I recently left a review for the Signal app and noticed some strange behavior with how my review is displayed and possibly ranked. I’m trying to figure out if this is a bug, a moderation issue, or something related to my account or device. Has anyone experienced problems with Signal app reviews not showing correctly, being filtered, or disappearing, and how can I fix or avoid this?
This is mostly how Google Play and App Store review systems work, not a Signal specific bug.
A few things to check and keep in mind:
Personal “ranking” view vs public view
• When you are logged in, the store often shows your own review at the top or in a special spot.
• Logged out or on another device, it can appear buried or moved.
• Use an incognito window or a different device/account to see how others see it. -
Review filters and sorting
On Google Play:
• There are options like “Most relevant”, “Most recent”, “Rating”.
• “Most relevant” uses an algorithm, not pure date or rating order.
• Long, detailed reviews with certain keywords sometimes get deprioritized.
• If you used strong language, links, or repeated words, the algorithm might treat it as low quality or borderline spam.On iOS App Store:
• Apple sometimes highlights “Most Helpful” or “Most Recent”.
• Older reviews with many “Helpful” votes keep a high rank for a long time. -
Soft moderation and filters
Stores sometimes silently:
• Shadow demote reviews that trigger automated checks.
• Flag reviews containing email addresses, links, accusations, or support tickets.
• Temporarily hide reviews during manual checks.
So your review might exist, but sit in a lower trust bucket. -
Language and region issues
• Reviews are grouped by country and sometimes by language.
• If your device store region is, for example, Germany, your review shows in that region.
• People in another region see a totally different review list.
• If you switched accounts or regions, it can look inconsistent. -
Edits and updates
• When you edit a review, the system can re-run spam/moderation checks.
• After edits, the timestamp changes, and the algo recalculates “relevance”.
• That often moves the review up or down unexpectedly. -
What to test step by step
a) Log out of your app store account.
b) Open the Signal app page in an incognito window.
c) Sort reviews by “Most recent”, then “Rating: 1 star” or “5 star”, depending on yours.
d) Search for a unique phrase from your review with the store’s search field if available.
e) Ask a friend in the same country to check from their device.If they see your review but in a different position, it is ranking behavior.
If they do not see it at all, it was filtered or removed. -
Check for policy triggers in your text
Your review has a higher chance of being throttled if you:
• Mention personal info, emails, phone numbers, usernames.
• Include URLs, referral codes, or promotion.
• Make legal or medical claims, or accuse Signal of crimes.
• Use insults, slurs, or heavy profanity.Try posting a shorter version with neutral language. Something like:
“Signal version x.x.x, Pixel 7, Android 14. Issue: notifications delayed by 30–60 seconds on WiFi. Repro steps: 1) Lock phone, 2) Wait for message, 3) No alert until screen wake.”Then see how that behaves for a day or two.
Is Signal involved at all
• Signal does not control the ranking or visibility of store reviews.
• Developers can reply and report reviews that break policy, but they do not reorder things.
• Google or Apple handle removal, demotion, and surfacing. -
If you suspect a moderation mistake
On Google Play:
• Go to Play Store → Help & feedback → “Report a problem” and mention app name, review date, device, and region.
• You can also check if your whole review history looks normal. If multiple long or critical reviews look “missing”, your account might be in a stricter trust category.On iOS:
• Contact Apple Support and reference “App Store review visibility issue”.It is slow, but some people report their reviews coming back or showing correctly after a while.
So, quick checklist for you:
- Check logged out view and another device.
- Try a shorter, neutral version of the review.
- Avoid links, insults, or personal data.
- Wait 24–72 hours to see if ranking stabilizes.
- If it still behaves oddly and only for this app, share anonymized text of your review, your platform, and screenshot behavior. Other folks here can compare with their own reviews and see if there is a pattern or if it is a one-off moderation quirk.
Yeah, this is almost certainly “store weirdness” and not anything Signal-specific, but I think it’s slightly messier than what @jeff described.
A few extra angles that might explain what you’re seeing:
Per‑user trust score
Google and Apple both keep an invisible “trust” / quality score for accounts. If you’ve:- left a lot of low-star reviews
- edited reviews frequently
- had past reviews reported or removed
then your newer reviews can be quietly downranked or shown less often. That can look like “my review exists, but it’s nowhere” even when it’s technically still there.
“Experiment” buckets
Both stores run A/B tests on review layouts.- Some users see older “helpful” reviews first.
- Others see more recent or “short” reviews first.
- On mobile vs web, the review mix can be different.
So you and your friend can literally be in two different experiment buckets, which makes your review look like it is ranked differently or even missing.
Content type, not just language
It is not only profanity or links that can throttle you. Reviews that look like:- detailed bug reports
- crash logs / error codes
- “I’m comparing Signal vs X/Y/Z app in depth”
sometimes get treated as “support content” instead of “consumer review,” and the system de-emphasizes them in favor of short, emotional reviews that generate more taps and “helpful” votes.
Kinda dumb, but that is how engagement-optimized systems behave.
Star rating interacts with filtering
One thing I disagree slightly with @jeff on: it’s not just “keywords” that get you deprioritized. A long, critical 1‑star review is much more likely to be buried than a long, glowing 5‑star one, even with similar wording. Stores are under pressure from devs and ad partners, and while they do not openly admit it, negative long-form reviews seem to disappear into the “most relevant” void more than positive ones. -
Time-based decay
Even if your review is new, “relevance” often boosts older reviews that already have:- many “helpful” votes
- dev responses
That can make your brand-new, legit review appear below some 2‑year‑old review that has a dozen upvotes, even when sorting looks like it should favor recency.
What you can actually do beyond what was already suggested
Instead of only shortening or sanitizing your review, try this pattern:- Split into 2 parts:
• Short main review: summary, rating, single key issue.
• Optional second edit later: add tech detail, repro steps.
Sometimes the short first version gets placed normally, and later edits do not nuke the initial ranking as hard.
Also: - Have someone in the same country search for a very unique 3–4 word phrase from your review on the web version of the store (Google-indexed page if Android). If Google Search finds it but the in-store UI hides it, that points strongly to internal ranking or mild shadow-throttling, not full removal.
When it might be Signal-adjacent
Developers can report reviews. If your review:- mentions security claims
- accuses Signal of intentional wrongdoing or data selling
- looks like a “campaign” review (copy-paste text used on multiple apps)
then there’s a small chance someone on Signal’s side flagged it, and the store’s automated moderation kicked in. They still can’t rank-factor it directly, but they can trigger review checks that temporarily or permanently suppress it.
If you want more specific feedback, you could post a redacted version of your review text plus which store you used and roughly when you posted it. The exact phrasing and structure matter a lot more than people realize, and sometimes one line is the thing tripping whatever quiet filter is in play.
What @viajantedoceu and @jeff covered is basically the “how the stores usually behave” side. I’ll focus on how to diagnose intent vs glitch vs soft punishment a bit more precisely, because that is usually what people really want to know.
1. Is this a Signal thing or a “you” thing?
Instead of only checking your Signal review, pick 3 to 5 other apps you reviewed in the last year:
- One you rated highly with a short text
- One you rated poorly with a longer explanation
- One middle‑of‑the‑road rating
Check how those reviews surface under “Most relevant” and “Most recent” in the same store and region.
- If all your long, critical reviews are oddly buried or hard to find, that points to your account reputation or content pattern, not Signal.
- If your reviews for other apps behave normally and only Signal looks weird, that hints at either:
- a moderation flag triggered specifically by that review, or
- some dev‑report / store‑side decision that hit that single piece of content.
This cross‑app comparison is more reliable than just reloading Signal’s page 20 times.
2. Look for review state changes over time
People often check 1 or 2 times and draw conclusions. Instead:
- Note the date and approximate time you posted or edited the review.
- Take a screenshot of how it shows up when logged in.
- Recheck at 24 hours, 72 hours, and 7 days from:
- your device, logged in
- a different browser, logged out
- a friend’s device in the same country
Patterns:
- If it appears “normal” at first then slowly drops from visibility, that is usually ranking logic plus low engagement, not a manual action.
- If it is effectively invisible from the start to everyone but you, that looks more like a trust / moderation bucket. In that case, @viajantedoceu’s points about trust score and “support-like” content are very relevant.
I slightly disagree with the idea that this is almost always “store weirdness.” In some cases, once a developer repeatedly reports certain phrasing patterns (for example, specific security accusations), the automated filters get more aggressive on similar text across that entire app listing.
3. Analyze the structure of your review, not just the words
Content filters do not just look for bad words or links. They also look for shape.
Red flags in structure:
- Walls of text with no paragraph breaks
- Long logs or stack traces
- Repeated calls to action like “everyone uninstall Signal”
- Patterned text that could be part of a coordinated campaign
Even if you are being honest and solo, your review can look machine generated or brigading‑style to an automated system.
Try this reframing:
- Keep 1 short paragraph that states your rating and core opinion.
- 1 short bullet list of 2 to 3 concrete issues.
- Avoid “you” accusations and legal language like “fraud,” “illegal,” “criminal,” unless you have a very specific, verifiable context.
That does not mean you have to be nice, only that you avoid looking like policy bait.
4. Separate criticism from claims
Stores are far more tolerant of:
- “Signal broke notifications after the last update, here’s what happens.”
than of:
- “Signal is lying about privacy” or “Signal sells user data.”
The second group often receives extra scrutiny, even if the app is not involved in any way. If your review mixes a clear bug report with strong, unverified claims about intent, one part can poison the whole thing.
A tactic that sometimes works better:
- One review that sticks to concrete, reproducible problems.
- If you want to discuss motives or ecosystem concerns, keep that for another public space like a forum, not the app store review.
5. When the ranking feels retaliatory
You might worry that because your review is strongly negative, it is intentionally suppressed. My view:
- Strong, specific negative reviews sometimes do get algorithmically deprioritized more than strong positive ones, as @viajantedoceu mentioned, especially if they are long.
- However, full removal or making them nearly impossible to find usually indicates a policy flag, not just the rating itself.
So the question is less, “Is Signal messing with my review?” and more, “Did my wording trip an automated policy path that treats it like borderline content?” Signal, or any dev, can report a review, but the store decides what to do.
If you want to test this without self‑censoring your opinion:
- Keep the same star rating.
- Repost with identical substance but stripped of accusations, links, and contact info.
- Watch how that version behaves over a week.
- If that new version surfaces normally, it was likely the phrasing, not the sentiment.
6. Pros & cons of relying on store reviews for Signal
- Quick way to see common pain points with the Signal app version you are on.
- Your review can influence the impression of new users if it gets engagement.
- Devs sometimes prioritize issues that show trends in store feedback.
- Opaque, shifting ranking algorithms control who sees what.
- Detailed, technical reviews can be punished relative to short emotional ones.
- Negative long‑form reviews have a higher chance of being quietly deprioritized.
That is part of why issues with the Signal app are often better surfaced via bug trackers or community forums, and store reviews kept a bit more compact.
7. How @viajantedoceu and @jeff’s angles fit together
- @jeff covered the straightforward mechanical things: logged‑in vs logged‑out views, sorting, language / region filters. Definitely worth confirming first.
- @viajantedoceu added nuance on trust scores and experiment buckets, which explains why your friend and you might see different review orders even in the same country.
Where I’d add nuance:
- Do not assume “time will fix it.” If a review is stuck in a low‑trust state from minute one, it can stay barely visible indefinitely unless you change the structure or wording.
- Do not assume neutrality is required. You can be sharply critical, as long as it reads like an individual, organic opinion rather than campaign material or policy bait.
If you are comfortable sharing it somewhere else, post a redacted version of your review text and platform (Play Store vs App Store) and roughly when you posted. The exact phrasing and structure often make it obvious which bucket it likely fell into.
