How can I recover deleted text?
I accidentally deleted an important text file and really need to get it back. It had crucial information for a project I’m working on. Is there any way to recover it?
First things first, stop using the device where the deleted file was stored. Continuing to use it can overwrite the space where that deleted file is still existing, making recovery more complicated or sometimes impossible.
Here’s a step-by-step guide to get that deleted text doc back:
  1. Check the Recycle Bin: If you haven’t done this already, open your Recycle Bin and see if the file is still there. Right-click and ‘Restore’ if you find it.
  2. Previous Versions in Windows: If you’re using Windows, you can try restoring the file to a previous version. Navigate to the folder where the file was stored, right-click, and select ‘Restore previous versions’. This might bring back an earlier version of the file.
  3. Temporary Files: Sometimes text editors create temporary files while you’re working on a document. Check if there are any temp files with your document’s name in your temp folder. You can access the temp folder by typing %temp% in the Windows search bar.
  4. Recovery Software: If those steps didn’t help, it’s time to use some recovery software. I’ve had good experiences with Disk Drill
    (https://www.disk-drill.com/). It’s pretty straightforward and powerful when it comes to data recovery, supporting different file types and storage devices. They have a version for both Windows and Mac, which is handy.
Using Disk Drill:
  • Download and install Disk Drill from the provided link.
  • Open the application and select the drive where your text file was deleted from.
  • Click on ‘Search for lost data’ and let the software do its thing.
  • Once the scan is complete, look through the recovered files and check for your missing text file.
  • Select it and click ‘Recover’.
Remember, the key is to act quickly and avoid putting more data on the device to prevent overwriting.
If you’re on a Mac, Time Machine backups can be a lifesaver here too. If your project was backed up, you might be able to restore it from there. Just open the folder where the file was, enter Time Machine, and go back in time to when the file existed.
Lastly, let’s talk about prevention. Regularly back up your important files to avoid these situations. Cloud services like Google Drive, Dropbox, or even OneDrive, offer automatic backups, and it’s easier to recover files that way.
Hope this helps!
So, there’s still hope even if you’ve tried the conventional methods suggested by @codecrafter and found no luck. Let’s explore a few other angles here:
5. File History vs. Previous Versions
Everyone overlooks File History on Windows. If you’ve enabled it, you should definitely check File History instead of just relying on “Restore previous versions”. Go to Control Panel > File History and select ‘Restore personal files’. If enabled, it works better than the clunky Previous Versions feature.
6. Command Prompt to the Rescue
Sometimes the simplest methods are the best. Open a Command Prompt (Press Win + R, type “cmd” and press Enter), and try using some old school commands:
chkdsk C: /f
Replace ‘C:’ with the relevant drive letter. It might just bring the deleted file out of the shadows.
7. System Restore
System Restore is often considered only when you have big problems, but you can use it to roll back your system to a previous point in time. If the file was there when the restore point was created, you have a chance. Access it through Control Panel > System and Security > System > System Protection > System Restore.
8. Third-Party Recovery Tools
If Disk Drill isn’t cutting it (although, it’s really solid), try some alternatives which are equally capable:
  • Recuva: Made by the same folks behind CCleaner, Recuva is a robust and user-friendly tool.
  • EaseUS Data Recovery Wizard: This one’s heavy-duty. It always makes waves in the data recovery community.
  • PhotoRec: If you’re tech-savvy, this is a command-line based powerhouse that digs deep into recovering files.
Bonus: Something for the Cloud Users
If your text file existed in any cloud-synced drive like Google Drive, OneDrive, or Dropbox, even for a short time, all these services have ‘Version History’ or ‘File Recovery’. For Google Drive, right-click on the file and select ‘Manage versions’. On Dropbox, check the ‘Deleted files’ in the menu or the version history feature.
Disk Drill Revisited
Disk Drill is highly effective and a go-to for many people when it comes to recovering files. If you need a powerful tool that supports all file types, even the sneaky ones, Disk Drill is your best bet. Here’s where you can get it: Disk Drill Data Recovery Software. Make sure you follow the instructions carefully.
Last Resort: Professional Help
When all else fails, data recovery services employ specialized techniques like using cleanrooms to recover data from severely damaged drives. But keep in mind, this can be expensive. Consider this as a measure of last resort if the data is absolutely irreplaceable.
Preventive Measures
@codecrafter already mentioned backups, and it’s worth stressing. A daily backup routine could save hours of headache. Use external drives, NAS, or cloud solutions. Automate it wherever possible so you don’t forget.
Hopefully, you won’t need to go through all these methods. Best of luck getting your text file back!
First things first, if you’ve already tried the methods outlined above by @byteguru and @codecrafter without success, there’s still room for more tricks and tools outside the standard procedures.
Get into Your Unallocated Space
One thing often overlooked is that deleting a file doesn’t erase it, it merely marks that space as available. Therefore, you can scan your unallocated space (space that was formerly used by the deleted files) with more advanced recovery software or manually if you’re up for a challenge. That’s where utilities like TestDisk come into play.
TestDisk is powerful and open-source but can be less user-friendly than Disk Drill. But if you’re geeky enough, this could be your savior. The downside is that it requires deeper technical knowledge.
Go Nuclear with Data Recovery
When using Disk Drill or similar tools, go through all the available recovery modes. Most tools offer different levels like Quick Scan, Deep Scan, and even more intense scanning routines. Disk Drill’s Deep Scan is particularly powerful but can be time-consuming. A pro of Disk Drill is it’s straightforward user interface, which is super useful if you aren’t a tech wizard. However, the major con is that complex operations can sometimes miss files or mislabel them, so triple-check everything it recovers.
Filesystem-Specific Tools
Different filesystems (NTFS, FAT32, EXT4, etc.) often have recovery tools tailored to them. For example, Photorec (as mentioned by @byteguru) supports a multitude of filesystems and file types and can be a lifesaver especially if you have a UNIX-based system. Yet again, it requires a good level of comfort with command-line interfaces.
Virtual Machines and Disk Images
An interesting trick is to use a Virtual Machine or to clone your drive and work on that clone. This entirely avoids any further overwriting risks. Tools like Clonezilla can clone your drive, and then you can run recovery operations on the clone, keeping the original drive untouched. It’s a bit of a hassle, but it’s a bulletproof method if your data means the world to you.
Database Can Hold More Than Data
If your text file was interacting with any sort of software that logs data (including basic version control systems like Git if you used it for coding projects), there might be recoverable metadata. Database backups or logs could have snapshots or echoed pieces of your lost text file. Though unwieldy, it’s worth an investigation.
Extra Recovery Tools
There’s also MiniTool Power Data Recovery and Stellar Data Recovery. Both carry a stellar reputation in data recovery circles. They’re kind of middle-ground in terms of functionality and user-friendliness compared to Disk Drill and TestDisk.
Cons: They can be pricy, but the GUI might be worth it if you’re not super techy.
Professional Recovery
While costly, professional data recovery services use specialized hardware and cleanroom environments that go way beyond what software can do. These services could involve hardware-level data reconstruction, which is something consumer-level tools can’t compete with.
Manual Method for Text Files
Here’s more of a hands-on, last-ditch attempt: use a hex editor to manually search for remnants of the text file. This method is highly technical but can be a nerdy last resort. Tools like HxD or WinHex can help you sift through the binary data on your disk. It’s cumbersome but not impossible.
Prevention is the Key
It’s apparent but must be reiterated: regular backups are king. For data that’s critical, employ a multi-tiered approach: local storage, cloud backups, and even physical media. Services like Backblaze offer extensive, automated backup solutions for a reasonable price, or use Google Drive and OneDrive which have robust version histories.
Remember, the sooner you act after deletion, the better your chances. The more you write data to the drive, the lesser the likelihood your file exists in a recoverable form. Good luck, and remember - periodically yelling at your computer screen is also a form of data recovery!
Check the app’s autosave and temporary-file folders first. This is faster than scanning the drive.
On Windows, press Win+R, enter %temp%, then sort files by “Date modified.” Search for part of the filename or open recent.txt,.tmp, and.bak files in Notepad.
Also open Notepad and check Recent files. If you used Word, enable “Recover Unsaved Documents.”
On macOS, check Finder’s Recents and the app’s AutoRecovery folder.
Save any matching file to another drive immediatly. Search by content if the filename has chnaged.
