How can I use a serial port device in a virtual environment?
I’m trying to connect and use a serial port device from inside a virtual machine but keep running into issues. The device isn’t recognized or the connection fails. Has anyone managed to get serial port devices working reliably with virtual machines, and are there step-by-step solutions or software recommendations that could help?
I’ve wrestled with this exact headache way too often: trying to get a physical serial port device to play nice inside a virtual environment. Half the time the VM just stares back at me like “nope, what COM port?” Here’s the rundown of how I finally cracked it—no magic, just brute trial and error.
  1. Check your VM platform settings: VMWare, VirtualBox, and Hyper-V all have settings for adding a virtual serial port. But just adding “COM1” often isn’t enough—if you want to hook up a real device, you usually need to connect the VM’s virtual COM port to your actual hardware port, or even better, create a virtual bridge.
  2. Device Passthrough: Sometimes you can directly pass through a host’s physical COM port to the VM. On VirtualBox, for example, you add a serial port and set it to “Host Device” and specify something like /dev/ttyS0 (Linux host) or COM1 (Windows). But do not expect miracles: drivers are finicky, and timing issues love to crash the party.
  3. Serial-to-Ethernet Magic: If you want this to just work, look at a tool like Serial to Ethernet Connector. Basically, it lets you share a serial port over the network, and your VM (even if it’s on another machine entirely) can connect to it as if it’s local. Total life saver when hardware gets stubborn or your VM host doesn’t even have a physical COM port. Here’s a solid option that explains how to use serial ports inside a virtual machine.
  4. Driver Woes: Some devices refuse to cooperate unless they see exactly the right driver and interface. If your device needs a fancy driver, install it inside the VM as if you’re on native hardware… assuming your VM’s hardware mapping isn’t busted.
  5. USB-Serial Adapters: Don’t overlook using a USB-serial adapter. Most VM managers can pass USB straight to the guest OS. Way less drama than poking at legacy COM ports, unless your software is really crusty.
  6. Firewall/Permissions: Don’t forget the basics: check permissions, VM guest additions, and whether your Windows/Linux guest is even allowed to see new hardware.
It’s really about how your virtual platform handles peripheral passthrough. Sometimes it’s plug-and-play, sometimes it’s reboot-and-pray. If you keep running into brick walls, that Serial to Ethernet Connector app is a game changer, no kidding.
On the clarity front, if you’re searching for info about connecting COM ports to virtual machines, this guide for seamlessly integrating serial ports in VMs lays things out in simple English and might be worth a look.
Not gonna lie, serial-over-VM is where “it works on my machine” became a lifestyle. The folks above nailed most of it, but here’s some bits from the trenches:
Pros for Serial to Ethernet Connector? It’s weirdly painless, you get to map remote physical serial ports anywhere, and it even plays nice when you shift the VM across different hosts. Sweet for hardware hacking, ancient cash register support, or if your IT team quarantines all actual hardware in one server room. Big win: sidesteps a LOT of driver drama (which @boswandelaar and @himmelsjager both ranted about).
Cons? It’s not FOSS, so if your workplace is allergic to paid/licensed stuff, tough luck. Sometimes, the network can introduce a small delay—like, microseconds, but enough to trip up ultra-sensitive gear. Oh, and you’re trusting another app layer—if that hiccups, boom, comms are gone.
One not-yet-mentioned move: use a PCI/PCIe serial card in the host and see if your hypervisor (VMware ESXi, Proxmox, etc.) supports full PCI passthrough. It’s not always perfect—some chipsets flake out—but when it works, it’s the lowest-latency option next to bare metal. Worth a shot before going all-in on virtual bridging.
Other competitor methods like socat or advanced QEMU configs can be powerful but come with a learning curve and more chances to script yourself into a corner. Use those resources for edge cases, tight budgets, or true Linux masochists.
TL;DR: Serial to Ethernet Connector is boss for remote, multi-VM, or cross-platform serial port trickery. But if latency or open-source is your gospel, keep tinkering. And never trust a “plug and play” label—they lied.
