I have a photo I want to improve with AI, but I’m not sure which tool to use or how to get natural-looking results. I tried a couple of apps and the edits came out blurry and fake, so I need help figuring out the best way to enhance or change a picture with AI.
If your edits look blurry or fake, the issue is often the workflow, not the photo.
Use the right tool for the job.
For quick cleanup
Photoshop Lightroom AI.
Best for exposure, color, noise, and sharpening.
Natural results if you keep changes small. -
For face retouching
Photoshop, Facetune, or AirBrush.
Use skin smoothing at low strength. Around 10 to 25 percent.
If pores vanish, you went too far. -
For upscaling old or low-res photos
Topaz Photo AI or Gigapixel.
These do better than most phone apps.
Good for print. Mixed results on faces if the source is tiny. -
For removing objects
Photoshop Generative Fill or Cleanup Picture.
Works best on simple backgrounds.
Hair, hands, and shadows still trip it up sometiems.
Simple workflow:
First fix light and color.
Then remove noise.
Then sharpen.
Then retouch skin.
Last, upscale if needed.
If you upscale first, artifacts get worse.
A few settings rules:
Keep sharpening low.
Keep skin texture visible.
Do not whiten eyes or teeth too much.
Do not blur the background unless the mask is clean.
Zoom out often. Fake edits look worse at normal size.
Best natural-looking setup for most people:
Lightroom for global edits.
Photoshop for small fixes.
Topaz only if the file is low res.
If you want, post the type of photo, portrait, old family pic, phone selfie, product shot, and people here will give better tool recs.
Blurry and fake usually means the app is doing too much auto-magic, not that your photo is hopeless.
One thing I’d add to what @ombrasilente said: sometimes the best “AI photo editing” tool is not an editor at all, it’s a masking tool. A lot of bad results happen because the app edits the whole image equally. Faces, skin, sky, clothes, and background all need different treatment. If the app can’t target areas cleanly, it’ll look cheap fast.
My take:
- Snapseed is still weirdly good for subtle edits on phones
- Photomator on Apple stuff has solid AI adjustments without going full wax museum
- If you want restoration, try Remini carefully, but honestly I disagree with people who use it as a default. It can invent details that were never there and make everyone look like plastic
- For old scanned pics, sometimes manual contrast + dust cleanup beats AI enhancers by a mile
Big tip: export once, not 5 times. Re-saving from app to app wrecks detail.
Also, if the source photo is badly focused, AI can sharpen edges but it can’t truly fix missed focus. A lotta apps pretend otherwise.
Rule I use:
- fix composition first
- make small local edits
- compare against the original every minute or two
- stop as soon as it looks “better,” not “different”
If you want natural, keep a tiny bit of imperfection. That’s the part most apps try to kill, and that’s exaclty why the result looks fake.
I’d split this into two questions: what kind of photo and what kind of fix.
If it’s a normal recent photo:
- Use Lightroom or Photoshop Express for tone, color, noise, and light cleanup
- Use AI only for small assists like denoise, subject select, or distraction removal
- Avoid one-tap “enhance” modes if skin matters
If it’s an old photo:
- Use a restoration-focused tool, then dial results back
- I slightly disagree with @ombrasilente on one point: AI restoration is not always worse than manual work. On badly faded scans, AI can give you a usable base fast. You just have to treat it like a draft, not the final image.
What usually makes results fake:
- over-sharpening
- skin smoothing
- HDR-style contrast
- face relighting
- eye/teeth enhancement
Best practical workflow:
- Start from the highest-resolution original
- Crop and straighten
- Fix exposure and white balance manually
- Apply very light denoise
- Sharpen only at the end
- Export once at high quality
Pros of ':
- can improve readability if the tool is simple
- may speed up beginner edits
Cons of ':
- if it leans too hard on auto AI, results can look generic
- limited local control usually causes that fake “processed” look
Quick rule: if you instantly notice the edit, it’s probably too strong.
