My Dell Pro 14 Plus PB14250 started having issues, and I’m trying to figure out what went wrong. It was working fine, then suddenly began acting up, and now I need help troubleshooting the problem so I can get it working normally again.
Start with the basics. Sudden issues on a Dell laptop usually fall into 4 buckets. Power, RAM, SSD, or Windows corruption.
Do this in order.
Hard reset.
Shut it down.
Unplug charger.
Hold power button for 20 seconds.
Plug charger back in.
Power on. -
Check LEDs and signs.
No lights, no fan, no screen, suspect charger or board.
Lights and fan, but no display, suspect screen or RAM.
Dell logo appears, then fails, suspect SSD or Windows. -
Run Dell diagnostics.
Tap F12 at startup.
Choose Diagnostics.
If it throws RAM or SSD errors, stop there and replace the bad part. -
Try BIOS.
Tap F2.
See if SSD shows up.
If drive is missing, that’s a big clue. -
Test safe boot.
If Windows starts looping or crashing, boot into recovery and run Startup Repair.
If that fails, back up files and reinstall Windows. -
Check heat and fan noise.
If it got hot before this started, clean vents. BIOS thermal events matter.
If you post the exact symptoms, beep code, LED pattern, or error text, people here can narrow it down fast. Right now it’s too broad to pin down the exact failuer.
I’d add one angle @reveurdenuit didn’t really dig into: updates and firmware. A lot of these “was fine yesterday, broken today” cases happen right after a Windows update, BIOS update, or even Dell firmware pushed through SupportAssist.
A few things I’d check:
- In BIOS, load defaults once. Bad BIOS settings can cause weird boot/display stuff.
- If it powers on but acts flaky, disconnect everything external. USB docks, monitors, dongles, even mice. I’ve seen one bad USB device stop a Dell from booting right.
- If Windows does load, check Event Viewer for critical errors around the time it started. Look for Kernel-Power, disk, or driver failures.
- If the keyboard works in BIOS but not in Windows, that points more to driver/software than hardware.
- If battery charge is stuck or it only works on AC, run
powercfg /batteryreportfrom Command Prompt and see if the battery health fell off a cliff.
I’d slightly disagree on jumping straight to “replace the bad part” from one diag result. Sometimes SSD errors are from a loose connection or firmware hiccup, not instant death. Back up data first if you still can.
Post the exact symptom: no power, black screen, boot loop, freezing, blue screen, fan screaming, etc. Right now it’s kinda too vauge to call.
What I’d do next is separate power-path issues from OS issues before tearing into drivers.
- Watch the charging LED behavior. On Dell, weird or missing charge light patterns can point to adapter, battery, or board problems before Windows is even relevant.
- Try LCD BIST if this model supports it. If the screen can show built-in color tests, the panel/GPU path may be fine and the issue is higher up the chain.
- Listen for signs of life: caps lock response, fan spin pattern, backlight glow, Windows login sound. “Black screen” is not always “dead laptop”.
- Reseat what you can if you’re comfortable opening it. Especially SSD and battery connector. I slightly disagree with assuming software first if the failure was abrupt with no update involved.
- Run Dell ePSA preboot diagnostics repeatedly, not just once. Intermittent RAM or SSD faults sometimes only show on a second pass.
- Test one RAM configuration at a time if the Dell Pro 14 Plus PB14250 has removable memory. If soldered, skip this.
- Check for thermal shutdown history. If it starts, runs briefly, then dies, clogged cooling or failing fan is a real possibility.
@reveurdenuit raised good points, but I’d put preboot hardware behavior ahead of Event Viewer unless Windows is still loading reliably.
Pros of the ‘’: can improve readability in long troubleshooting threads.
Cons of the ‘’: not much to say since no actual product title was provided.
If you can, post exactly which of these applies: no LED, LED but no screen, Dell logo then freeze, Windows loop, random shutoff, or battery not charging.
Try a full power reset first. Shut the laptop down. Unplug the charger and all USB accesories. Hold the power button for 30 seconds. Wait one minute. Reconnect only the original Dell charger, then start it.
If the issue stays, use another compatible Dell USB-C charger rated at 65W or higher. This quickly isolates a bad adapter.
For the simplest route, enter your Service Tag on Dell Support and request warranty repair. Avoid opening a newer laptop before checking coverage.
Don’t reinstall Windows or crack the case open on a laptop this new before you’ve nailed down the exact symptom. That’s the trap in this whole thread so far. Everyone’s handing you a full decision tree, but half of it doesn’t even apply until you tell us what the machine is doing.
Quick reality check on one thing: @chasseurdetoiles mentioned testing one RAM stick at a time. On the PB14250 the memory is soldered, so there’s nothing to pull or reseat there. Same goes for the SSD reseat idea, doable, but on a current Dell you’re risking the warranty for a five minute check that a repair tech would do for free. That’s why @cyberrouter3323’s warranty point is the one I’d actually lean on. This isn’t a five year old machine you’ve got nothing to lose on.
Where I land: run the F12 preboot diagnostics and the LCD BIST first, because those cost you nothing and they tell you fast whether it’s hardware or Windows. If diagnostics come back clean and it still misbehaves, then the software angle @caminantenocturno raised is worth chasing, especially the SupportAssist firmware push, since that lines up perfectly with a ‘fine yesterday, broken today’ story. But post the actual symptom before you touch anything. No power, black screen with fans, Dell logo freeze, boot loop, they each point somewhere completely different, and right now people are just guessing.
