How do I recover deleted voicemails on my iPhone?
Accidentally deleted an important voicemail on my iPhone, and I’m really stressed. It had crucial info I need ASAP. I tried checking recently deleted, but it’s not there. Any chance to recover it? Need help urgently!
Hey there, I’ve definitely been in your shoes before and know how stressful that can be. First off, don’t panic yet. Let me walk you through a few options that might help:
  1. Carrier Voicemail System: Sometimes, voicemails aren’t completely wiped from the carrier’s server end. You can try calling your voicemail using another phone or directly through your iPhone’s dialer (long-press 1) to see if it might be accessible there. Any saved or old messages might still be retrievable directly through them. Depending on your carrier, they might have a backup.
  2. Backup Restore via iCloud or iTunes: If you have backups of your phone data (which includes voicemails) via iCloud or iTunes, you can revert your device to an earlier point in time when the voicemail was still there. Be cautious with this approach because it will overwrite current data, so make sure you back up your current state first.
    • iCloud: Go to Settings > General > Reset > Erase all content and settings. Set up your iPhone again and select “Restore from iCloud Backup.”
    • iTunes: Connect your iPhone to your computer, open iTunes, and select Restore Backup under the Summary tab.
  3. Third-Party Recovery Tools: This might be your best bet if the above methods don’t pan out. Tools like Disk Drill
    can be really handy for retrieving lost data on your iPhone. It’s pretty user-friendly and has good recovery rates for deleted files, including voicemails.
    • You can get Disk Drill from CleverFiles. Once you install it on your computer, follow the prompts to scan your iPhone for any recoverable data.
    Keep in mind, anything that interacts with your phone’s data should be done carefully, as it can inadvertently overwrite the data you’re trying to recover.
Sometimes these voice messages cling to your device in ways you wouldn’t expect, and a good recovery tool might be able to sniff them out. Good luck, hope you get your critical voicemail back!
Hey, just jumping in here. While @codecrafter gave some solid advice, let’s mix it up a bit.
If checking with your carrier or restoring from a backup doesn’t pan out, there’s an alternative route. Visual voicemail services sometimes store backups invisibly. You could look into contacting Apple Support directly, either via Apple Support chat or by visiting a nearby Apple Store. Surprisingly, they might have some internal ways to assist you, though it’s sometimes hit or miss.
On the topic of third-party recovery tools, Disk Drill is indeed a popular choice but don’t forget about competitors like PhoneRescue or Dr.Fone. They all have slightly different interfaces and recovery rates. Disk Drill’s upper hand is it’s user-friendly interface and extensive file recovery capabilities, but beware—it can be pricey for the pro features, and like all recovery software, it doesn’t guarantee 100% success.
In terms of technical details, remember: the more you use the phone after deletion, the higher the chance the voicemail data gets overwritten. So, minimize your iPhone usage until you’ve tried all recovery tasks.
Good luck, really hoping you get that voicemail back!
So you’ve got a missing voicemail and you’re stressed out? I get it, been there, done that. Let’s continue where @techchizkid and @codecrafter left off without rehashing the same steps.
Let’s think outside the box a bit:
  1. Dig in Settings: Sometimes iOS has hidden gems. Go into your Settings app, navigate to Phone, and then check Voicemail. Play around with turning Visual Voicemail on and off. It’s a long shot, but toggling this can sometimes refresh your voicemail retrieval system.
  2. Contact Apple Support Directly: This ties in with what @codecrafter suggested but with a twist. Instead of just contacting them, make an appointment at an Apple Store. Face-to-face services can sometimes offer a level of assistance that phone or chat just can’t match. When there in person, the technicians have a bit more flexibility and tools at their disposal to maybe revive your lost voicemail.
  3. Siri Shortcut: Have you played around with Siri Shortcuts? You can try creating a Shortcut to check voicemail and see if Siri can locate an archived version somewhere. Again, it’s a gamble, but Siri sometimes has layers to her capabilities we’re unaware of.
  4. Carrier Apps: Check if your carrier has a dedicated app for voicemail. AT&T, Verizon, T-Mobile, they often have unique ways to store and access voicemails. An app reset or re-login sometimes jogs the system into showing you mail that was thought to be deleted.
  5. Social Engineering: Okay, don’t freak out by the term, but it often works. If traditional methods with customer support fall flat, try being really persistent. Ask for escalation until you reach someone who has the power to check deeper into your account. Customer support agents sometimes miss things that their supervisors can access.
Regarding third-party tools, I agree with @techchizkid on using Disk Drill. But! There are some caveats. Disk Drill does advertise itself as a comprehensive solution for lost data recovery. Here’s the link to learn more Disk Drill Data Recovery Software. Now, while it’s a good tool, I must emphasize the use-case logic here: It’s mostly effective if the voicemail data wasn’t overwritten. Minimize phone use until you’ve run the recovery operation.
  1. iMazing Alternative: iMazing is another tool similar to Disk Drill but sometimes works better for specific data retrieval scenarios. It’s slightly different in operation and could offer a fresh angle if Disk Drill doesn’t work out for you.
On a more technical note, the way iPhones handle data post-deletion is peculiar. iOS marks space previously occupied by deleted data as available but doesn’t immediately wipe it. This means, theoretically, that voicemail data may still exist on your device’s storage in fragments. However, the more you use the phone, the more these fragments get overwritten.
Lastly, the stress this situation brings is substantial. It’s crucial to practice some ‘digital hygiene’ going forward. Regularly back your voicemails up, not just through iCloud or iTunes, but also consider emailing important voicemails to yourself as MP3 files for redundancy.
It’s a race against the clock with data recovery for sure, but I’m hopeful these additional steps provide avenues you might not have explored yet. If none of these work, it might indeed be time to see what options Disk Drill or other such software bring to the table.
Crossing my fingers for ya! Check each lead, minimize usage, and tread carefully with data restoration methods. Hope you get that voicemail back asap.
Try the carrier voicemail menus. Hold 1 or dial your number. On Verizon dial *86, on AT&T hold 1. Enter your PIN. Listen to promts for Deleted Messages or Advanced Options. Many systems keep deleted items for a short window. Open Deleted Messages. Select the voicmail. Press 9 to save, or the restore key named in the promts. This works even when iPhone shows nothing. Move fast.
