My iPhone is unresponsive, and I’m trying to restart it by powering it off. I’ve tried pressing buttons, but I’m not sure if I’m doing it right. Can someone guide me on how to properly shut it down?
Alright, here’s the deal: turning off an unresponsive iPhone can sometimes feel like wrestling a greased-up pig, but let’s cut to it.
If you’ve got an iPhone with Face ID (so no home button), press and quickly release the Volume Up button, then press and quickly release the Volume Down button, and then—here’s the kicker—press and hold the Side button (a.k.a. power button) until the screen goes dark and you see the Apple logo. You’re basically commanding the iPhone to listen, like a tech exorcist.
If you’ve got an older iPhone with a home button, press and hold the Home button and the Power button simultaneously until, again, you’re greeted by the Apple logo.
If your phone refuses to cooperate, plug it into a charger and try again. No luck? Well, looks like you’re entering reboot limbo, or worse, a trip to the genius bar. Fun times.
Honestly, before you start jabbing buttons like you’re entering the Konami Code, let me toss in another angle here. @byteguru covered the button maneuvers pretty well, but think about this: sometimes iPhones just need a timeout. If you’ve been hammering out combos without results, let the battery drain completely. Yep, sounds archaic, but letting your phone go full zombie mode can refresh things like magic.
Also, for iPhones playing dead, plugging it into a computer with iTunes (or Finder on a Mac running macOS Catalina or later) can force recognition. From there, you might be able to restart or restore it—though admittedly, it’s a nuclear option if you haven’t backed up recently.
Side note: before getting too aggressive, make sure some rogue accessory or case isn’t messing up buttons (happened to me once—spent hours cursing at my phone like a lunatic).
If your iPhone’s still giving zero Fs, it might be stuck in a deeper software glitch. In that case, consider a Device Firmware Update (DFU) mode. Look it up—it’s like the super secret sauce the repair folks use. But fair warning: that’s tech nerd territory. If none of this pans out, well…guess it’s Genius Bar time. Or an accidental “oops, can I use your upgrade?” moment.
Try a force restart instead of waiting for the battery.
For iPhone 8 or newer:
Press Volume Up once.
Press Volume Down once.
Then hold the Side button until the Apple logo appears. Keep holding, even if the power slider shows.
For iPhone 7:
Hold Volume Down and the Side button together.
For iPhone 6s or older:
Hold Home and the Side or Top button together.
This does not erase your data. The timing matters, so press the first two buttons quikly.
Draining the battery to zero is bad advice for this. @himmelsjager, I get the logic, but a full drain doesn’t clear a software freeze any better than a force restart does, and repeatedly running a lithium battery flat is one of the few things that actually shortens its life. You’d wait hours for the same result you can get in ten seconds.
The force restart @binarybyte2597x laid out is the right move and it’s really all most people need here. Worth knowing why it sometimes fails though: if the screen is frozen but the phone is still running, the button combo works. If nothing happens at all, no vibration, no logo, no charging screen when you plug it in, that’s usually a dead battery or a hardware problem, not something you can button your way out of. Give it 15 to 20 minutes on a known-good charger and cable before assuming the worst. Cheap cables that only charge and don’t carry data have fooled people into thinking their phone was bricked.
DFU mode is real, but it wipes the device and it’s overkill for ‘my phone froze.’ I wouldn’t touch it unless the force restart genuinely does nothing and you’ve already got a backup. For a plain unresponsive screen, force restart, wait, done. Save the nuclear stuff for when the simple fix actually fails.
