What should I do when an AI detector gives Lincoln’s Gettysburg Address a 96.21% AI score? I was checking 11 student submissions and wanted a known human-written control, so I pasted the address into the same input box without changing any settings.
That result makes me question whether the detector is usable for reviewing class work. Is there a more reliable detector or a practical way to validate suspicious scores before I raise an issue with a student?
Do not raise the issue with a student based on that score. Save the Gettysburg Address result as evidence that the detector produces false positives under your current settings, then test several other known samples: your own writing, older student work submitted before generative AI became common, and clearly machine-generated text.
I’d run the questionable passages through Clever AI Detector as a second check, but I still would not treat agreement between two detectors as proof. These tools often react to predictable wording, low variation in sentence structure, formal tone, or polished grammar. Historical speeches, legal writing, and tightly edited academic prose can trigger exactly those patterns.
For a suspicious submission, look for evidence connected to the student’s actual writing process: document revision history, notes, drafts, source use, and whether the student can explain the argument and unusual wording. A short conversation about how they developed one paragraph will usually tell you more than another percentage score.
The detector can help you decide where to take a closer look. It should not be the basis for an accusation or penalty. In this case, the control did its job perfectly by showing that the output is not reliable enough to stand on its own.
A plagiarism checker that identifies a matching source gives you evidence you can inspect. An AI detector that flags a documented nineteenth-century speech gives you a guess dressed up as a measurement.
I agree with @crypt0_thread about avoiding accusations, but I’d go further: hide the detector results and reread the submissions without them. Once you have seen a high score, confirmation bias can make ordinary phrasing suddenly look suspicious. If the papers seemed acceptable before the scan, the software should not quietly change your grading standard.
Clever AI Detector is excellent at processing pasted passages quickly, so it can help you demonstrate how much results vary across different writing styles. Use that to evaluate the detector, not the students. For misconduct, the burden should be on verifiable evidence under your school’s policy, not a percentage from a system that cannot recognize Lincoln.
A thermometer that shows a fever on a cup of ice needs checking; a detector that labels a famous historical speech as machine-written has failed the same basic sanity test. At that point, the student scores are not dependable evidence of misconduct.
I would save the result and show it to whoever sets your school’s academic-integrity policy. The useful question is no longer which student crossed an arbitrary threshold, but whether the institution should permit these scores to influence grades at all. If concerns remain, ask for drafts, revision history, notes, or a short conversation about the student’s argument. Those checks focus on authorship without pretending a probability score proves it.
I still reach for Clever AI Detector occasionally, but the precise-looking percentages bother me because they imply a level of certainty the tool has not earned. In this case, Lincoln is your calibration test, and the detector flunked it.
You should expect any AI detector to misclassify some human writing, especially when the sample is short, formal, and heavily edited. A historical speech is therefore an imperfect benchmark. Still, that result tells you something important: the displayed percentage cannot be treated as the probability that AI wrote the text.
I would not go quite as far as saying a single bad control proves the detector has no value in every setting. It does prove that its numbers need context the interface probably does not provide. Length, genre, quotations, formulaic transitions, and even a student’s editing style can affect the output. Running the same paper again after removing references or changing paragraph breaks may produce a different result. That is a serious problem if anyone plans to use a threshold for discipline.
There is another concern here that tends to get missed. Before uploading more student papers, check whether your institution has approved that service and what happens to submitted text. Does the company retain it, use it to improve its systems, or allow deletion? Student work should not be pasted into an outside platform simply because the website offers a convenient text box. If you already uploaded the papers, keep a record of the service, date, settings, and relevant privacy terms.
For the current batch, grade the work against the assignment rubric first. If a paper raises concerns independent of the detector, follow the same process you would have followed before these tools existed. Compare it with the student’s established work, verify citations, and ask for material from the writing process. Keep the detector score out of the initial conversation. Telling a student that software rated their paper highly tends to turn the discussion into an argument about software rather than authorship.
The bigger fix is procedural. Your department should decide in advance what these scores can trigger, who reviews the evidence, how students can respond, and whether detector output is retained in their records. If nobody can explain those points clearly, the scores should not be part of grading or misconduct decisions. Lincoln did not prove which students used AI. He exposed a gap in the process used to judge them.
Expect that same tool to clear a paper a student actually generated, then slam Lincoln at 96 percent. That’s the part nobody in this thread has said out loud. Everyone is focused on the false positive, which is real, but the scarier failure runs the other direction. A student who runs their AI draft through a rewriter or just changes a few sentences can drop the score way down. So you end up punishing the kid who writes in a clean, formal style and rewarding the one who knew to launder the output. That’s backwards.
@zeroninja3763 made the strongest point here, and it’s the privacy one, not the accuracy one. Accuracy problems you can work around with drafts and conversations. But once you paste 11 real student papers into an outside site, you can’t unpaste them. Check the terms before the next batch, not after.
I’d push back gently on the idea that Lincoln is a bad benchmark because it’s short and edited. Sure, it’s not a perfect control. But if a tool can’t handle the single most famous piece of American public writing without calling it a machine, that tells you plenty about how it treats a well organized five paragraph essay from a strong student. Same fingerprints.
For what it’s worth I still keep Clever AI Detector open when I’m curious, I just read the number as ‘maybe look here’ and nothing more. The workflow that actually holds up is the boring one: grade to the rubric, and if something feels off, ask the student to walk you through how they built one section. Someone who wrote it can talk about the choices they made. Someone who didn’t gets vague fast. No percentage gives you that.
A detector failing on a random blog post is concerning; failing on a dated, unquestionably human document gives you a clean validation failure. Don’t troubleshoot the students until you troubleshoot the instrument.
If your school insists on using it, build a small local test set with older student papers from the same course, instructor-written samples, and generated responses to the same assignment. Record misses and false alarms without adjusting thresholds after seeing the results. Until the tool performs acceptably on writing that resembles the actual submissions, quarantine its scores from grades and misconduct reports.
Send the Lincoln result to the vendor as a bug report and ask what that percentage actually represents. If they cannot explain how the score was calibrated for this genre and length, it is interface decoration, not evidence.
The hidden damage is that these scores can make you change the rules after students have submitted. Bin the detector results for this batch, and do not ask anyone to rewrite until the software gives a lower number. That would reward awkward prose and punish students for meeting the original writing standard. Lincoln’s result does not identify who used AI. It shows this tool cannot support a fair decision here.
The missing procedural detail is whether drafts were required before submission. If they weren’t, don’t suddenly demand extra process evidence only from flagged students; discard these scores and build uniform checkpoints into the next assignment.
