Help with Seagate data recovery?
My Seagate external hard drive just stopped working, and I can’t access any files. I have important documents and family photos on it. Does anyone know how to recover data from a Seagate drive that isn’t being recognized? Any advice on software or services?
Hey, sorry to hear about your Seagate drive issues. It’s definitely a bummer when a storage device just decides to stop working. There are a few steps you can try to get your data back:
Firstly, make sure your drive really isn’t being recognized. Try a different USB port or even another computer. Sometimes, it’s a simple connection issue.
If that doesn’t work, you might want to try booting into safe mode or using a live boot of Linux. Sometimes these methods can force the computer to recognize the drive. You can also check the Disk Management tool on Windows (just type “disk management” into the search bar) to see if the drive shows up there. It might just need to be re-partitioned or reformatted.
In case the drive is showing up in Disk Management but isn’t accessible, you could try some data recovery software. One program I’ve had good luck with is Disk Drill
. It’s pretty user-friendly and supports a variety of file types. You can find more info about it here: Disk Drill Data Recovery Software.
Disk Drill can scan the corrupted or non-recognized drives and might be able to pull your files back. They offer a free version so you can see if it detects your files before committing to anything.
Remember, these things can take a while depending on the size of your drive and the amount of data on it. Be patient and let the software do its thing.
If none of this works, you might be dealing with a hardware failure. In that case, using professional data recovery services could be your last resort. But keep in mind, they can be pricey depending on the level of damage and the complexity of recovery.
Good luck, and I hope you get your files back soon!
Multiple possibilities exist to recover data from a Seagate external hard drive, especially when it is not being recognized by your system. Building on @byteguru’s suggestions, let’s explore a few more methods and tools.
Firstly, if your Seagate drive doesn’t show up in Disk Management or File Explorer after trying different ports and computers, there’s a possibility it could be a driver issue. Check Device Manager (type “device manager” in the search bar) to see if there’s an exclamation mark next to your external drive. If there is, you might need to update or reinstall the device drivers. Uninstalling the device from Device Manager and then reconnecting it can prompt Windows to reinstall the drivers, which sometimes fixes the detection issue.
In addition to safe mode or a Linux live boot mentioned by @byteguru, you could try using a different operating system. If you have a Mac available, connect the Seagate drive to it to see if it gets recognized there. Often, different file systems can be handled better across different OSes.
Now, if you’re tech-savvy, you might want to try opening the drive enclosure to access the bare drive and connect it via a different USB-to-SATA adapter or directly to a desktop’s SATA port. This step is only for those comfortable with hardware tinkering, as it can void your warranty and might cause further damage if done improperly.
When it comes to data recovery software, Disk Drill is indeed a solid option and often highlighted for its ease of use and effectiveness in scanning for lost files. However, it’s definitely worth noting that it might not be the best for every scenario. Disk Drill offers a free version which allows you to scan and preview files, but actual recovery might be limited, prompting you to pay for the full version if successful.
From personal experience, R-Studio and Recuva can be powerful alternatives. R-Studio, particularly, stands out for its thorough and detailed scanning capabilities, but it comes with a steeper learning curve and is pricier. Recuva is more user-friendly and cheaper but might not be as effective in recovering files from severely corrupted drives.
One thing @byteguru mentioned but deserves emphasis is the patience required during the data recovery process. These software solutions can take several hours to days depending on your drive’s size and condition. Disk Drill and its competitors typically offer a range of settings that allow you to refine your scan — quick scans for recent deletions or deep scans for more comprehensive recovery.
Pros for Disk Drill:
  • User-friendly interface
  • Supports a wide range of file types
  • Free trial version to assess drive contents before purchasing
Cons for Disk Drill:
  • Full recovery features are locked behind a paywall
  • Might not be as thorough in deeply damaged drives
Lastly, if none of these methods work, and especially if there’s a physical failure (like strange noises coming from the drive), professional data recovery services might indeed be your next step. These services often have cleanroom environments to handle drive components safely and use advanced techniques to recover data from severely damaged drives. But keep in mind, these can be very costly, easily running into hundreds or even thousands of dollars depending on the extent of damage and the amount of data.
For less severe issues, sometimes moisture or mild short-circuits inside the external drive’s enclosure can cause temporary failures. In such cases, there have been anecdotes of users bagging their drives in airtight bags with silica gels and exposing them to low-humidity environments for a few days, although this is certainly not a guaranteed fix and should be a last-ditch effort before seeking professional help.
Fingers crossed you get your cherished documents and photos back without it breaking the bank!
Firstly, sorry to hear about your data loss; that’s always a bummer. If you’ve already tried different ports and computers like @techchizkid suggested, and still no dice, then you might want to consider a few additional steps.
One thing to try is using a different USB cable. Sounds too simple, right? But you’d be surprised how often the cable can be the culprit. USB cables can wear out over time or have some other undetected issues. Especially since external drives often come with these proprietary cables that aren’t exactly the sturdiest.
Regarding OS variations, connecting your Seagate drive to a Mac or another Linux machine can sometimes yield fruitful results. Macs especially handle external hard drives differently due to their unique file systems like HFS+ or APFS. Even a buddy’s Chromebook might give you some data back!
If your drive still isn’t recognized, pay some attention to physical factors. Sometimes, external drives can experience issues due to simple things like overheating. Let your drive cool down if it’s been in continuous use for a long time, then try reconnecting it.
But let’s say none of that works. It’s time to go deeper. You might wanna try using a different recovery software that’s a bit on the techie side. @byteguru mentioned Disk Drill, which is a solid recommendation for its user-friendly interface and wide support for different file types. If you wanna give it a try, you can find more about it on their website here: Disk Drill. Their free version lets you scan the hard drive and see if your files can be recovered before committing to a purchase. Definitely worth a shot if you’re not ready for professional services yet.
For a more hands-on approach, you could consider using a utility called TestDisk. It’s free and open-source, which is always a plus. TestDisk is excellent for recovering lost partitions and making non-booting disks bootable again. However, it does lack the user-friendly GUI that Disk Drill offers, so be ready for a bit of command line action. But hey, if you’re a bit tech-savvy, it’s a powerful tool.
And about the idea of opening the drive casing that @techchizkid brought up? That’s solid advice only if you’re comfortable with it and your warranty’s already out the window. Some Seagate cases can be notoriously difficult to crack open without damaging the drive inside. Alternatively, a different USB-to-SATA adapter can sometimes bypass the problem altogether.
Speaking of hardware tinkering, sometimes there are anecdotes about putting the hard drive in a ziploc bag and freezing it overnight. This can sometimes realign the read/write head long enough to pull some essential files off it. Sounds super hacky and risky, but when you’re desperate, it’s worth a shot.
And, of course, professional data recovery services should be the last resort. They can be pretty pricey but come with higher success rates, given they have the tools and expertise to handle even physically damaged drives. Honestly, if your drive is making strange noises, like clicking or grinding, stop using it immediately and consult a pro. Using it further can cause more harm.
Remember, future you will thank you for keeping backups of backups. Consider those cloud storage solutions out there. They’re a lifesaver when physical drives inevitably fail.
Good luck, and hope you get your precious files back!
