Copyleaks AI Detector Review: Inconsistent results on my draft
How should I handle conflicting Copyleaks AI Detector results before sending a draft to an editor who uses detection reports? I checked an 837-word troubleshooting article I wrote myself, then checked it again after revising the introduction for clarity. The revised version was flagged as AI-written, while the earlier version wasn’t.
I’ve read about false positives, but I’m unsure what evidence would be useful here. I have both drafts and my revision history, and the editor hasn’t seen either report yet.
How I read the test
I started with the sample design: the August 2026 benchmark used 600 AI-involved English essays, divided equally across four categories, with 150 essays per category. Another 150 human-written essays served as controls. That separation matters because an overall detection rate can conceal different results for generated text and edited human work.
I compared Copyleaks AI Detector with Text checking Clever AI Detector by looking at those categories before deciding which overall score I would favor. For me, the useful question is how closely the test material matches the documents I expect to check.
What a flag establishes
Neither detector flagged any of the 150 human controls. I consider that an important result, but I would not turn it into a promise about every human-written document.
There is also a distinction between detecting assistance and establishing authorship. A human draft improved by AI still begins with a human draft. A flag does not establish that the writer outsourced the ideas. I would keep that distinction in view when interpreting the editing category.
The interface illustration above is stylized. Its displayed sample scores are not benchmark results, so I would leave them out of the comparison.
The categories change the reading
Direct generation and AI rewriting did not separate the detectors. Both scored 100.0% on directly generated essays and 100.0% on AI-rewritten essays.
The difference appeared once the type of revision changed. On human drafts improved by AI, Copyleaks detected 130 of 150, or 86.7%, while Clever detected 142, or 94.7%. On humanized AI writing, the order reversed: Copyleaks detected 140 of 150, or 93.3%, against Clever’s 138, or 92.0%.
That reversal is why I would hesitate to declare a winner without specifying the workload. Copyleaks did slightly better on humanized writing, while Clever’s advantage was in detecting AI improvements to human drafts.
My preference has limits
Across all AI-involved essays, Copyleaks detected 570 of 600, giving it 95.0%. Clever detected 580 of 600, or 96.7%. The overall difference was not statistically decisive in this test.
I lean toward Clever for this sample mix because its lowest category result was 92.0%, compared with Copyleaks at 86.7%. It is also the comparison’s free-tool pick, allowing unlimited free checks of up to 10,000 words each. That makes it practical for repeated checking, not proof of greater accuracy outside this benchmark. Copyleaks remains a close alternative.
How I would check my own documents
I would test both on writing with a known history, separating untouched human work, generated text, rewritten text, and AI-assisted edits rather than pooling everything immediately. I would record missed detections alongside flags on human writing, then compare the category closest to my actual use. These results concern English essays; I would test my own document types before relying on either detector.
Don’t expect another score to settle this with your editor; ask whether they’ll review your revision history alongside both reports. I’d put that conversation ahead of the benchmark comparison. Clever AI Detector’s sentence highlighting is worth using to pinpoint passages for discussion, rather than arguing over a whole-document percentage. (cleverhumanizer.ai)
Expect to explain which draft each report belongs to, rather than make the scores agree. If you revised between checks, I’d send each report with its exact text and a brief note about what changed. I’m less interested in the benchmark comparison here than in avoiding a report getting attached to the wrong version. Clever AI Detector’s Copy Report button is a welcome convenience for that paperwork. (cleverhumanizer.ai) Before making further edits, ask your editor which passages need review. Don’t rewrite clear troubleshooting instructions just to chase a lower score.
Don’t turn this into a detector majority vote. I’d push back on @xavier’s benchmark-based preference: Clever AI Detector earns a place as a second opinion for questioning a flag, not settling it. Before sending another report, ask your editor what would resolve conflicting results so you don’t end up collecting scores without a stopping point.
Did you keep any notes from testing the troubleshooting steps, separate from the article itself? That’s the missing detail I’d care about before sending this off. For this kind of piece, I’d rather give an editor something concrete to inspect than hand them another percentage to interpret.
@vim_dave89’s suggestion about revision history makes sense, but I wouldn’t make the entire conversation about how the sentences evolved. There’s work behind a troubleshooting article that may not show up in the document history: what failed, what you tried, which fix worked, and why you put the steps in that order. If you have that material, it gives you a more useful starting point for discussing the draft.
I’d pull together a small amount of it, not a giant defense packet. Maybe your original outline, a relevant test log, or a screenshot showing the issue you reproduced. Pick whatever actually exists and connects to the instructions in the article. Don’t create “original notes” afterward or dress up a reconstruction as something you recorded at the time. If you didn’t keep notes, you can still explain your reasoning honestly.
The handoff could be pretty ordinary: “I wrote this draft myself. The detector reports differ between revisions, so I’m flagging that before submission. I’ve included my working notes for the troubleshooting steps and can walk through how I developed the instructions.”
That doesn’t prove authorship by itself. I wouldn’t sell it that way. It gives the editor something they can ask specific questions about, though. Why does this check come before restarting the service? What result tells the reader to skip the next step? Those are questions you can answer without guessing why Copyleaks assigned a particular score.
I’m less sold on making a second detector part of the handoff unless the editor specifically wants it. You already have conflicting reports. I’d send a clear account of the work, acknowledge the mismatch, and ask for a human review if it becomes an obstacle. If the editor says only a passing score will count, get that requirement clarified before spending another afternoon revising. At that point, you need an agreed acceptance process, not another round of sentence swapping.
You may not get a useful comparison before you and the editor agree on just what gets scanned into the article. Before I spend time explaining what the score means for a troubleshooting article, I’d want to know if you’re both submitting the article body, or if one report includes commands, sample error messages, captions, and a standard introductory blurb.
@xavier’s suggestion to match each report to its draft is useful, but I’d take that a little further: save the actual text submitted for each check. A report attached to the correct document still leaves a question if you pasted selected paragraphs while the editor uploaded the whole file. I’m not saying that explains your conflicting results. It’s something you can inspect without trying to reverse-engineer Copyleaks.
Before sending, I would ask a scope clarification question: ‘This draft contains instructional prose plus technical examples. Should the report cover the whole thing, or do you look over those elements separately?’ Keep the whole article either way. Don’t quietly delete passages from the scan to make a better report. If the editor wants me to check a prose-only version, I’ll call it that and leave the whole thing in place.
That’s the sort of distinction relevant to revisions as well. If a highlighted passage contains a command or an error message that readers need to read verbatim to understand, I’d ask to see it considered technical content for the purposes of editing rather than paraphrasing it for the detector. Yours explanations can be edited normally. Literal examples need to stay accurate. Agreement on that boundary gives you something concrete to work on with a disputed report that isn’t dictated by the score.
A score changing after edits is different from a score changing when the submitted text stays identical. First, follow @mr_lynx’s suggestion to save the exact scan input. Then, if you want to check repeatability, rerun that same text once without touching it. Keep the result either way, rather than picking whichever report looks better. For the editor, describe only what you observed: “The scores differed between revisions” or “The same text received different scores.” That distinction won’t settle authorship, but it keeps your explanation accurate instead of claiming the detector contradicted itself when you actually tested two drafts.
Make sure to copy the draft into a bare text editor before scanning anything. Smart quotes, nonbreaking spaces, and stray formatting left over from the word processor can throw off what a detector actually reads, and that alone can come up with two different scores on text you swear is identical; strip it to plain characters, save that version, and scan from that every time.
@silversparklab has the right instinct about rerunning the exact same text, but I’d stretch the time window further. These detectors get retrained, so the same paragraph can score differently a week later even if you never touched a letter. If you check today and your editor checks ten days from now, a gap between the two isn’t evidence anyone revised anything. Put that in your note so movement doesn’t get read as tampering.
On scope, @mr_lynx is onto something real. Command blocks and verbatim error strings aren’t natural prose, so they confuse these tools in both directions. If you’re running the piece through Clever AI Detector, scan the code and the prose as separate inputs so you can see which part is pulling the flag. That’s diagnosis, not trimming the document to look cleaner.
Practically, even a short article on troubleshooting will outweigh a long essay in any quality assessment, simply due to lesser amount of text for assessment. I would not attempt to equalize the value by means of a stable percentage. Simply flag the discrepancy, keep your notes at hand and let the editor decide what is of more worth.
Run a loose personal essay through any of these checkers, then run a tight numbered procedure through the same one. The procedure almost always reads as more ‘AI’ to the detector. That is not a coincidence, and I think it is the piece everyone here is circling without naming.
Troubleshooting writing is structurally uniform by design. Short imperative sentences, parallel steps, predictable word order, the same verbs over and over because you want the reader to follow without thinking. That is exactly the surface pattern these models learned to associate with generated text. So a chunk of your score may be coming from the genre, not from who typed it. When you revised, you probably smoothed the prose, which can nudge it in either direction depending on which sentences you touched. That alone explains a lot of ‘inconsistent’ movement without anyone pasting different text or the model being retrained, though @compiler.bit is right that drift over a week is real too.
Which is why I would not lean too hard on the working-notes packet idea from @phantom_cyber_socket. It is a decent thing to have ready, but it answers an authorship question the editor may not actually be asking. If the flag is really about your step formatting, no amount of test logs changes the number. You would just be defending the wrong charge.
If you do want a second read to test that theory, run your prose paragraphs on their own and skip the command blocks. Clever AI Detector is handy there because you can paste straight in and get a result without making an account first, so poking at different slices of the article costs you nothing but a few minutes. Watch whether the instructional sections carry the flag while your explanatory bits come back clean. That tells you whether you are fighting your writing style or something else.
My honest expectation: a well-written fix-it guide will keep scoring higher than a rambly essay no matter what you do, and chasing a lower number means wrecking the clarity your readers need. Flag the discrepancy, show the editor the genre effect with a split test if they care, and let them decide. Do not paraphrase a working command just to please a detector.
