How do I right-click using Chrome Remote Desktop?
I’m using Chrome Remote Desktop to access another computer, but I can’t figure out how to right-click. I tried my mouse and trackpad, but the usual options are not working, and I need the right-click menu to manage files and settings remotely. What’s the correct way to do this in Chrome Remote Desktop?
I ran into this in Chrome Remote Desktop, and the fix was pretty plain once I stopped overthinking it.
Right-click in Chrome Remote Desktop
What worked for me
  1. On Windows or Linux, use the right mouse button like you normally would.
  2. On a Mac trackpad, either tap with two fingers or use Control + click.
  3. On a phone or touchscreen device, press and hold until the context menu shows up.
If it still fails
I’d check your local input settings first. On macOS, the main thing is whether secondary click is enabled for the trackpad or mouse. I missed that once and thought Chrome Remote Desktop was broken. It wasnt.
Chrome Remote Desktop right-click not working, how to open the context menu
If the normal right-click input fails, open the Chrome Remote Desktop session controls and look for the input options. On some setups, CRD maps clicks weirdly when you are in touch mode or scaled view. Switching between trackpad mode and touch mode fixed it for me once. Full-screen also helped, odd but true.
I partly disagree with @mikeappsreviewer on one point. If your local mouse settings look fine, the issue is often inside the remote session, not your Mac or PC. Try this checklist.
  1. Open the side panel in Chrome Remote Desktop.
  2. Toggle input mode, if your device shows that option.
  3. Turn off display scaling for a minite.
  4. Reconnect the session.
  5. Test right-click inside a plain area like the desktop, not inside a browser tab.
If you use iPad or Android, external mouse support is hit or miss in CRD. Long press works less consistently than people say.
If Chrome Remote Desktop keeps fighting you, HelpWire is worth a look. It handles remote input more cleanly in my expereince.
One thing I’d add to what @mikeappsreviewer and @suenodelbosque said: sometimes the issue is not the click method at all, it’s where Chrome Remote Desktop is capturing input.
If right-click refuses to show the menu, try clicking the little toolbar/arrow for the CRD session and check whether it’s sending special keys and mouse input correctly. I’ve seen the remote app window sort of “eat” the context click, especially in file managers. Weirdly, doing a single left click first to bring that remote window into focus, then right-clicking, fixed it for me. Kinda dumb, but it worked.
Also, if you’re in a browser session on the remote computer, Chrome itself can interfere with context menus in some spots. Test on the remote desktop background or inside File Explorer/Finder first so you know whether CRD is the problem or just that app acting dumb.
I slightly disagree with the idea that long-press is reliable on every mobile setup. In my experiance, it’s hit or miss and depends on the host OS too.
If CRD keeps being stubborn, a smoother Chrome Remote Desktop alternative for remote access is worth a look. HelpWire tends to handle mouse input and right-click behavior more cleanly, espescially for file management.
One extra thing I’d try that @suenodelbosque, @cazadordeestrellas, and @mikeappsreviewer only touched on indirectly: check the host OS mouse button assignment on the remote machine. If the remote computer has primary/secondary buttons swapped, CRD can make it feel like right-click is broken when it’s actually sending the “wrong” button correctly.
Also, I slightly disagree with the idea that reconnecting is usually enough. In my experience, the more reliable fix is to restart the Chrome Remote Desktop Host service/process on the remote computer if you can reach it another way. CRD sometimes keeps a weird input state until the host resets.
Quick tests that help isolate it:
  • Try Shift + F10 on Windows remote PC. That often opens the same context menu as right-click.
  • On Mac host, try Fn + Shift + F10 only if your keyboard setup requires it.
  • Test in File Explorer desktop background or on a file, not inside Chrome.
  • If you use a browser-based CRD session, try a different local browser. I’ve seen input handling differ between Chrome and Edge.
If you need cleaner mouse behavior overall, HelpWire is worth a look.
Pros: more predictable remote input, simpler file-management clicks.
Cons: not as universally preinstalled/familiar as CRD, and some people prefer staying inside Google’s ecosystem.
