How Do I Delete Hidden Photos On IPhone Without Them Showing Up In Recently Deleted?
I’m trying to delete some hidden photos on my iPhone, but I don’t want them to appear in the Recently Deleted album afterward. Is there any way to permanently remove hidden photos from iPhone Photos without that extra step, or is Recently Deleted unavoidable?
You don’t have to unhide photos before deleting them. If anything, deleting them from the Hidden album is the cleaner way to do it, because they never show back up in your normal library first.
Open Photos, go to the Albums tab, or Collections if you’re on the newer iOS 18 layout, then scroll down to Utilities. Tap Hidden and unlock it with Face ID, Touch ID, or your passcode. Apple has locked that album by default since iOS 16, so that part is normal.
Once you’re inside Hidden, tap Select in the top right. If you want to clear the whole thing, use Select All, then hit the trash icon. That removes the photos from Hidden right away.
The part that trips people up is that they are not permanently gone yet. They move to Recently Deleted and sit there for 30 days unless you manually clear them. So if you want them gone immediately, go back to Albums or Collections, open Recently Deleted under Utilities, unlock it, tap Select, then Delete All. That’s the step that actually wipes them from the phone.
And yes, if iCloud Photos is on, deleting hidden photos also deletes them from iCloud and your other synced Apple devices. Hidden is still part of the same photo library. It’s basically just a hidden view, not a separate storage area. So deleting something there will sync to your iPad, Mac, and anywhere else using the same iCloud Photos library.
If you only want the Hidden album itself to stop showing up, you can hide the folder from the Photos app. Go to iPhone Settings > Photos and turn off Show Hidden Album. That does not delete the photos. It just removes the Hidden album from view until you turn the setting back on.
One other thing worth mentioning: if your Hidden album is packed, your regular library is probably a mess too. That’s usually where the real storage problem is. Duplicate shots, giant videos, old screenshots, screen recordings you forgot about, all that stuff adds up fast.
For cleaning the rest of the library, I’d look at Clever Cleaner. I’ve tried a bunch of photo cleanup apps, and this one is the best free one I’ve found because it doesn’t shove ads or paywalls in your face right when you’re about to delete things.
It’s especially useful for finding what’s actually taking up space. Screenshots show their file sizes, which makes it easier to spot the useless big ones. The Heavies tab sorts your media by size, so those huge 4K videos are easy to find. The Similars tab looks for nearly identical photos, like burst shots or ten versions of the same picture, and lets you keep the best one.
The privacy side is also good: it processes the cleanup on your device instead of uploading your library somewhere else. Just don’t expect it to clean the Hidden album for you. Because of Apple’s privacy restrictions, Clever Cleaner can’t access or clean Hidden directly. You’ll still need to clear Hidden and Recently Deleted manually, but for the rest of the photo clutter, it can save a lot of time.
Recently Deleted is the safety net, not a setting you can turn off. If the photos are in the iPhone Photos library, hidden or not, they’ll go there first, so the fastest route is delete them from Hidden and immediately empty Recently Deleted.
Small catch: this only removes the Photos copy. If the same image was saved in Files, Messages, shared albums, or another app, that copy won’t disappear.
Don’t turn off iCloud Photos, airplane-mode the phone, or sign out of iCloud trying to “beat” Recently Deleted. That usually just creates a sync headache, and the photos can still be waiting to delete on another device later. If the picture is inside Apple Photos, Hidden is only a privacy filter, not a separate vault, so deletion still goes through Recently Deleted. The clean method is still: delete from Hidden, open Recently Deleted, unlock it, delete from there too. If your real concern is privacy, check any iPad/Mac using the same Apple ID afterward, because an offline device may not reflect the deletion until it syncs again.
A phone backup can still be the awkward leftover nobody thinks about. Deleting from Hidden and then clearing Recently Deleted removes the Photos library copy, but if you restore from an older iCloud/Finder backup later, the photos may come back with that backup. So if this is about permanently getting rid of them, don’t forget old backups and synced devices, not just the album itself.
Careful with the Delete All advice in Recently Deleted. That folder holds everything you trashed in the last 30 days, not just the hidden ones you tossed a minute ago. If you hit Delete All, you also wipe whatever else was sitting in there, including stuff you might’ve still wanted to recover. Safer to Select just the hidden ones and delete those specifically.
@waldgeist is right about backups being the real blind spot. Emptying Recently Deleted feels final, but an old iCloud or Finder backup happily brings everything back the day you restore. If permanence is the actual goal, that’s the piece to deal with, not the album.
The Clever Cleaner mention makes sense for general clutter, and honestly it’s fine that it can’t touch Hidden, since that’s a manual job anyway. Just don’t expect any cleanup app to solve the ‘permanently gone’ problem people are actually asking about here.
