My monitor started flickering halfway through a work session, and moving windows around just to keep text readable got old fast. I ended up trying Xreal Aura instead, but I couldn’t tell whether I was adjusting to a genuinely usable monitor replacement or just putting up with a different set of annoyances because the alternative was worse.
For people who have spent real workdays with it, do you actually use Xreal Aura as your only display, use it alongside a regular monitor, or stick with the monitor and leave Aura for occasional use? What made that setup the one you kept, especially for reading, typing, and switching between windows?
A broken monitor is a terrible benchmark.
I’d keep Aura as a secondary display, not the only one. The appeal is obvious when you want a large workspace without dedicating half the desk to screens, but sustained reading is the test that matters. If you have to increase text size, reposition windows, or move your head to catch content near the edges, the extra virtual space stops being useful pretty quickly.
The overlooked annoyance is everything outside the display. Touch typing may be easy enough, but checking the keyboard, reading notes, grabbing your phone, or dealing with a video call adds friction. A regular monitor lets you glance between those things without thinking about it. Window switching can be learned. Constantly shifting attention between virtual content and your physical desk is harder to ignore over a full day.
My practical setup would be a normal monitor for writing, spreadsheets, and anything text-heavy, with Xreal Aura used for a focused second workspace, private viewing, or travel. I’d only go Aura-only where space or portability mattered more than comfort. If the choice feels close solely because your current monitor is flickering, I’d replace the monitor before deciding the glasses have replaced it.
Your eyesight and the fit of the glasses matter more than the advertised screen size. Slight blur, glare, or pressure that seems harmless for twenty minutes can become exhausting during a long document or spreadsheet session. I’m less concerned than @router3027 about checking the physical desk, but I wouldn’t call Xreal Aura a monitor replacement until it survives several hours of small text without eye strain or constant adjustment. For video, coding with larger fonts, or travel, it could be the main display. For precision work, probably not.
Realistically, Xreal Aura could replace a second screen, but I’d keep a cheap physical monitor for calls and collaboration. Wearing glasses while switching between a virtual desktop, keyboard, phone, and coworkers adds friction that display specs don’t capture.
Boot screens, login prompts, driver failures, and app crashes matter more than they sound. A normal monitor is available before the operating system has finished waking up. A virtual workspace may depend on the computer, connection, and software all behaving properly. A display replacement that needs another display to troubleshoot it is a neat little comedy routine.
That is the reason I would not make Xreal Aura the only screen in the house, even if the image felt comfortable all day. Comfort is something you can evaluate over a week. Reliability tends to announce itself on the morning you have a deadline, the desktop refuses to appear, and your troubleshooting options consist of unplugging things while staring hopefully at the wall.
I’m less convinced that a full-size monitor has to remain the main workspace, though. If Aura makes focused writing, coding, or media work easier, use it as the primary display. Keep a small, boring physical screen nearby for setup, recovery, firmware updates, weird permission dialogs, and anything else that assumes you can already see the computer. It does not need to dominate the desk or become your default.
There is another practical issue with testing this while your monitor is flickering: almost anything stable will feel fantastic by comparison. That doesn’t make the glasses bad. It just means relief can disguise inconvenience for a while. The better test is to use Aura when a working monitor is available and see which screen you choose when neither option is actively annoying you.
So yes, it could replace a monitor for daily work, but I would not let it become a single point of failure. Retire the giant desk display if you want. Keep some cheap physical fallback around, preferably one boring enough that it never needs its own troubleshooting session.
No, if your workday is made of interruptions.
A monitor is useful even when you are barely using it. You can walk over, answer a message, check a build, approve something, and leave again. Putting on Xreal Aura, settling the view, finding the right window, then taking it off turns every small task into a procedure. None of those steps is terrible. Repeating them all day is.
That is where I slightly disagree with the focus on text quality. Perfectly readable text would not solve the basic difference between equipment you wear and equipment that sits there waiting. Glasses suit long, deliberate sessions. A monitor handles fragmented work better.
There is a social angle too. With a regular display, someone can approach and immediately tell whether you are busy, stuck, or available. Glasses make your attention less obvious. That may be irrelevant at home. In a shared office, it can produce a steady stream of shoulder taps and explanations.
Aura could replace a monitor for someone who spends hours inside one task, especially if desk space matters. For a manager, support worker, parent working from home, or anyone constantly getting pulled away, it would probably become the device they keep meaning to put back on.
Count how often you remove it during a normal day. That number matters more than the virtual screen size.
Check the focal distance before you commit to full days in it. The virtual screen sits at a fixed depth, so your eyes stay locked at roughly the same focus for hours, and unlike a desk where you can glance out a window or across the room to reset, there’s no natural far point to relax on. That’s the part @nanocloud1188 was circling with the eye strain worry, but it’s less about fit or blur and more about your focus never getting a break. If you already get tired eyes at a normal screen, the Aura won’t fix that and might make it worse. Honestly I’d worry less about whether it can replace a monitor and more about whether your eyes forgive you at hour four. Try it in a bright room too, since ambient light washes out the image more than the demos let on.
Run a real screen-sharing session before retiring the monitor. Virtual desktops can feel great to the person wearing the glasses while producing awkward scaling, tiny text, misplaced windows, or accidental notification sharing for everyone else.
That matters if your job includes demos, training, pair programming, or frequent “show me what you’re seeing” moments. You may spend more time rearranging the workspace for other people than benefiting from the extra space yourself. Screenshots and remote-support sessions deserve a test too.
Xreal Aura could replace a monitor for mostly private, solo work. For collaboration-heavy work, I suspect it replaces the desk screen right up until the first meeting, then the normal display gets turned back on.
