How can I retrieve mistakenly deleted WhatsApp messages?
I accidentally deleted some important WhatsApp messages. They had essential information I really need. Is there a way to get them back? Any advice or solutions would be greatly appreciated!
It’s frustrating to lose important WhatsApp messages, but there are a few ways you might be able to recover them. Here’s a rundown of methods you can try to get those crucial messages back:
Restore from a Backup
  1. Google Drive Backup (Android):
    • WhatsApp backs up chats daily to Google Drive if you’ve set it up. To restore, ensure that the Google Account used for backup is added to your device.
    • Reinstall WhatsApp and verify your number. Once prompted, tap ‘Restore’ to restore your chats and media from Google Drive.
    • Note that this process will overwrite all current messages with the backup version.
  2. iCloud Backup (iPhone):
    • For iOS users, WhatsApp chats are often backed up to iCloud provided you’ve enabled the feature.
    • Uninstall WhatsApp from your iPhone, then reinstall it from the App Store.
    • Confirm your phone number when prompted, and WhatsApp will prompt you to restore chat history from iCloud.
Remember, the major caveat is that these backups need to be proactive. They need to exist before you deleted the messages. Also, restoring from these backups will revert your entire WhatsApp history back to the backup date, meaning you might lose more recent messages.
Local Backup (Android)
  • WhatsApp makes a local backup on your phone every night. These are stored on your device and saved up to 7 days, depending on your settings.
  • Using a File Manager or connecting your phone to a computer, navigate to /sdcard/WhatsApp/Databases. Here, you’ll find local backup files like msgstore.db.crypt12.
  • Rename your chosen backup file from msgstore-YYYY-MM-DD.1.db.crypt12 to msgstore.db.crypt12.
Then:
  • Uninstall and reinstall WhatsApp.
  • When prompted to restore, select the file you renamed.
This can be a bit more technical and shouldn’t be your first option, but it’s effective if you lack recent cloud backups.
Data Recovery Software
If the above methods fail you, you can step up your recovery game by using data recovery software. ‘Disk Drill’ can be incredibly useful for this purpose. Here’s how it works:
  • Download and install Disk Drill: Disk Drill Data Recovery Software
  • Connect your phone to your computer or insert the SD card into the computer if you’re using one.
  • Open Disk Drill and let it run a scan on the storage drive where WhatsApp stores its data.
  • It can locate files that were deleted but can still be recovered.
Disk Drill is pretty handy because it digs deeper into your phone’s storage to find traces of deleted files that haven’t been overwritten yet. People often forget or don’t realize that deleted files are usually not immediately removed but rather marked for deletion, allowing tools like Disk Drill to recover them if acted upon quickly.
Tips and Tricks
  • Automatic Backup Settings: Ensure you have a routine backup strategy moving forward. Adjust your WhatsApp settings to back up daily to avoid any future mishaps.
  • Local Backup Copies: Periodically copy your local backup to an external drive or cloud storage as a secondary precaution. Keeping diverse backups can save you a lot of hassle.
  • Recover Media Files Separately: If your main concern is media files, you might find them under WhatsApp/Media folder in your file manager or even in your device’s main gallery.
Act quickly, as older data is more likely to be overwritten by new data, which can drastically reduce the chance of successful recovery. Each minute counts when it comes to data recovery, so start with less intrusive methods (like cloud backups) and move on to more intensive ones (like Disk Drill) if necessary.
I hope this helps and that you can recover those essential messages!
Disk Drill is an option many people recommend, but personally, I’ve found it a bit hit or miss. Of course, it’s nice to have that as a last resort, but bear in mind, data recovery software like Disk Drill may not always guarantee the recovery of deleted WhatsApp messages, especially if new data has already overwritten the old data. So, really, your success rate could also depend on how promptly you act after realizing a deletion mistake.
Another thing to consider is the cost; while Disk Drill is powerful, it can be somewhat pricey for full usage. Compared to competitors like Recuva or EaseUS, Disk Drill often stands out for its more user-friendly interface. However, in terms of performance, I’ve seen similar results with its competitors, albeit sometimes requiring a bit more fiddling.
One more tip I think everyone should know is to check if you’ve archived your chats instead of deleting them. Go to Chaprs > Archived. A surprising number of people overlook this step and panic when the, chats are just tucked away.
Also, remember that third-party recovery tools can bring some risks, especially if privacy is a concern. They dig deep into your device’s storage and to some extent, you’re trusting them with your personal data.
Lastly, on Android, try looking into Helium Backup or even Titanium Backup if you’ve rooted your device. Both provide more robust backup solutions but come with their complexities. And remember to periodically backup and even manually check your WhatsApp’s media folder, to save any crucial media files to another location. Proactivity will save you future headaches.
So, while Disk Drill is legit, balancing its use with the immediacy and type of data you’re aiming to recover might lead you to simpler solutions first.
Hey, you might wanna add to those great suggestions with another slick trick.
WhatsApp Logs and Notifications Center
Believe it or not, sometimes you might catch spontaneous logs or even notifications that could come in clutch! For instance, Android users can check their device’s notification log. This is more like a moon chance, but sometimes partial message data lingers here.
  1. Notification Log (Android only):
    • Go to ‘Settings’, then ‘Apps & notifications’.
    • Tap ‘Notifications’ and then ‘Notification history’.
    • If enabled, you’ll see recent notifications which can include WhatsApp messages you deleted but peeked at previously.
Cloud Backups Settings
Sometimes, folks miss that Google Drive or iCloud might have incremental backups, not just one static one. Dive into the specifics—Google Drive settings on your PC or iCloud settings on your iPhone. This isn’t standard some years back, but if enabled, you have versions. It’ll allow granular recovery, based on when the messages were still kicking around before getting zapped.
When it comes to Disk Drill, it’s solid, don’t get me wrong. You can snag it at Disk Drill. It deep-dives into your device as mentioned and restores all kinds of deleted files. However, rather than just disk drill, you might wanna contrast it with other recovery software like Tenorshare UltData or dr.fone. They can be pricier but are also designed specifically with message recovery in mind.
Ugh, almost forgot, if you’re adept with scripts and have rooted your Android, SQLite database browsing is an option albeit tech-heavy. Your message database file ‘msgstore.db’ often keeps vestiges of deleted convos that you can manually extract using a ScriptKit-Browser.
Don’t sleep on the manual approach either. Sometimes, WhatsApp media files might still linger in your standard gallery even when the chat message poofs. Dive into the storage directly from your file manager and see those WhatsApp images or videos might give you the clues you need.
One more wild card trick - WhatsApp support. If it’s worth a shot, hit them up. Probs not an immediate turnaround, but I’ve seen cases where they’ve swung a bat for background extraction of logs, albeit this is far from guaranteed.
Remember, often it’s about the timing. The fresher the deletion, the better shot you have at recovery. Act swiftly and balance your attempts between automatic tools and some manual snooping.
