a few seconds.
Just remember, you can’t really clear all caches on an iPhone as you would on some Android devices. But these steps should help with RAM and storage issues slowing down your phone.
You can find more info and updates by checking out this ‘Reddit Tutorial’.
Hey, that’s a solid start Sterrnkijker laid out there, but let’s flip the script a bit with some additional insights. Clearing the cache on your iPhone can indeed help improve its performance. Here’s a different take:
  1. Safari History and Data:
    • While Sterrnkijker mentioned this, I’d like to add: this action will log you out of websites, so make sure to note down any important login info before proceeding.
  2. App Cache:
    • I also agree with the steps provided. A pro-tip here: regularly offloading apps you don’t frequently use can free up tons of space. This way, you keep all your app data without getting rid of the app entirely.
  3. Hard Reset:
    • Instead of a simple restart, try a hard reset. Press and hold both the Home button and the Power button (or Volume Down if you don’t have a Home button) until the Apple logo appears. This can clear out more temporary files.
  4. Clear RAM:
    • Interestingly, you can manually clear the RAM. For iPhones with a Home button, press and hold the Power button until the ‘slide to power off’ screen appears, then press and hold the Home button until the screen goes blank and returns to the home screen. For those with Face ID, enable AssistiveTouch, then follow the steps with the virtual Home button.
  5. Update iOS:
    • Make sure your iPhone is running the latest version of iOS. Software updates often include performance improvements.
Hope these help! Also, sterrnkijker’s shared a good Reddit link, but I recommend checking out ‘this Linkedin tutorial’ for a more comprehensive, step-by-step guide about clearing cache on iPhone.
Remember, it’s not just about clearing cache; regular iOS maintenance can go a long way in keeping your device speedy!
Alright, let’s dive straight into some alternative methods to clear up your iPhone cache and spruce up its performance. Sterrnkijker and techchizkid did a thorough job, but there are a few more tricks up the sleeve:
  1. Settings Reset (Extreme, but effective):
    • Go to Settings > General > Reset.
    • Choose Reset All Settings. This won’t delete your data, but it will revert custom settings to their defaults. A significant, yet non-damaging refresh.
  2. Messaging Apps:
    • Apps like Whatsapp and Messenger store media that piles up. Open the app, navigate to storage/data usage, and clear unnecessary items.
  3. Photo Backup:
    • Long shot, but transferring photos to iCloud or a computer and then deleting them from the device can significantly ease storage strain.
  4. Browser Cache for Third-Party Browsers:
    • If you use Chrome or Firefox, go to their settings and clear the cache directly within the app.
  5. Battery Optimization:
    • Sometimes, battery health can affect performance. Go to Settings > Battery > Battery Health. If your battery health is significantly degraded, it might be causing the slowdown.
Pros and Cons
  • Boosts performance
  • Frees up space
  • Enhances battery life
  • Could sign you out from accounts
  • Might need more frequent maintenance
  • Some methods are quite drastic
Additional Note on Competitors:
  • Techchizkid provided comprehensive guidance for Safari and app caches, while Sterrnkijker brought valuable insights about app offloading. Both offered great starting points, but removing stored media and resetting settings brings an extra edge.
Routine maintenance keeps your iPhone running smoothly. Try out these additional steps and you might just find the balance between performance and storage space.
Use a simple restart routine.
  1. Hold the power button and volume up, then slide to power off.
  2. Wait 30 seconds.
  3. Turn your iPhone back on.
iOS often clears temporary files and reloads system processes after a full reboot.
In tests, a restart improved app launch times by around 10 to 20 percent on older iPhones.
If it still feels slow, restart once a week. This keeps memory fresh without you digging through settings.
