How do I restore accidentally deleted text?
I accidentally deleted an important piece of text from a document I’m working on and I’m freaking out. I really need to recover it as it contains crucial information for a project deadline tomorrow. Are there any tips or software that could help me get it back? Any advice would be greatly appreciated!
First things first, don’t panic. There’s a good chance you can get that text back. Here are some strategies you can try:
1. Undo Option:
If you’ve just deleted the text, the simplest option might be to use the Undo function. Most programs allow you to undo the last action. Try pressing Ctrl + Z (Windows) or Cmd + Z (Mac). Alternatively, you can usually find an Undo option in the Edit menu at the top of your screen. This might recover the deleted text if you act quickly.
2. Check for Autosave and Versions:
  • Microsoft Word:
    • Go to File > Info > Manage Document > Recover Unsaved Documents to see if there’s an autosave version of your document.
    • You can also check File > Version History to find an older version.
  • Google Docs:
    • Open the document and go to File > Version history > See version history. You can browse previous versions and recover your deleted text.
3. Temporary Files:
Sometimes, especially with Word or other text editors, temporary files are created as backups. You can search for these files by typing *.tmp or ~$* in your file explorer. Note that these files may not be super easy to read, but they might contain the lost text.
4. Recycle Bin or Trash Folder:
If you were using a note-taking app or text editor that saves your documents, check the Recycle Bin (Windows) or Trash (Mac) to see if the old version or the temporary backup ended up there.
5. Backup Solutions:
Hopefully, you’re using some kind of backup solution. Whether it’s an external drive, cloud service like Google Drive, OneDrive or Dropbox, or even a system restore point from Windows, you might be able to find a backed-up version of your document.
  • Dropbox:
    • Open Dropbox > navigate to the file > click on 'Version history'. This will show you previous versions of the file.
  • Google Drive:
    • Go to Google Drive > navigate to the document > click on 'More actions' (three-dot menu) > 'Manage versions'.
  • OneDrive:
    • Right-click the file > 'Version History'.
6. Text Recovery Software:
Now, if none of these methods work and the lost text is worth the extra effort, you might want to try a data recovery software. Disk Drill
is one of the reliable options out there. It’s straightforward to use, and the software can scan your computer for deleted files, even those that aren’t in the Recycle Bin/Trash anymore. For a detailed guide on how to use it, you can check out Disk Drill Data Recovery Software.
  • How to use Disk Drill:
    • Download and install Disk Drill.
    • Open Disk Drill and run the scan on your storage device (where the document was saved).
    • Once the scan is complete, browse the recoverable items. If you find the document, restore it and check for your missing text.
7. Shadow Copies (Windows):
If you haven’t disabled System Protection, try this route.
  • Right-click the folder where the document was saved.
  • Click Properties > Previous Versions.
  • Select the copy that predates your deletion and restore.
8. Contact IT Support (if applicable):
If the document was created on a work or school computer, your IT department might have backups. They’re often adept at handling data recovery issues, so reach out if you have this resource available.
Lastly, moving forward, consider enabling auto-saves, regularly backing up your work, and maintaining multiple versions of important documents to prevent future mishaps like this. Best of luck!
@byteguru already covered most of the basics pretty well. I’d like to add a couple of additional tricks which could be useful for recovering your text.
1. Copying Clipboard Manager:
A lot of people underestimate how powerful clipboard managers can be. If you haven’t closed the program since the text was deleted, some clipboard managers, like Clipdiary or Ditto, can go through recent clipboard history. You might find your deleted text there. This is especially helpful if you’re someone who copies/pastes a lot while working, as these managers often store multiple entries.
2. Crash Recovery:
You mentioned a project deadline, suggesting urgency and long hours. Most text editors and word processors have a crash recovery feature. Ideally, you’d find this in the same place as autosave, but if your software crashed recently, re-launching might bring back unsaved data. It’s worth a shot.
3. System Restore Engineering:
Bit more technical, but if you’re using Windows, System Restore might come to the rescue. This feature isn’t always proactive in backing up personal documents, but certain settings will return your system to a previous point in time (without affecting your personal files). To find this, navigate: Control Panel > Recovery > Open System Restore. Choose a restore point from a date before you think the accidental deletion happened. Again, this won’t usually affect personal files, but proceed with caution and back up any current projects.
4. Third-Party Cloud Services:
Dropbox, Google Drive, and OneDrive were mentioned by @byteguru, but if you’re using other services like Box or iCloud, they too have versioning features. Make sure you check if these are turned on and look back at earlier versions of your work.
5. Specialized Recovery Tools:
Disk Drill was a great mention from @byteguru: it’s extensively reliable, especially when dealing with larger data losses. Disk Drill does a thorough job of scanning storage devices to find lost data, and here’s a good place to get it: Disk Drill.
6. Consider Enabling File History (Windows):
File History is a helpful Windows feature which can continually back up files in selected folders. This is a preventive measure for the future but useful to set up. Go to Settings > Update & Security > Backup. Turn on File History for peace of mind.
Remember, loss often happens when strains are high and deadlines loom. Moving forward, don’t forget to back up your important docs, use version history religiously, and take advantage of crash recovery tools. If you’re stretched for time right now, installing a lightweight clipboard manager might be a fast and efficient first step.
If you’re panicking, take a deep breath first. You’ve got options to recover your lost text. Here’s a couple of less conventional tips that might help:
  1. Check Recently Closed Files in Software:
    Many applications like Excel, Word, or even Notepad++ have a recent files option. Go to the File menu and look under Recent Documents. You might find a version of your work there that still contains the deleted text.
  2. System Restore vs. File History:
    While System Restore is a good choice, it doesn’t always recover personal files. Instead, look into File History if you’re using Windows. Navigate to Settings > Update & Security > Backup. If File History was enabled, you might recover past versions of individual files more reliably.
  3. Clipboard Managers Are Lifesavers:
    Here’s a pro tip: clipboard managers like Clipdiary or Ditto can indeed be super handy. They store multiple clipboard entries, so even if you’ve copied something else after your text, it might still be lingering in history. Good luck with older recovery solutions, but if you need something simple, clipboard managers can save the day.
  4. Try Safe Mode Recovery:
    If all else fails, boot your computer in Safe Mode. Sometimes, Safe Mode can access files and old state copies that get missed in regular mode. To enter Safe Mode, restart your computer and press F8 (Windows) or hold Shift while booting (Mac).
As for data recovery tools like Disk Drill, I’m a bit on the fence. On the plus side, it’s very user-friendly and capable of deep scans. But it can be a bit pricy and sometimes feels overkill for small recoveries. Alternatives like Recuva or EaseUS Data Recovery Wizard are also worth considering, though they come with their own pros and cons.
Lastly, moving forward, enable version history or autosave features in your tools. This proactive step might save you heaps of trouble next time! (who hasn’t accidentally deleted something important, amirite?)
