Can anyone suggest alternatives to COM port emulator?
I’m looking for reliable alternatives to COM port emulator software because it keeps crashing on my system. I need something that can help me virtualize serial ports for testing and device communication. If you’ve found other tools that work well, please share your recommendations and experiences. Thanks!
Honestly, I’ve been through the virtual serial port emulator chaos too and totally get why you’d want something other than COM port Emulator—especially with random crashes and general flakiness. Shoutout to @mikeappsreviewer for a solid breakdown of com0com (if you like pain) and the other option that’s less retro-wrestling.
But real talk: there are a few more tools with solid reputations when it comes to serial port virtualization. Have you ever tried Virtual Serial Port Driver? Not to be confused with Virtual Serial Port Emulator, this one is by Electronic Team. It doesn’t require wizard-level registry hacks and is pretty reliable for pairing, splitting, and creating virtual COM connections. The GUI is very modern, and it’s been rock-solid for most Windows setups I’ve thrown at it. Supports all typical data rates, handshake variations, etc. Not free though, so if cost is a dealbreaker, this one’s in the “my sanity is worth a license fee” zone.
Some folks are still fans of the old-school Null-modem Emulator (by FabulaTech), but I honestly found it a little clunky and not as stable when running multiple instances at once. YMMV, especially on newer Windows 10/11 installs—it sometimes fights with driver signing requirements or defender.
If you’re not strictly on Windows, you could give Socat a whirl for Linux/Mac, but it’s all command line. Handy for network-to-serial bridging or if you want to script complex tests, but not exactly the friendliest option unless you’re comfortable with shell scripts.
I wouldn’t totally dismiss free stuff, but at this point with serial port emulation, stability trumps saving a few bucks. If you want click-and-go, UI-based stability (and tech support that isn’t a 15-year-old forum post), check out Virtual Serial Port Driver. If you still want to browse, take a look at advanced Windows serial port simulation tools—some great comparison charts and honest breakdowns.
Just my experience: nothing kills a debugging session faster than an emulator that randomly vanishes or freezes mid-test. Invest in something that won’t crash just because you sneezed.
If anyone’s using something even simpler—or has gotten these to work on ARM-based setups—please chime in. Always curious if there’s a new player I missed.
Honestly, while @mikeappsreviewer did a deep dive into com0com and Virtual Serial Port Emulator, there’s another contender in this dogfight they didn’t mention: Virtual Serial Port Driver by Electronic Team. I know, sounds a bit similar to the one above, but this is a different beast.
Real talk: Virtual Serial Port Driver is pretty rock solid when it comes to virtualizing RS232/422/485 ports, and isn’t restricted to single-use-case workflows (i.e. not just for the serial nostalgia crowd running hyperterminal at 9600 baud). What’s nice is its support for creating unlimited pairs, merging ports, splitting, port bundles—seriously, if you want to get nerdy with port mapping for automation or complex device simulation, this one gets out of your way.
And just a heads-up: even if VSPE feels slick and com0com is old-school-hacker-chic, neither really matches the level of seamless Windows integration and diagnostic logging the Virtual Serial Port Driver offers. It doesn’t throw a fit with recent Windows updates (can’t say the same for com0com… had a whole morning ruined once).
Also, the app actually manages to avoid the clunky UI disease a lot of serial tools get. If you want a bit more technical edge and hate manual registry witchcraft, it’s worth a look. The only caveat? Yeah, it ain’t freeware—but if flaky emulators are eating your dev time, that’s the cost of avoiding endless troubleshooting.
To get straight to it, check out how Virtual Serial Port Driver could streamline your workflow. Not reinventing the wheel, just making it round.
P.S.: Loopback testing and port sharing just work, even under heavy loads—try that with com0com if you’re a masochist. Not to throw shade (well, maybe a little).
