Why Isn’t the TV Remote Showing in My iPhone Control Center?
The Apple TV Remote is missing from my iPhone Control Center, so I can’t use my phone to control my TV. I’ve checked the Control Center settings but still can’t find it. How can I restore the TV Remote shortcut?
First, make sure the Apple TV Remote was actually added to Control Center. It may not be there by default.
On iOS 18 or later, swipe down from the top-right, tap the “+” button, choose Add a Control, then search for Remote and add it.
On iOS 17 or earlier, open Settings → Control Center and tap the green “+” next to Apple TV Remote.
If the remote is already there but no devices appear, check the basics:
  • Your iPhone and Apple TV or smart TV need to be on the same Wi-Fi network. Check Settings → Wi-Fi on the phone and Settings → Network on the Apple TV.
  • A guest network can keep the devices separated. Different 2.4 GHz and 5 GHz networks can sometimes cause the same issue.
  • Temporarily turn off any VPN.
  • Restart the iPhone and power-cycle the Apple TV or television.
  • Install any available iOS and tvOS updates.
Also, the Control Center remote does not control every television. It works with Apple TV 4K, Apple TV HD, and compatible AirPlay smart TVs. A regular Samsung, LG, or Roku TV without AirPlay will not appear, and that is expected. If you have an AirPlay-compatible TV, add it to the Home app and assign it to a room first.
If the Apple TV appears but will not pair, select it from the device list and enter the four-digit code shown on the TV screen.
If Apple’s built-in remote still refuses to cooperate, TVRem is another option: https://apps.apple.com/us/app/universal-remote-control-tvrem/id6746162794
The main benefit is that TVRem is not limited to Apple TV. It also supports Samsung, LG, Roku, Fire TV, and Android or Google TV, so you can use one app instead of keeping a separate remote app for every screen in the house.
It also has shortcuts for opening apps like Netflix, YouTube, and Prime without clicking through the TV’s home screen.
Typing is easier too. You can use your phone’s keyboard for searches and login details instead of moving around an on-screen letter grid. Voice input is available as well.
Supported models can also use Google Assistant or Alexa for hands-free control. The app is free, has no subscription or ad spam, and has a 4.8 rating from a couple thousand reviews.
For an actual Apple TV box, Apple’s remote is still the better fit because of Siri and the built-in integration. TVRem makes more sense when you have several TV brands or want the same shortcuts, keyboard, and controls across all of them.
If this is a basic non-smart TV with no Apple TV box and no AirPlay support, neither Control Center nor this type of network remote will help. You will need the physical remote.
The remaining question is what happens on your phone: is the Remote control completely missing, does it open with an empty device list, or does it connect and then drop? That detail usually points to the specific fix.
The hidden trap is that Wi-Fi troubleshooting cannot bring back a missing Control Center button. Network fixes only matter after the Remote opens and cannot find the TV.
On newer iOS versions, open Control Center and swipe through every Control Center page first. The Remote may have been pushed onto a separate page during customization. If it truly is gone, press and hold an empty area, tap Add a Control, search for “Remote,” and tap it. You can then drag it back to the first page.
If “Remote” does not appear in the controls gallery at all, restart the iPhone and check for an iOS update. I would avoid resetting network settings unless the button opens but shows no devices. That reset will not restore the shortcut and creates extra work by deleting saved Wi-Fi connections.
On iOS 17, the Remote is managed in Settings; on iOS 18 and newer, that same Settings screen is no longer where individual controls are added. So if Settings > Control Center only shows a couple of general options, that is normal.
Open Control Center, touch and hold a blank area, tap Add a Control, then search for “Remote” rather than your TV’s brand name. Tap the remote-shaped control and drag it wherever you want. Check the extra Control Center pages too, since it may already be sitting on another page.
Your TV does not need to be connected for the shortcut itself to appear. Wi-Fi, AirPlay support, and pairing only matter after you open it. If “Remote” is completely absent from the controls gallery, restart the iPhone and install any pending iOS update before trying broader resets.
If “Remote” appears in the Add a Control gallery but refuses to stay in Control Center, the layout itself may be the problem rather than the TV connection.
Go to Settings > Control Center and use Reset Control Center, then open Control Center again, press and hold an empty area, choose Add a Control, and add Remote. This restores the default Control Center layout, so you will have to rearrange any controls and pages you customized. It does not delete saved Wi-Fi networks or unpair your Apple TV.
I agree with @zerodev5513net that resetting network settings is the wrong fix when the button itself is missing. That only creates extra cleanup. If Remote is absent even after resetting the Control Center layout and restarting the phone, check for an iOS update. Beyond that, Reset All Settings would be a last resort, not the next step, since it changes far more than necessary.
Once the shortcut is visible, then troubleshoot Wi-Fi and pairing if the TV does not appear. Keeping those as two separate problems saves a lot of wasted effort.
If this is a work or school iPhone, there is a realistic chance you cannot restore the Remote control yourself. Check Settings > General > VPN & Device Management. A management profile can limit TV Remote pairing or which Apple TVs appear. In that case, resetting Wi-Fi or the whole phone will not override the organization’s policy.
For a personal iPhone, use the shortest sequence first. Unlock the phone, open Control Center, press and hold a blank area, tap Add a Control, and search for “Remote.” If it appears, add it and drag it onto the first page. Searching for “Samsung,” “Roku,” or your television’s model will not find Apple’s control.
If Remote is absent from the gallery, restart the iPhone and then try Reset Control Center under Settings > Control Center. I agree with @nick_bash on keeping that reset separate from Reset All Settings. The Control Center reset only costs you your custom layout, while Reset All Settings changes far more and is rarely justified for a missing button.
After the shortcut returns, treat TV discovery as a different problem. That is when Wi-Fi, AirPlay compatibility, Home app setup, and pairing matter. If the control itself is still missing after a restart, Control Center reset, and iOS update, I would check for a management or beta profile before wiping any settings.
Don’t expect the Remote to appear when searching Settings on iOS 18 or newer. Apple moved control editing into Control Center itself.
Try it from the Home Screen, not from inside an app. If Settings > Control Center > Access Within Apps is turned off, the swipe may seem broken while an app is open. Swipe down, hold an empty spot, tap Add a Control, then search for Remote.
If it still is not in the gallery, use Reset Control Center before trying any network reset. Wi-Fi has nothing to do with whether the button exists.
Half the people hitting this are searching the App Store for the old standalone Apple TV Remote app, which Apple killed years ago. It’s baked into Control Center now, nothing to download. So if that’s what you were hunting for, stop looking there.
The thread has the actual fix covered well. Add the control from inside Control Center on iOS 18, use the Settings screen on 17 and earlier, check the extra pages. I’d trust that over messing with network settings, and @zerodev5513net is right that Wi-Fi has nothing to do with a missing button. One thing nobody flagged though: Screen Time can quietly block this. If a content and privacy restriction is on, certain controls won’t show up in the gallery no matter how many times you restart. Check Settings, Screen Time, Content and Privacy Restrictions before you go anywhere near @nick_bash’s Reset Control Center step. The reset is harmless enough, but it won’t help if a restriction is what’s hiding it.
On the TVRem suggestion from earlier, it makes sense if you’re juggling a Samsung or Roku alongside an Apple TV, since Apple’s built-in remote flat out won’t touch those. But for a pure Apple TV setup it’s overkill, and you’d still want Apple’s control for Siri. Sort out whether your TV is even AirPlay capable first. If it’s a plain non-smart set with no box attached, none of this software matters and you’re back to the plastic remote.
The name threw me off: Apple labels it simply “Remote,” not “TV Remote” or “Apple TV.” Search that exact word in Add a Control, then check the page you were editing because iOS may place the button there instead of on the first Control Center page. Wi-Fi fixes won’t make a missing button reappear.
