Can someone help me with Swipey Ai?
I started using Swipey Ai and ran into issues I can’t figure out on my own. Something changed while I was setting it up, and now it’s not working the way I expected. I need help troubleshooting Swipey Ai so I can get it working again and avoid making the problem worse.
Start with the boring stuff. Most Swipey AI setup issues come from one of 5 things.
  1. Wrong workspace or account.
    Log out. Log back in with the same email you used at signup. People end up in a diff account more often than they think.
  2. Browser junk.
    Open it in Chrome incognito. If it works there, clear cache, disable extensions, espeically ad blockers, and try again.
  3. API or integration broke.
    If you connected OpenAI, Stripe, Zapier, Notion, whatever, disconnect it and reconnect it. Check for expired keys, wrong permissions, or a plan limit.
  4. Saved settings changed.
    Look for defaults. Tone, output format, team permissions, automation triggers, publishing targets. One flipped toggle is enough to mess up the whole flow.
  5. Credit or usage limit.
    A lot of AI tools fail silently when credits run out or rate limits hit. Check billing and usage first.
Best way to isolate it:
  1. Create a fresh test project.
  2. Run the simplest prompt.
  3. Add integrations one by one.
  4. Note the exact step where it fails.
If you post the exact error message, what changed, and whether this is web app or extension, people here can be way more specific. Right now it sounds like setup drift, not total breakage.
I’d add one thing to what @andarilhonoturno said: don’t assume it’s a “bug” just because the output changed. A lot of these tools quietly switch modes, templates, or onboarding presets after the first run, and suddenly you’re testing a different workflow without realizing it.
What I’d check next:
  • Look for a hidden “template” or “campaign type” setting. Swipey-style tools often behave totally different depending on whether you picked ads, emails, social, etc.
  • Check if your prompt/history got overwritten. Sometimes the app saves a bad draft as the new default. Annoying as hell.
  • Compare one old working output vs one broken output. If the structure changed, it’s probly a config issue, not a system failure.
  • If there’s a team/shared workspace, see if someone else changed permissions or brand settings.
  • Export or screenshot every current setting before changing more stuff. Otherwise you end up chasing your own tail.
I slightly disagree with “just reconnect integrations first.” If things broke during setup, I’d verify the core app works with zero extras before touching API stuff. Less noise, faster answer.
If you can post:
  • what exactly changed
  • what you click before it breaks
  • what you expected vs what it does now
then people can narrow it down way faster. Right now it sounds like setup state drift, not Swipey being fully busted.
