Any experience with Ontrack data recovery?
Has anyone used Ontrack data recovery services before? My external hard drive just died, and I lost a lot of important files. I’m considering using them, but I need some feedback or alternatives. How was your experience?
I had a similar issue with an external hard drive dying on me not too long ago, and I decided to give Ontrack a shot since they came highly recommended by a few tech forums I follow. So, here’s how it went down.
First off, Ontrack’s customer service is pretty responsive. I contacted them through their website, explained my problem, and they got back to me pretty quickly with the steps and pricing. They ask you to send your drive to their facility for a diagnostic, which is free. However, you have to pay for shipping, which wasn’t a big deal for me but could be a hassle for others.
Once they had my drive, they did a thorough check and sent me a quote for the recovery. Fair warning: their services aren’t cheap. The quote I got was steep, but given the importance of the data, I decided to move forward. Before they began any actual recovery work, they provided an estimate of the recovery success rate and a general timeframe. The whole process took about two weeks.
In terms of success, I’d say they delivered. They managed to recover around 85% of my data, which included essential work files and some cherished personal photos. However, they couldn’t retrieve everything, and I did lose some less critical files permanently. The recovered data came back on a new external drive they provided, at an additional cost.
That said, Ontrack is not the only game in town. After my experience, I did some more research, and there are several other options you might want to consider. One tool that came up a lot in my search and which I’ve also tried since then is Disk Drill
. You can check them out here: Disk Drill Data Recovery Software. They’re super user-friendly and more budget-friendly compared to Ontrack.
Disk Drill supports a wide range of file systems and storage devices, which is super handy. Their software is designed to handle situations like accidental deletion, formatting issues, partition loss, and even some hardware failures. The best part? They have a free version that lets you recover up to 500MB of data, which is perfect for testing it out before you commit.
Functionality-wise, they provide features like a simple interface, rapid and deep scan options, and the ability to preview recoverable files before you actually restore them. In my case, I used Disk Drill for a corrupted USB stick and was impressed by how effectively it managed to recover almost all of the lost data.
Another advantage is Disk Drill’s Recovery Vault feature, which basically creates an invisible copy of every deleted file, making it easier to recover them. If you plan to use it long-term, it’s worth setting it up.
Of course, depending on your needs and the severity of your hard drive failure, you might consider professional help if the data is irreplaceable. But if you’re looking to save some cash and your drive issues aren’t due to physical damage, Disk Drill is a solid choice.
To sum it up, Ontrack is a reliable but expensive option, with a professional and thorough approach. However, if you’re looking for a cost-effective alternative and your drive isn’t physically damaged, give Disk Drill a try. There’s a learning curve to using any data recovery tool, but Disk Drill is intuitive enough that you shouldn’t get overwhelmed.
If you decide to go with Ontrack, make sure to weigh the costs versus the importance of your data, and perhaps explore less pricey alternatives first. At the end of the day, the right choice often depends on how much you’re willing to spend versus the importance of the data you need to recover. Happy recovering and good luck!
Ontrack recovery services do seem pretty solid, as @byteguru mentioned, but holy moly, the cost can be pretty exorbitant. If we’re talking mission-critical files, sure, but for a lot of us, it might be hard to justify spending big bucks.
Multimedia industries, enterprises with a massive budget, they can swing it. But, for the average Joe, I’d explore more wallet-friendly avenues first. Disk Drill is one that kinda stands out, not just because it’s cost-effective, but also because it’s versatile.
Something that hasn’t been highlighted much here is the importance of prevention tools. Disk Drill (btw, you can check them out at https://www.cleverfiles.com/) comes with this feature called Recovery Vault. Basically, it’s like an undo button for deleted files. It’s exaggerated insurance against human error and can save a ton of headaches down the road. While you might have to spend a bit of time setting it up, it can be an absolute lifesaver.
For most DIY enthusiasts, I’d say start with software like Disk Drill. Especially since it supports an array of files and systems, it has your back whether you’re on Windows, macOS, or dealing with different file types. Plus, with the 500MB free version, you can gauge its efficiency without spending a dime.
However, let’s not ignore alternative professional services. Companies such as DriveSavers and Gillware also offer robust solutions without perhaps the same price tag as Ontrack. Maybe look into what third-party reviews are saying about their success rates and pricing transparency.
If your drive is making those ominous mechanical noises — clicking, grinding, etc. — professional service is likely unavoidable. Judiciously balance the value of lost data against the recovery cost. Sometimes, detailed reviews online are profoundly revelatory.
To wrap this up, blend in less pricey software solutions like Disk Drill for quicker and cheaper recovery routes. Reserve the high-end professional services for when absolutely necessary. And hey, regardless of the path you choose, always consider a solid cloud backup strategy moving forward to prevent future data despair.
Honestly, it’s a bit of a toss-up depending on how desperate you are to retrieve the data. Ontrack recovery services are top-notch and super comprehensive, but as @codecrafter and @byteguru mentioned, the prices can be pretty steep. For mission-critical files, maybe. For everyday stuff? Not so much.
Here’s an angle that’s worth considering: Disk Drill might be perfect for you if your hard drive isn’t completely toast. One thing that stands out about Disk Drill is its Recovery Vault feature, which acts like an undelete button for your files. Super helpful if you’re prone to accidental deletions. The downside is, it doesn’t handle physical damage, and success rates can be hit or miss.
An alternative to Disk Drill and Ontrack might be services like DriveSavers or Gillware. They also have strong reputations but do check customer reviews. Some have complained of hidden costs, so be vigilant.
I’d say start with Disk Drill if your drive hasn’t suffered too much physical damage. Disk Drill’s free version allows you to recover up to 500MB of data, which should give you an idea of its capabilities. Simple interface, easy navigation, really good for non-techies.
Remember, preventative measures like regular backups can save you from a lot of hassle in the long run. Cloud backups are worth looking into, but they do have their own quirks and security concerns.
To summarize, Ontrack is great but expensive; Disk Drill is cost-effective but might not solve all issues; and there are other fish in the sea like DriveSavers and Gillware that could be your knight in shining armor (or not).
Choose wisely based on how critical your lost data is and how much you’re willing to shell out.
Good take. Ontrack is strong but pricey. Disk Drill is fine for light logical issues. DriveSavers and Gillware are solid, watch quotes.
Simpler path. Bypass the enclosure. Many “dead” externals have a failed USB bridge, not the disk. Remove the drive, attach to a cheap SATA to USB dock or plug into a desktop SATA port. Use read only mode if offered. Check if it mounts. Run chkdsk or Disk Utility First Aid only after imaging. A $20 dock often revives access. I’ve recovred photos this way twice this year. Fast, low risk, no new software.
