Is It Possible To Recover Deleted Files From Emptied Trash On Mac?
I accidentally emptied the Trash on my Mac and lost important files I still need for work. I didn’t have a recent backup, and now I’m trying to find out if deleted files can still be recovered after the Trash is emptied on macOS. I’d really appreciate advice on the best Mac file recovery options or steps to try before the data is gone for good.
First thing I’d do, and I mean right now, stop using the MacBook.
No downloads. No app installs. Don’t save files. Quit stuff running in the background if you still can.
Here’s the ugly part. Emptying Trash on macOS usually does not erase the file data right away. The system drops the pointers to those files and marks the space as free. So the old data often still sits on the drive for a bit. The catch is simple, once new data lands there, your old file gets overwritten and recovery odds fall off fast.
On newer MacBooks this gets worse because of SSD behavior and TRIM. TRIM tells the drive to clean out deleted blocks in the background. Good for speed. Bad for recovery. I’ve seen deleted stuff vanish way faster on SSD Macs than people expect.
Before touching recovery tools, check the easy exits.
  1. Time Machine snapshots
If you use Time Machine, open it and go to the folder where the files lived before you trashed them. Even without the backup drive connected, macOS often keeps local snapshots for about the last 24 hours. I’d check there first because it’s clean and fast.
  1. Cloud storage
If those files were synced with iCloud Drive, Dropbox, or Google Drive, do not keep poking around on the Mac. Use your phone or another computer and sign into the web version of the service. A lot of them keep their own deleted-items area for around 30 days, separate from your Mac’s Trash.
  1. App-level deleted folders
This trips people up all the time. Photos and Notes have their own Recently Deleted sections. So even if Trash is empty, your stuff might still be sitting inside the app for 30 to 40 days.
If none of those worked, then I’d move to recovery software.
What these tools do is scan the raw storage and look for file traces before they get overwritten. If the deleted data is still there, recovery software has a shot. If TRIM already cleared it, results get rough.
I’ve had the best luck with Disk Drill on Macs, esp on newer ones. A bunch of older Mac recovery apps seem half-dead on Apple Silicon systems or machines with the T2 chip. Permissions, encryption, all the usual Apple lockouts. Disk Drill tends to handle modern Macs better than the random old utilities people keep recommending from 2014 forum posts.
Big warning here. Do not install recovery software onto the same internal drive if you can avoid it. That write activity is exactly what you’re trying to avoid. Best move is this:
  • Use another computer
  • Download Disk Drill onto a USB flash drive
  • Plug the USB into the MacBook
  • Run it from there if possible
Then run a Universal Scan.
The useful part is the scan itself is free, and you get previews. I’d always preview before paying for anything. If your photos show full thumbnails and your docs open in preview, you at least know the files are not mangled. If you recover them, save them to an external drive, not back to the Mac’s internal storage. People mess this up, then overwrite more stuff. Kinda brutal.
If the scan finds nothing, then you’re down to lab recovery.
That means a data recovery shop with proper hardware, sometimes cleanroom work, and direct access methods outside normal macOS tools. It works often enough, but the pricing hurts. I usually see numbers from $300 up to $3,000 depending on damage, urgency, and device type. For tax records, legal docs, business data, baby photos, stuff like that, people pay it. For random downloads, not so much.
One more thing. Ignore the Terminal-command folklore. I keep seeing posts where people throw shell commands at an emptied Trash problem like it’s some secret cheat code. Those commands help in specific cases, like moving items out of a stuck Trash. They do not pull erased files back out of nowhere.
So the short version:
  • Stop using the MacBook
  • Check Time Machine
  • Check cloud trash from another device
  • Check Photos or Notes Recently Deleted
  • If needed, scan with Disk Drill from a USB setup
  • Recover to an external drive
  • If all else fails, call a recovery lab
If you move fast, you still have a shot. If you keep using the Mac, the drive tends to make the choice for you.
Yes, recovery is still possible after you empty Trash on a Mac. The odds depend on two things, your drive type and how much you used the Mac after deletion.
I agree with @mikeappsreviewer on one part, stop writing new data fast. I disagree a bit on the “go straight to software” vibe, because on newer Macs with SSDs and TRIM, software scans often return a lot of noise and not your missing work files.
A few things people skip:
Check other Macs or iOS devices tied to the same Apple ID. If Desktop and Documents syncing was on, an older copy might still sit on another device that has not synced changes yet.
Look in app autosave and temp folders. Microsoft Word, Excel, Adobe apps, and some editors keep autorecovery files. For Office, search Finder for “AutoRecovery” and sort by date. I’ve seen people recover 90 percent of a report this way after Trash was emptied.
Open Terminal and inspect recent file activity, not for magic recovery, but to identify original file names and paths. That helps a ton when scanning in Disk Drill later.
If FileVault was enabled and the Mac sat on for hours after deletion, recovery odds drop hard on SSD models. Older Intel Macs with hard drives usually give better results. New Apple Silicon Macs are less forgiving.
If the files matter for work, make a byte-for-byte image of the drive first, then scan the image, not the live disk. That avoids more wear and more writes. This is the part most home users skip, then regret.
Disk Drill is still one of the better Mac options for deep scans and previewing recoverable files. Use it on an external drive, not your startup disk.
This vid is decent if you want a step-by-step Mac guide for recovering files after emptying Trash:
recover deleted files after emptying Trash on Mac
Short version. Yes, there’s still a shot. On a newer SSD Mac, move fast or the data gets wiped out fast too. If the files are worth money, skip DIY and image the drive first.
Yes, sometimes. But I’d add one thing to what @mikeappsreviewer and @boswandelaar said: if this is a work Mac and the files were in a company-managed folder, check your office suite’s version history or collaboration logs before doing anything fancy. A lot of people forget that Word, Excel, Google Docs, Adobe Cloud, even some project tools keep older copies outside Trash entirely.
Also, I’m not fully sold on home users jumping straight into disk imaging unless they already know what they’re doing. It’s smart in theory, but it can get messy fast. For most people, the practical route is checking app/version history, then scanning with something like Disk Drill from external storage and recovering to another drive.
Another overlooked place is email. I’ve seen “lost” attachments recovered because the original doc had been mailed around and was still sitting in Sent or in a thread. Sounds dumb, works more than you’d think.
One more reality check: if it was deleted from an internal SSD on a newer Mac, recovery chances can be kinda bad even if you act fast. Not impossible, just not the old days.
If you want another discussion on this exact issue, this Apple forum thread covers empty Trash recovery on Mac pretty well:
So yeah, possible? Yes. Guaranteed? nope. The less you use the Mac right now, the better your odds.
Possible, yes. Predictable, not really.
I’d add one angle the others only touched lightly: check whether the files ever lived inside an app library or package. On Mac, projects from Final Cut, Logic, Photos, some design apps, and even Scrivener can look “deleted” while pieces still exist inside package contents or app-managed storage. Right click related project files, Show Package Contents, and search there before assuming the whole thing is gone.
I slightly disagree with the “image first no matter what” advice from @boswandelaar. Good practice, sure, but on a normal work Mac with APFS, FileVault, limited free space, and no second drive ready, people can burn hours setting that up and miss easier wins. I’d prioritize:
  • app version history
  • app autosave containers
  • package contents
  • cloud web recycle bins
  • shared/team drive history
  • then recovery scan
One more overlooked source: APFS local document versions. Some apps support Browse All Versions. Open the app and the same document name if it still exists, then check File menu for Revert To. It sometimes resurrects older states even when the Finder file is gone.
If you do scan, Disk Drill is a reasonable option.
  • solid APFS support
  • easy previews
  • simple enough for non-tech users
  • can find lost partitions and deleted files in one pass
  • results on TRIMmed SSDs can still be disappointing
  • deep scans return lots of junk filenames
  • recovery license cost may sting
  • best practice needs another drive, which many people do not have handy
So I’d read @mikeappsreviewer, @cazadordeestrellas, and @boswandelaar as mostly right on the urgency part. My tweak is this: don’t only think “Trash recovery.” Think “where else did this file exist?” For work docs, that often beats raw recovery.
